Question about Kenmore 63942 Dryer
Is it possible that the automatic sensor can fail on a dryer.
  • 4 more comments
  • llhess Feb 17, 2009
    The dryer model number is 110.66982500, it is a kenmore elite dryer and it's not very old. It appears the clothes are still damp when I use the auto moisture sensor, but drying by the time setting seems to dry the clothes.
  • llhess Feb 18, 2009
    It appears the clothese are damper than they used to be and I put them in on the more dry cycle. I have cleaned the vent and drum.
  • llhess Feb 19, 2009
    My machine doesn't show minutes on the auto dry feature. It just has the option for more dry to less dry. It appears to be giving off alot of heat in the beginning, it just appears to not dry everyting. I put a load of towels in and one towel still felt damp after the cycle was complete, granted it was the heaviest towel, but I have had sheets come out damp as well.
  • Jim London
    Jim London May 11, 2010
    Hi, Ok Last question, If you are putting the machine on more dry and it shows like 6 minutes, are you coming back 10 minutes later and it still shows 5 or 6 minutes left?
  • Jim London
    Hi, Is it working at all when on the auto moisture setting? This setting will not dry completely, it is supposed to dry to 80% to allow you to chose if you want to iron, air dry, or wrinkle guard. Is it working different than before or are you noticing because of a larger item or a thicker item? Have you cleaned the drum and lint filter or have you noticed moisture or condensation? The reason for all of the questions is the sensor is pretty reliable but there are a lot of factors that will make it seem like this setting is not doing the job, especially if it "partially" works.
  • Jim London
    Hi, what automatic sensor are you referring to? You need to be specific in describing what the problem is. Is it failing to dry? Also give us a make and model to help us determine what automatic features you have.
  • 257 Answers
Hi, Sounds like everything mechanical and electrical is working. The sensors are located on the outbound air ducts. You may be able to improve things significantly by removing the dryer vent where it attaches to the rear (or side) of the machine, and cleaning the tube going into the machine. While you have it removed from the vent, remove the lint trap, use your vacuum crevice tool and clean the trap area. If you have the ability to blow air through the trap area, blow it through the crevice tool so that you are as far beyond the screen area as possible. Be warned that it may blow dust and lint from the vent, covering it with a piece of nylon stocking will catch most of it. The object of this whole exercise is, the exhaust air ducts collect dust and lint which collect moisture from the damp items, the sensor reacts to this so cleaning out as much of it as you can will help. Good Luck to You!
Posted on Feb 19, 2009
  • 130 Answers
Yes, it is not common but it can. i'd check my vent line for a blockage first
Posted on Feb 17, 2009
Roper model red4640yq1 heats in auto mode but not on timed dry
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.htmlGOD IS So GOOD !!!! AND THAT'S WHY MY ADVICE IS FREE
How to Check Dryer Thermistor eHow
Feb 26, 2016 | Roper Dryers
Dryer shuts off after 5 seconds then beeps 3 times
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Apr 03, 2015 | Frigidaire FARE1011MW Affinity High...
Why do the Automatic cycles on my Whirlpool Duet Electric Dryer not always work?
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Jul 30, 2014 | Whirlpool Dryers
Dryer doesnt work on settings
I have repaired (2) gas Maytag dryers that appeared to have timer issues. In both cases, it wasn't the timer, but the temperature sensors. In both cases, I replaced them and the dryers operated A-OK. The sensors signal the timer to advance. One sensor is located just beyond the flame where the gas is burning, the other just before the squirrel cage blower. In addition, there are (2) electrical coils located in front of the gas igniter assembly. If replacing the temperature sensors doesn't fix the issue, then replace the coils.
Apr 06, 2014 | Maytag Dryers
Check engine light Code P1725 for a Toyota echo 2001
That code is related to the automatic transmission, It is indicating that the Turbine Shaft Speed Sensor Circuit has Malfunctioned.
Possible causes
Input shaft speed sensor signal (NT) circuit is open or shorted Input shaft speed sensor is damaged or has failed PCM has failed
Feb 16, 2012 | 2001 Toyota Echo
Overheats
These dryers have a heat sensor that automaticly shuts down the heat when at maximin temperature. Yours has failed and needs to be replaced
These sensors are life savers too when people do not clean the venting tubes. I would replace it very soon for its a fire hazard
Apr 09, 2010 | Whirlpool LER7646E Dryer
I think the moisture sensor is bad in my kenmore he4 electric dryer. It works well on timed dry but does not stay on when using the automatic settings. It is still heating fine, it just stops prematurely...
it is a problem with how you are loading the unit. you must use the same type and weight of clothes or the sensor will think the light items are dry and then shut the unit off.
try to do a load of all towels and see what happens on the automatic cycle. if it does well then you just need to sort your clothes better.
the sensor is just 2 metal strips and will never fail.
Mar 13, 2010 | Kenmore Elite HE4 Electric Dryer
Newer Kenmore dryer automatic sensor not working.
I dont understand your problem?
Jan 19, 2009 | Dryers
Automatic dry feature of electric dryerr does not work
chances are you have lint on the sensor look inside the dryer in the front just in side the door you will see three or four silver wires about flush with the front housing wipe the off and try it if this fails contact a local appliance parts store with your model number and they can get the part num for it
good luck
bill
Jan 08, 2009 | GE Dryers
Kenmore 63942 Dryer Logo
189 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De GO PATS
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
