Question about NetGear RangeMax WPN824 Wireless Router (WPN824NAR)
Router cable problem
Have recently bought a rangemax wireless router, followed instructions until we had to insert ethernet cable from tower into router. we where unable to do this as the cable from the tower is a USB not an ethernet connection, is it possible to replace cable or do i have to replace modem
  • Carl Navarro
    Carl Navarro May 11, 2010
    I'd put a network card in the tower. Probably less than $20 gets you a PCI network card.
  • 854 Answers
Replace the USB cable to ethernet cable follow this instruction below
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Posted on Jul 08, 2009
What would be the best ethernet cable to connect my dual band 5ghz wireless n600 router
What do you wan to connect?
This is a router so it should have internet connectivity and is wireless so you should be able to connect it using wireless.
If you want wired connection you can use any cat5 cable.
Sep 03, 2012 | NetGear RangeMax Dual-Band Wireless-N...
How do I connect to my computer with AT & T DSL connection? I only see one ethernet port on back of computer tower.
If you just bought the router, you will need to insert the router between your computer and your ATT DSL Modem. The cable from the wall goes into the modem (should already be that way) then the Ethernet cable from the modem should now go to the source of your Linksys Router. then use one of the ethernet ports from your router into the ethernet port on the back of your computer tower.
Use the documentation that came with the Linksys for more information on setting it up.
Good Luck
May 11, 2011 | Linksys Wireless-G WRT54GS Router...
I8 only have 1 ethernet commector and need 2 had I know this i wouldn't have bought it in thr git=rst place!!!
You can add more ethernet ports by purchasing a 4 port hub or 8 port hub.
Connect a LAN cable from the Netgear wireless router to one of the ports on the hub and then connect the other computers to the ports on the hub.
Sep 03, 2010 | NetGear RangeMax NEXT WNR834B Wireless...
How do i connect my netgear rangemax wireless router
You should have a manual/setup guide.
BUT, the basics of setting a wireless router are.
Connect an ethernet cable from your MODEM to the WAN port on the rear of the ROUTER.
Connect an ethernet cable from one of the LAN ports (usually 4) to your computer.
You now log on to your router via your web browser, set your wireless security (using WPA2) choose your password.
Save and exit from the router setup, disconnect the ethernet cable from your computer to the router and try and connect wirelessly
Your support page is here, choose which version of the router you have and download your manual
http://kb.netgear.com/app/products/family/a_id/1299
Aug 11, 2010 | NetGear RangeMax WPN824 Router
How can I change my router in my computer from unsecured condition to secured?
How to secure the wireless network
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Click Here for step by step instructions
Jul 01, 2010 | NetGear RangeMax NEXT WNR834B Wireless...
Bought this netgear rangemax wireless router and don't know where the wires and stuf*** hook up to.the yellow ethernet wire on the back of router where does that go on the back of my computer terminal of...
Take the ethernet cable which is going from your Warner cable modem to your computer, and run it from your cable modem to the input connection of your router. Then take a second ethernet cable and run it from the router (ports 1, 2,3 or 4) to your computer. Log into your router's setup page (see your instruction manual), and set up all the passwords and wireless settings. Please read the instructions for specifics of your particular router.
Jun 26, 2010 | NetGear RangeMax WPN824 Wireless Router
Connecting a router to a gateway
Sure, you just need to change the ip address of the Rangemax. Netgear usually uses 192.168.0.1 for their router ip addresses. Plug the ethernet cable from your PC into the Rangemax. Open a web browser and put 192.168.0.1 into the address bar. You should reach the home page of the Rangemax. Change it's ip address to 192.168.0.2 and save.
Run an ethernet cable from one of the four ports in your Netgear gateway to the internet in port on your Rangemax and all should be well.
Jan 15, 2009 | NetGear RangeMax WPN824 Wireless Kit
Can connect through Ethernet but not through Wireless
what is the operating system of your computer and what is the wireless card that it is using?
Jul 26, 2008 | NetGear RangeMax WPN824 Wireless Router...
Wireless router
Have you tried inserting the included cd into your drive and follow the instructions in the SmartWizard yet?
Sep 16, 2007 | NetGear RangeMAX 240 WPNT834 Wireless...
NetGear RangeMax  WPN824 Wireless Router (WPN824NAR) Logo
165 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
