Question about Pioneer VSX-516-K
Please ensure my
How can I get protection from overload model VSX-516?
amplifier is a very good but the protection il break.
    Genius:
  • Pioneer Master
  • 1,550 Answers
The audio amplifier IC of your device are fried
Posted on Feb 17, 2009
Pioneer amplifier vsx-d512 overload message
This indicates the audio output stage in the receiver is loading down and triggering the overload protection circuit to kick in. Check the speaker wires for shorts, if okay! you will need a professional to assess the cost for repair.
Mar 31, 2012 | Pioneer Audio Players & Recorders
Pioneer vsx 405 overloading whenever it turns on I checked the speaker wires and they are all OK.
vsx405 came error dc protection chacked all power transistors c2500 ,a1948 all ok i was disconnect dc detector wire then ok after few minutes one pair burned with c945100 ohms resistors that time not fix heat sink then all replaced power on error overload with speaker and without speakers also coming error disconnect ol wire no chang pease help any expert amplifiers thanks
Oct 27, 2011 | Pioneer VSX-405 Receiver
My amplifier when i put it at -50 and more it write overload .....pionner vsx-d511
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Apr 27, 2011 | Pioneer VSX-D511 Receiver
Hello, Problem is that after a few seconds the display shows "overload. " integrated circuits seem to be good, and I say this because I measured the voltage on each output amplifiers, and I have...
ALL the IC's are ok?
You'd measure 0 vdc if it was turned off, too, so that doesn't prove much.
Generally speaking, an amp protects itself from heat, shorts and overloads. Check for loose speaker connections.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Feb 01, 2011 | Pioneer VSX-517
VSX-859 RDS turns off
This is pretty close to the same Operating Manual.
http://www.retrevo.com/s/Pioneer-VSX-D909S-Receivers-review-manual/id/385ci954/t/1-2/
This is the service manual, for what it's worth.
http://www.kallhovde.com/pioneer/tricomp/Audio/VSX/VSX-859_RRV2378.pdf
Jan 29, 2011 | Audio Players & Recorders
My pioneer vsx-816 sshows overload then shuts down,it happends when the volume is around 42 i have wharfedale speakers
Jan 25, 2011 | Pioneer VSX-817-S
Pioneer VSX D710S, I hook everything up and turn the unit on, after about 5-10 seconds it flashes POWER OFF and shuts down.
I wouldn't hold my breath waiting for free detailed circuitry.
A precise make and model might yield more-specific answer.
Jan 24, 2011 | Pioneer VSX-D710S Receiver
I just bought a VSX-820 and it seems to shut down automatically as soon as turn the volume up
Make sure the speaker wires are tight.
http://www.retrevo.com/support/Pioneer-VSX-820-K-Receivers-manual/id/23653ag912/t/2/
Jan 17, 2011 | Pioneer VSX-1016 Receiver
Power overload
That is a good thing, your receiver is going into "protect mode" that means the receiver is shutting down to keep from damaging delicate internal circuitry, it is sensing a speaker bottoming out or some other electrical "short" that could be damaging!
Also could be from over driveing the amp and then it starts to overheat thus going into "protect mode".
If your speakers are "clipping or distorting" turn it down, you are going to ruin your amp. Good luck !
Jan 06, 2010 | Pioneer VSX-516-K
Pioneer vsx-516 6.1 channels
Check the speakers one by one maybe there is one bad or almost damaged
Jun 06, 2009 | Pioneer VSX-515 Receiver
Pioneer VSX-516-K Logo
179 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Dennis McCollum
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
