I have cleaned the washer completely with cleaner then by hand.... drum, soap dispenser, seals... everything. but clothes still keep coming out with dirty streeks on them...I dont overload the drum.. cant think of what else to do... nothing else wrong with machine so dont really want to buy another!!!
i had the same problem with marks on the clothes , when i found out later that the water seal on the drum had failed and leaked grease into the drum making the clothes . time 2 change the bearings !!!
Was this helpful?
Yes
No
Popular Solutions for Candy CN146 Front Load Washer
candy activa smart washing machine. starts to wash but after a short while the top two lights start...
(More)
candy activa smart washing machine. starts to wash but after a short while the top two lights start to flash. Can drain when restarted on drain cycle and then will spin if restarted on spin cycle.
changed bearings, put machine back together but machine wont come on now, i think its the wiring,...
(More)
changed bearings, put machine back together but machine wont come on now, i think its the wiring, any ideas. thanks
I have this machine from 2007, never had a problem but now when the machine starts a cycle, just...
(More)
I have this machine from 2007, never had a problem but now when the machine starts a cycle, just after filling water starts to spin twice, some lights flashing, the wash cycle stop. The only cycle that the machine ending is drain only. We have cleaned the filter, have checked all over but the situation does not change.
Hi, my washer stopped before it drained and rinsed so there was water still in the drum. I moved the...
(More)
Hi, my washer stopped before it drained and rinsed so there was water still in the drum. I moved the dial to the end of the programme and then reset it to spin. after a while it did spin. now when I set it to start the wash cycle it stops following the wash, then following the 1st rinse then the second and I have to reset it every time. I have had an engineer out who said it is the heater but I am not convinced as he didn't even touch the washer and charged me a lot of money for the call out.He says the repair will cost a further £100, Any help would be great.
