Question about Daewoo KOR-630A Microwave Oven
Daewoo over the range microwave model KOT-21OUB just stopped working for no apparent reason. Lights and fans still work. Not heating food. Worked for one dish then the next nothing.
  • 52 Answers
How old is the machine, microwave ovens have a tendancy to do the ridiculous for no possible reason. a check of the main power fuse within the unit might help. it is a large fuse 10A> that supplies the transformers
Posted on Feb 21, 2009
I have a GE Spacemaker Over-The-Range Microwave Model #JVM1533WD002 that has worked perfectly for 10 years. Now everything still works, except it doesn't heat the food. Where is the fuse located and how...
A common symptom of a failed magnetron is a failure to heat with everything else (magnetron fan, stirrer, timer, etc.) working fine. Check the GE manufacture date for the unit on its nameplate to determine the age of the magnetron. For GE models of the past, magnetrons had a 10 year parts replacement warranty. Magnetrons can be expensive, so you need to weigh all your options, i.e., repair versus replacement, before you commit to one solution.
Oct 04, 2013 | GE Spacemaker Over-the-Range Microwave
Model "KOT-152UW" The
well inside the unit check for any burn fuses on the power supply area, and into the control board. fuse basically the one will tripped if power surged occurred..
Jun 27, 2008 | Microwave Ovens
Manual
my Daewoo microwave over heats on the right hand side of the external casein wen in use model number is kor6n9rr is there any thing majorly wrong please get bk to me on my email which is bridgetyork @.co.uk
Jul 04, 2013 | Daewoo KOR6N9RR Microwave Oven
Hi. I want to replace my Daewoo KOT 210UW over-the-range microwave. I need to know the size of the hood opening. How do I find this information?
All over the range microwaves are 30 inches. All the ducting is the same also. So you can replase with anyone you would like.
Dec 28, 2009 | Daewoo Microwave Ovens
Ewave OTR Microwave Oven, Model KOT-153UW. Light
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or no bright, too. Sometimes this will similarly affect the exhaust fan operation or inside light, too.Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Jul 13, 2009 | Daewoo Microwave Ovens
My GE spacemaker microwave doesn't heat up foods. There is a slight bit of heat generated but not much. All timers, lights, etc. work normal. It is a GE model jvm1440. It is about 3 years old. The problem...
IT COULD BE A NUMBER OF THINGS RANGING FROM DIODES TO CAPACITORS TO YOUR MAGNATRON OR THERMOSTAST OR TRANSFORMERS. IT'S DIFFICULT TO DIAGNOSE WITHOUT SEEING THIS MICROWAVE. YOU MAY BE BETTER OFF GETTING YOURSELF A DIFFERENT ONE.
Apr 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Daewoo MT1510B problem
Chances are your magnetron is overheating, activating the magnetron thermostat, which resets and restores power when it cools.
Your manual may call for you to put a paper plate under the popcorn bag to heat better and to protect the turntable. (And always place the food slightly off-center on the turntable, for the same reasons!)
You should first confirm that the outlet reads about 110-120 volts AC and that the microwave is on its own breaker. If a microwave shares a breaker with another high current device (or even lights) it can affect operation.
Then be sure the microwave's internal cooling fan is running.
If this is an over the range model, it will also have a exhaust hood vent fan which you can turn on and off at will, but this is not the fan I'm talking about.
The internal cooling fan should be on whenever the oven is cooking. If not, the magnetron can overheat and eventually be destroyed.
The next issue is how long you've had the oven.
If it's within the 30-day dealer exchange period, I'd take it back for a new one pronto.
If it's within the full warrranty period (usually 1 year) Daewoo's service center should fix it free.
You can visit Daewoo online or call them at 1-800-323-9668 or 1-800-553-4355 to find parts or find your nearest authorized service center to have them do the work.
Oct 07, 2008 | Daewoo KOR-6115 Microwave Oven
The handle on my daewoo microwve over the range model#KOT-210UW broke off and was looking for a new one - can you help - Its about 14 years old?
I would contact either Magic Chef or Daewoo for a new part, if it is still available after so long.
I would try these numbers, plus any they might recommend:
Daewoo
877-393-2725
800-553-4355
800-323-9668
Magic Chef
888-775-0202
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 19, 2008 | Microwave Ovens
Kenmore microwave
Since it's under warranty, they will replace or repair it at their choice, and if they replace it, it will be the same model or a "like model".
I'd ask them about it.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 04, 2008 | Kenmore 63663 Microwave Oven
Daewoo KOR-630A Microwave Oven Logo
817 people viewed this question
Top Daewoo Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Daewoo Microwave Oven Expert? Answer questions, earn points and help others
