Question about Denon AVR-1507 Receiver
No bass from speakers
I have a AVR 1507 denon home theater system and no bass is coming out from the any of the 5 speaker system
  • 44 Answers
Go in to your settings an adjust the bass volume
Posted on Feb 17, 2009
Denon avr 1507.recently replaced with new set of speakers.sound got dropped.keeping full volume only i can able to hear something.
Are you using normal impedance speakers? If it worked correctly before, and even better if you can connect the old speakers back to verify the receiver works correctly, would give you a clue.
If the new speakers are a difficult load (below 4 ohms) it may overload the amplifier and it will shutdown to protect itself. You need to provide more info to access correctly.
Removing all speakers and using a headset will also validate the operation of the receiver.
Good luck.
Jan 30, 2015 | Denon AVR-1507 Receiver
How do you connect denon avr 1507 to pc? hav used rca but does not register on pc
you should be able to use a rca to mini-plug cable and hook up to the audio out or headphone jack on your pc
Jan 08, 2014 | Denon AVR-1507 Receiver
How to connect denon AVR 1513+Bose Acoustimass 5
Plug the speaker wire from the speakers themselves directy to the receiver or you can plug them into the acoutimass module and the module into the receiver using speaker wire.12_16_2013_3_46_09_pm.gif
Feb 19, 2013 | Denon Avr-1513 5.1 Channel 3d Pass Through...
Using Denon AVR 2803 as an FM receiver
• Insure that the speaker system is working.
try it on other receiver.
• Check to see if there are headphones connected.
• Check if tuned is lit
Aug 12, 2012 | Audio Players & Recorders
I have Denon AVR-2310...but lost operating manual ! In audio set up, more specifically speaker configuration, a choice is given between " FTE", and "FTE +main". What is the...
The manual... http://www.retrevo.com/support/Denon-AVR-2310CI-Receivers-manual/id/23452bh638/t/2/
I'm pretty sure you mean "LFE + Main".
You need to identify the speakers to the receiver as Large or Small regarding their bass-handling capacity more than their actual size.
"LFE" removes the possibly overloading bass in a given speaker channel containing 'small' speakers and sends it to the subwoofer.
"LFE + Main" is sort of explained on page 29 "Bass Setting". The intent of LFE+Main is to task your subwoofer with the bass that ALSO exists on all other speaker channels regardless of their ability to handle it all by themselves. As you can imagine, this might make the subwoofer respond to sonic events that are actually supposed to be directional from, say, the rear channel(s). In that case the event might seem to come from wherever the sub is located instead of the intended direction; or at the very least it might seem to come from both places which is probably not what the sound engineers intended when they recorded the piece.
Having full-range speakers 360-degrees around PLUS a subwoofer, I don't subscribe to the 'bass-is-non-directional' school of thought. If you've ever felt the concussion from and subconsciously glanced toward one of the speakers after, say, a huge explosion, the system is working.
Sep 03, 2011 | Denon Audio Players & Recorders
I have a denon avr-4802 receiver. I am looking to purchase new speakers for this system, but don't want to put too much into the speakers. Will the speakers from a denon s-302 work on this receiver? ...
Register and download the manuals for free at retrevo.com
http://www.retrevo.com/support/Denon-S-302-Home-Theater-Systems-manual/id/7046dj484/t/2/
http://www.retrevo.com/support/Denon-AVR-4802-Receivers-manual/id/363ag815/t/2/
Page 10. The S-302 uses a proprietary D-Sub25 system cable to the DSW-S302 subwoofer. Don't know if or why it has more than 2 active conductors. The other speakers have removable cable ends so they might work just fine.
Apr 24, 2011 | Denon AVR-4802 Receiver
Denon AVR-1507 speakers don'twork is there something I can reset
Yup, don't guess, read. Lots of things to set.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Denon-AVR-1507-Receivers-manual/id/696ci071/t/2/
Mar 14, 2011 | Denon AVR-1507 Receiver
The left channel on my denon avr-1507 no longer works. The speaker tests out fine. Is there a fuse that can be swapped for this or some other easy fix?
there are no speakers fuses on this model it only shows relays so your probable couse is your left channel went bad specially if you like to play it loud and for long periods of time ( I recomend that you have it repaired by a profesional ) good lock ,, I have the service manual in case you need it
Dec 16, 2009 | Denon AVR-1507 Receiver
I am getting static out of all speakers in my Denon AVR-682 Home Theater system even at low volume. Connections and speakers are all good. Where do I start to look internally for a fix?
Static could mean a few things.
Magnets on or near (tube TV's) the system could disrupt the signal.
Try plugging the speakers in one at a time with music going to the AUX in. Run through all your settings to make sure that nothing is abnormal.
If it's plugged into a powerstrip, try plugging it into your wall outlet.
201-762-6500 is their main number.
Nov 17, 2009 | Denon AVR-682 Receiver
No sound/test tone front front right channel
1-make a reset to your system.2-repeat your speaker setup.3-confirm that you assign your sysem for 5 chanell surround system.-4-change the cables between left and right front speakers if the trouble go to left channel you will have a problem in receiver itself-if the problem exict you will have a problem in speaker itself(cable or speaker)
Sep 30, 2008 | Audio Players & Recorders
Denon AVR-1507 Receiver Logo
282 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Dennis McCollum
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
