Question about Canon MX700 Office All-In-One InkJet Printer
Canon MX700 Error Code is 6A80 Does not print on/off flashing Alarm with yellow light flashing
    Brigadier General:
  • 8,619 Answers
Hi!
This issue arises when a purge unit is faulty or there is apaper jam. Check for paper jam & please revert for further clarifications.
Posted on Feb 17, 2009
  • Rylee Smith
    Rylee Smith Feb 17, 2009
    To solve it lift up the scanner unit, with the unit ON, wait for the print head to come in the middle, move it to left.
    And, see for any peice of paper jammed inside or near the print head or on extreme end of the unit.
    Genius:
  • 1,550 Answers
You need to clean print head . The error code occurs when print head is not detected properly.
  • SAM ANDERSON Feb 17, 2009
    6A80 error is an APP position error. It means that an error has occurred
    when the motor was running during the purging operation on start up.
    The error occurs because purge unit got damaged or stuck. Probably you have to pulled apart the printer and check the purge unit.
  • Canon Master
  • 19,396 Answers
Try first unplugging power cord for five minutes.
  • Ginko
    Ginko Feb 17, 2009
    If unplugging does not reset then the error means app position error.
    I quote solution from:Message error 6A80 - FixYa
    "6A80 error is an APP position error caused by the APP motor during the
    purging operation as the printer starts up. Canon states that one of
    three components is likely to have failed, the sheet feed unit, purge
    unit or logic board. All of these will be almost impossible to get as a
    spare part. The only thing worth trying is an EEPROM reset that can be
    done using the service manual. Get a copy here: http://www.tradebit.com/filedetail.php/4..."
My MX700 canon printer is flashing the on ff green light and the gold alarm light and say error code 6A80. My book says to unplug all power and the plug back in but it is doing the same thing. Thanks for...
The printer head has locked itself and won't move.
I have found a solution for you on the Internet - here are the details :-
I was able to unlock the print head - just with a small piece of foil.
Cut a 3-5cm wide stripe from a sheet of overhead-foil (90um thickness), move it below the print head, and move it to the front and upwards, to the back and upwards. Remove the foil. After switching the printer on - it will work as before and be able to move the head. No need to disassemble the whole MX700!
Leo.
Nov 21, 2010 | Canon PIXMA MX700 All-In-One InkJet...
Error code 6A80, won't print after changing ink cartridge. printhead is all the way to left. Tried moving it manually and turning off and unplugging printer.
@font-face { font-family: "Times New Roman"; }@font-face { font-family: "Verdana"; }p.MsoNormal, li.MsoNormal, div.MsoNormal { margin: 0in 0in 0.0001pt; font-size: 14pt; font-family: Verdana; }table.MsoNormalTable { font-size: 10pt; font-family: "Times New Roman"; }div.Section1 { page: Section1; }
Issue: ERROR LCD: Error Code 6A80
Solution #1: Press ON/OFF switch to reset the multifunction device
Reset the device when it is not functioning properly.
If the device is not functioning properly or to clear memory, reset it.
1. On the operator panel, press and hold the button for one second. (The display will go blank.)
Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
2. Wait approximately ten seconds and then press the button again.
3. Wait until the device has completed its cycling process before submitting another job request.
Solution #2: Removing paper jams MX700
See very detailed description at this link:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx700#ServiceAndSupport
Jun 30, 2010 | Canon PIXMA MX700 All-In-One InkJet...
I have a Canon MP550 and after pressing ON button in few seconfs appeares message: ERROR CODE 6A80
[6A80] & Light Blinking 12 times = APP Position Error. An error occurred in the APP motor. Maybe foreign material or paper debris around the PURGE UNIT (at the printer most right hand side) or Auto Sheet Feed area.
May 24, 2010 | Canon PIXMA MX700 All-In-One InkJet...
What does 6A60 error message indicate and how do I resolve on my Canon MX700 all in one machine.
6A60 error is an APP (Application Printer) position error. It means that an error has occurred when the motor was running during the purging operation on start up.Check the sheet feeder and purge unit.Sometimes pieces of paper stuck in purge unit.
Thank you!
Nov 02, 2009 | Canon PIXMA MX700 All-In-One InkJet...
My Canon Pixma Printer MX700 is near new and the screen is showing Error Code 6A80...and the alarm light is flashing.. Does anyone know what the problem is?
According to Canon there is a way to reset the printer.
Just go to this link and this should help.
http://fix-your-printer.blogspot.com/2009/06/error-code-6a80-on-canon-printers.html
If you need further assistace, please respond to this post and I will help you.
Thanks for using FixYa
asnowman
Nov 01, 2009 | Canon PIXMA MX700 All-In-One InkJet...
MX700 ERROR 6A80
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Error 6A80 – means “AP position error”- indicates that "an error occurred in the APP motor during purging operation". Either the sheet feed unit, purge unit, or logic board could be at fault.
I'd recommend bringing the unit into your local canon authorized service facility for complete diagnostic and repair.
Hope this helps
Aug 08, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Error 6A80
Error 6A80 indicates that "an error occurred in the APP motor
May 22, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Cannon Mx700 error code 6a80.
It is because of Purge unit can be damaged or stuck. Probably you have to pulled apart the printer and check the purge unit.
Nov 27, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Canon MX700 Office All-In-One InkJet Printer Logo
229 people viewed this question
old marine
old marine
