Question about Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool dishwasher float 'assembly' model-DU810SWPQ2
The connector nut attached to the float dropped back down into the long tube at the bottom of the dishwasher when I was trying to see why the water wouldn't drain. The small tip at the bottom of the float looked a tiny bit 'chewed up' so I ordered a new float and it looks exactly like the old one. Obviously the float is not the problem.
When I pull out the dishwasher to retrieve the part(connector nut?) that fell---what exactly am I looking for? How does the rest of the assembly attach to the bottom of the float? The whirlpool customer service seemed clueless when I ordered the part the first time.
  • gatorgal71 Apr 05, 2009
    The float won't float
  • 117 Answers
Enter your model number into a site like partselect.com to get a parts diagram for your dishwasher so that you can see what the part looks like. The float just extends through the base to close a micro switch so the dishwasher shuts off the inlet water valve.
http://tclaundryrepair.com/
Posted on Feb 20, 2009
Wan't take on water after first rinse
see this steps and fix it. God bless you
Water Inlet Valve
The dishwasher has an electrical water valve called a water inlet valve. If the dishwasher won't fill with water, the water inlet valve might be defective. These valves are not repairable and will have to be replaced.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Float
The float assembly is normally inside the dishwasher near the door on the floor of the dishwasher. If something gets stuck underneath it and holds the float assembly up, the dishwasher won't fill with water. If the float assembly moves freely up and down, the float switch might be defective.
Float Switch
The float switch is actuated by the float assembly. It is a protection device designed to prevent the dishwasher from overfilling. If the dishwasher won't fill with water, it may be because this float switch is defective or stuck.
Water Supply Problem
The dishwasher is connected to the hot water supply from the house. Check to be sure the household water supply valve is turned on. Over time, calcium deposits can build up in the water supply valve or in the small filter screen inside the water inlet valve. The water supply line may need to be removed from the water inlet valve of the dishwasher, then run some water into a bucket to see if there is enough pressure. Be certain to turn off the water before working on the water line.
Jul 30, 2013 | Whirlpool 24 in. DU1055XTPS Stainless...
The washer does not appear to accept the rinse agent. The dishes come out with a white film on them.
Hi
If the water inlet valve is fine and it fills with water then the issue seems to be with the float switch assembly that is bad and should be replaced. Float assembly is found inside the dishwasher's tub, on the bottom. The water that fills the dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with dishwasher's filling and/or draining ability. Use voltmeter to test the switch. Set the device to the ohms setting x 1. Take each probe and touch them to one switch terminal each. This should produce a reading of either zero or infinity. Continue to touch the probes to the terminals, and press down on the switch's button. The reading should change to the opposite extreme. If the switch fails either of these tests, you should replace it. Hope this helps...please post back for further assistance.
Daniel
Aug 27, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
My dishes are not clean in my whirlpool gold quite partner III. my model #gu2275xtvy0
Hi
Daniel
Aug 05, 2011 | Whirlpool Dishwashers
My Whirlpool dishwasher leaves a white coating on all the dishes and glasses. Help. It also leaves this coating that is chalky to the touch on everything else pots pans etc. I have tried different cycles...
Hi
If its brand new then its better to use warranty however, if you bought it from someone else then check if the water inlet valve is fine and it fills with water then the issue seems to be with the float switch assembly that is bad and should be replaced. Float assembly is found inside the dishwasher's tub, on the bottom. The water that fills the dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with dishwasher's filling and/or draining ability. Use voltmeter to test the switch. Set the device to the ohms setting x 1. Take each probe and touch them to one switch terminal each. This should produce a reading of either zero or infinity. Continue to touch the probes to the terminals, and press down on the switch's button. The reading should change to the opposite extreme. If the switch fails either of these tests, you should replace it. Hope this helps...please post back for further assistance.
Daniel
Jul 25, 2011 | Whirlpool DU1055XTV 24 in Builtin...
Freestanding model ADP7740, 33" tall.
Hi
Daniel
Jun 19, 2011 | Whirlpool Dishwashers
The pump makes a noise but no water
First, the obviouis, make sure the water is turned on under the sink. Check for kinks in the fill hose. It may be the float assembly or float switch.
Check the float to make sure it moves freely up and down, and it should click when it moves. Remove float and clean around the float tube-you may need to do this from below, through the access panel. Use white vinegar to scrub the float and shaft assembly. Turn on the dishwasher to see if this fixed the problem.
If not, it may be the float switch. If you are handy with electrical repairs, turn off the power to the dishwasher, pull the dishwasher from the wall and remove the back. Remove the wires from the terminals on the float switch-use masking tape to identify to identify terminals,noteing which belongs where.Remove old switch and replace with the new float switch. You will need the serial number, model number and make of your dishwasher to order the new float.
Sep 22, 2010 | Dishwashers
Westinghouse 904 water starts overflowing after prewash and at wash it does not stop the water i had to turn tap off. Also it does not open detergent dispenser when Wash led is lit, it was working fine...
Well first of all you can check the float switch, A float for use in a dishwasher to control an externally mounted overflow switch in response to a potential overflow condition existing within the dishwasher tub. The float is loosely mounted on a vertical guide tube on the bottom of the tub and comprises an inverted cup-shaped member having internal partitions to define a plurality of separate chambers, a post-portion telescopically received over the guide-tube, and a rod extending through the guide-tube to abut the switch. Certain of the chambers provide buoyancy to the float while others act in the manner of a dash-pot to stabilize the vertical fluctuations of the float. The post-portion also defines an opening through the wall thereof to prevent a flow path from being maintained in the space between the guide-tube and the post-portion by a syphon effect. Please follow the below steps to clean the float switch -
1. Open the dishwasher door and locate the float switch. It should be a cylinder-shaped piece of plastic and may be set to one side along the front of the cabinet or near the sprayer head in the middle of the machine.
2. Check the float to make sure it moves freely up and down on its shaft. (You may have to unscrew and remove a protective cap to get to the float.) If the float sticks, you'll need to clean away any debris or mineral deposits that are causing it to jam.
3. Pull the float off the shaft, then clean the inside of the float with a bottle brush. Clean the shaft with a scrub brush.
4. Reinstall the float and check that it moves smoothly.
5. Set the dishwasher to fill, and check to see if it overflows. If it still malfunctions, you need to replace the float switch.
If further you have the same problem then you need to change the float switch, please follow the below steps to change float switch -
1. Turn off power to the dishwasher by unplugging it or turning off the circuit breaker.
2. Remove the service panel that runs along the bottom front edge of the dishwasher. If it is screwed to the dishwasher, remove the screws with a screwdriver. If the panel hangs on hooks, pull the panel out and swing it up to get it off the hooks.
3. Locate the float switch. Wrap each wire with masking tape and label each so you can reinstall them correctly on the new switch. Then remove the wires with needle-nose pliers.
4. Remove the old switch, using a screwdriver or a nut driver and socket to loosen the fasteners.
5. Take the switch to an appliance store and purchase an exact replacement.
6. Install the new switch and attach the wires.
7. Replace the service panel, turn on the power and test the machine.
For detergent cup - The detergent cup itself can become clogged with old dried detergent that prevents it from opening. Sometimes just cleaning the cup takes care of the problem. If not, you probably need to replace the entire cup assembly, please check this first.
Please post comment if you need more information or help........
Good Luck!!
Thanks
Jan 08, 2010 | Westinghouse 24 in. MDB421 RF Built-in...
My dishwasher keeps adding water and overflows
If the water lifts the float all the way up or the float is submerged, the water level is too high. Overfilling is likely a problem with the float or float switch. The float is located inside the dishwasher in the tub area. As water enters the tub, the float device will rise. When the float rises to a certain level it triggers the float switch, which in turn, turns off the water flow. In some dishwashers, the float switch is only used to prevent overfilling and the amount of water is regulated by the timer.
Before testing the float assembly, unplug the dishwasher or shut off the power at the fuse box or breaker panel to avoid an electrical shock hazard.
To inspect the float assembly, open the dishwasher and remove the bottom rack. Remove the float cover (if any; it can be identified by the fact that the cover does not move up and down). The cover may snap in place or it may be fastened in place with a screw.
Lift and drop the float several times. It should move freely. If the float sticks, it may prevent the dishwasher from filling or draining properly. Remove the float and look for obstructions that may interfere with its free movement. The float usually snaps in place. If it does not come off with a small force, it may have to be disconnected from the float switch first.
You will need to Replace the float and float cover, If you found no obstructions and the problem persists, test the float switch.
TESTING PROCEDURE
To access the float switch remove the lower panel located beneath the door. The panel is usually held in place with two screws either above or below the panel. It may be necessary to first open the door to the dishwasher to reach the screws over the panel, then close the door to remove the panel.
Note the location of the float in the dishwasher's tub and you will find the float switch beneath it in the access area. The switch has two wires connected to it. Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals. You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
Use a multimeter to test for continuity. Set the multimeter to the ohms setting X1. Touch one probe to each terminal. You should get a reading of either zero or infinity. With the probes still in place, depress the button or lever on the switch and the reading should change to the opposite extreme.
If the switch fails either test, it should be replaced.
NOTE_ If the float, and float switch check out ok, and there are no issues here, the culprit will be a faulty water inlet valve. replace the valve in this case.
Nov 23, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool model #GD25DIXH02. The front water dispenser tube cracked at the retaining screw. How do I change the filler tube kit?
Remove the top free door hinge cover and disconnect the plug there . This removes all power to the door . Remove the grill inside the dispensor , and remove the 2 screws at the bottom , holding the dispensor cover on . Lift the cover to remove , and disconnect the receptical , freeing the front . Next , remove the 4 screws holding the white dispensor switch mount , and slide out . Remove the screw holding the water fitting assembly .
Remove the bottom refrig kick plate . Follow the tube about 6 " to a connector , and disconnect the connector . The plastic compression nut , slips off the tubing after disconnecting .
Pull the dispensor tube , up thru the door from the top . Using the new tube with spout , pt number 4388152 . Insert the new tube into the hole from the top , and feed down , thru the door . Re-assemble in reverse .
Oct 26, 2009 | Refrigerators
Upper wash tube assembly came off back of unit. can not reattach.
We had the same problem with our Bosch 4800 and found that the upper wash arm and tube assembly should attach to the bottom of the upper rack (rather than to the back of the dishwasher). The wash arm and tube assembly slides in and out with the upper rack. When the dishwasher door is closed the tube assembly is forced up against the back mounting/water supply.
Nov 30, 2008 | Dishwashers
Whirlpool GU2400XTP Built-in Dishwasher Logo
742 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
