Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
I need to know were the seal gose on the bearing in front or behind the bearing
  • david1981s Feb 17, 2009
    thanks i will try it
  • david1981s Feb 20, 2009
    washing machine is fixed now thanks for your help
  • 121 Answers
First go seal and then You put a bearings,if seal is rubber ring with spring inside.
Posted on Feb 17, 2009
When the washer is spinning it is very loud.
you need to replance the drum bearings and water lip-seal behind the inner drum,it requires you to completely dis-assemble the machinesfront cover,then remove pulley from drum in rear,drum boot seal,then knockout bearings and seal and replace these then re-assemble the machine in reverse order
Jul 03, 2011 | Maytag Neptune MAH5500B Front Load Washer
Water leaking from bearing at back of drum
you better get at this soon,the lip-seal is gone from the outer tub and now water has penetrated the bearings behind this lip-seal,the longer you wait the harder it will be to remove these bearings and if its a plastic outer tub you can destroy this tub when removing the old bearings,the inner tub needs to be removed,the rear access needs to be open the motor pulley removed,the c-clip that secures the outer bearing needs removing then the inner tub can come out the front to access these bearings for replacement
Mar 24, 2011 | Indesit W 123 Front Load Washer
When my washer gose into its highest spin cycle there's a loud noise from the washer
Might be the rear bearing. The bearing and seal come as the rear tub assembly and is quite expensive as it is a two hour repair .
Mar 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Rear axle bearing, need to know if tthe bearing goes first and the seal after, grand cherokee 1994
Most times the bearing fails first but a seal can fail without the bearing being bad. If you see any flaked metal in the lube behind the seal when you remove it, you can bet the bearing is failing. If you already know the bearing is bad, you know you can't get it out without damaging the seal so it really does not matter if it was good or bad since you will need to replace both..
Since the axle needs to be removed to do either job, most times it's wise to replace both the bearing and seal together so you don't need to do it over in a few weeks.
Sep 12, 2010 | 1994 Jeep Grand Cherokee
How to replace bearings in hotpoint washing machine. Has anuone got a plan view of what I need to do.
Hello,It's fairly straight forward,not easy though.The facial comes off(take the dispenser out and remove the four screws), front of the machine comes off (3 screws at the bottom and 3 behind the facial,the outer tub front comes off.)The pulley on the rear comes off,the inner drum can be knocked through.This gives you access to the bearings and bearing seal,not the easiest to get out.A lot of the time the outer race is left behind from the front bearing and it's a nightmare to get out.Hotpoint use a special bearing tool,get yourself a spider and bearing kit as well as a new tub seal.
Thanks
May 30, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Bad bearing
if the bearings are rusted or seized u need to change main seal near bearings. was it noisy b4 you looked at bearings?could be broken spider that holds bowl.please reply if u need more help
Mar 31, 2010 | LG WM1814CW Front Load Washer
How to change my front differential seal and bearing ? passenger side. I bought a new wheel bearing because of a humming sound on passenger side and doing so saw leaking seal and maybe the humming was...
That will be a Huge job. The whole front diff must come out of the car and the case will need to be taken apart to even gain acess to the carrier side bearings.
The hub bearing is where the wheel bolts up is that maybe what you are talking about?
Also the axle seal isn't that bad to do you need to remove the cv shaft then it's just a simple remove the seal and install the new one.
But all of these jobs will be big ones.
Oct 13, 2009 | 1999 GMC Jimmy
Right front bearings need lube
Hi if you are refering to the hub bearing it can not be lubed it is a sealed bearing it will have to be replaced
May 04, 2009 | 2002 Buick Park Avenue
1985 Porsche 944 oil leak from front bottom of engine coming through what looks like a rounded seal its located at bottom front behind the belts.Anyone know what this problem is and what needs replaced or...
YES THIS IS THE FRONT MAIN BEARING SEAL, IF YOU HAVEN'T DONE THIS BEFORE I SUGGUST YOU TAKE IT TO A DEAL.. THEY CAN BE TRICKY..PROBLAY A COSTLY FIX.. GOOD LUCK KEITH..
Mar 12, 2009 | 1985 Porsche 944
Bearing. replacement ,Aquarius wma30s.
This one comes out through the front.Remove screws behind soap drawer and take off control panel then take out screws at top and bottom of front panel. take seal off door then lift front to remove. the rest you obviously know.
thanks for using Fixya
Dec 15, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
