Question about Sharp FO DC500 Plain Paper Laser Fax
We have a Sharp FO DC500 experiencing paper jams
The paper jams through the fuser. We have had to use long-nosed pliers to remove the paper stuck in the paper path. Do we need a new fuser, or do we need to replace rollers?
    Genius:
  • 2,120 Answers
New fuser.
Posted on Feb 17, 2009
Need manuel
just try this link
http://esupport.sharp-cee.com/html/om/index.php?StartRec=0&ListLimit=10&Lang=%&TemplateLang=en&ProdLine=36&SortOrder=DESC&OrderBy=Title&SearchString=fo%20dc%20550
Apr 21, 2011 | Sharp FO DC500 Plain Paper Laser Fax
I have a sharp FO DC-500 that is broken. Is there anyway I can save the existing faxes ?
You will not be able to print out these fax's until the machine is fixed. There is no way to transfer them to another machine, but they will still be there after the repair is done, provided the tech doesn't reset your memory. Which hopefully, he won't since he has no reason to do so.
Dec 30, 2009 | Sharp FO DC500 Plain Paper Laser Fax
Is there a way to change the Baud rate on a Sharp FO-DC500? My phone company is telling me it needs to be @ 3200-3300?
Your phone company is lying to you.
Fax machines are ANALOG devices and will not work reliably on a DIGITAL phone line.
Nov 10, 2009 | Sharp FO DC500 Plain Paper Laser Fax
Black Vertical Lines
This can be caused by a damaged fuser or drum try to change the cartridge and if that does not resolved the issue then its the fuser
Mar 27, 2009 | Sharp FO DC500 Plain Paper Laser Fax
PAPER JAM
try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Mar 19, 2009 | Sharp FO DC500 Plain Paper Laser Fax
Sharp Copier AR-C270 Code Problem
jam in the fuser unit, try simulation 14
and/ or possible bad sensor switch actuating as tho paper is stuck in the fuser. check that exit switch is not stuck open or bad. if jam elsewhere , fuser will not allow operation untill jam somwhere is removed.
Jan 30, 2008 | Sharp AR-160 Copier
Paper Jam
Try putting a piece of tape or something sticky on the eraser end of a pencil and try to work out the paper. Sometimes, you can use needle nose pliers or other long nose pliers to grab the paper and pull it out.
Dec 13, 2007 | HP Officejet Pro L7680 All-In-One Printer
Brother 4100e paper jam
Can be tricky people usally damage the fuser rollers removing this jam with pliers/tweezers, it has concertined and stuck after fuser rollers and before exit rollers it will be stuck on the switch best bet is to dismantle properly and remove fuser then dismantle fuser and remove jam, another thing to be concerned about is why did it, three seneraros, Damp paper going threw fuser dries and crincles(use fresh paper from sealed packet), fuser is worn(have fuser replaced), just a bad bit of paper (just have fuser jam removed. Fusrr runs on 240v, covers break easy
Oct 15, 2007 | Brother IntelliFAX 1270E Plain Paper Fax
Paper Jam Message
Where is it saying the paper jam is located? Do you have a service code? It sounds as if either a paper pass switch is stuck in the down position (meaning it thinks there's a piece of paper there), or you may have a sheet of paper stuck in the fuser or behind a guide plate. Check on these and let me know!
Apr 10, 2007 | Sharp AL-1655CS Laser Printer
Sharp FO DC500 Plain Paper Laser Fax Logo
129 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
