Question about Sony Grand WEGA KDF-70XBR950 70" Rear Projection HDTV
New lite engine put in my sony kdf70xbr now theres blue tint. can't correct with on screen menu. tv guy says there is no adjustment & to remove front glass.
  • 139 Answers
Dear info248,
A blue tint means that the Blue, or possibly Red, LCD is faulty.
You put in a used engine.
Posted on Mar 06, 2009
I own a Quasar SP-3235 32" TV. It has a slight green tint after 10 years of use. How can I adjust the color screens on this set? Is it a function of the remote like Sony TVs or do I need to remove
I would open it first and look, a lot of those had both the screen and drive controls on the PCB at the end of the picture tube, at least look there first.
You are dead on in looking for the screen controls, if you find one it should only be a tiny adjustment due to age and the Crt changing a bit.
Dec 13, 2012 | Quasar SP-3235 32" TV
I have a sony KDS-R60XBR1. The lamp burned out so I ordered a new one. When I took the old one out, I noticed the area directly in front of the lamp, the first thing the lamp shines into, is a little dirty...
Use a eyeglass cloth or LCD screen cloth. Use NO solvants on it. Just dry cloth. ALSO goto the settings menu and put the tv in HIGH altitude mode. There tv's get too hot and the light engines go out. Green or blue tint. or dots. It also helps the lamp last longer.
Jun 02, 2011 | Sony KDS-R60XBR1 60" Projection HDTV
Sony trinitron FV-32FS120 picture has an orange tint
THERE ARE ADJUSTMENTS TO THE VIDEO DRIVE THAT CAN CORRECT THIS PROBLEM/THEY ARE IN THE SERVICE MENU. WITH THE POWER OFF, PRESS MENU-5-VOL+ POWER THE SET WILL COME ON IN THE SERVICE MODE. STEP THREW THE MENU ITEMS UNTIL YOU GET TO RED/GREEN/BLUE DRIVE THEN ADJ. TO BALANCE THE COLORS WHEN DONE PRESS MUTE TO STORE THEN POWER OFF ON THE FRONT OF THE SET OR IT WONT SAVE.
Dec 27, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Blue tint left side of tv
sounds like you need a new light engine. Sony can probably get you one at no cost if make enough noise, they are aware of problems with their light engines. good luck
Apr 25, 2009 | Sony KDF-50E2000 50" HDTV
Sony Grand Wega 60WF655 TV blue tint/spots
sounds like your optical block lenses has melted due to heat.
( common problem) here is the light engine/optical block number
A-1084-658-A
Mar 18, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
I have a KP-65WV700 and the screen looks a lil to green
OK, I'm the guy that was having the same problem, but had a blue tint to the screen. I also had blue lines running across the screen, and when I followed the steps below that were posted by another user not only did the lines disappear, but the blue haze vanished as well. My tv looks like it's new again, so you may want to try this:
noavatar_s.gif Guest
Rank:nonexpert_s.gif Apprentice
Rating: 0%, 0 votes
I have fixed this several times on my KP 65WV700
As Slinteriors posted if it is a thin curved line you need to adjust the screen control, it's sorta like a brightness for each color, and if one color is too high it will produce a thin curved line.
The best way I have found to get to the controls is by removing the lower grey speaker cover front the front of the TV. There are 6 screws if i remember, 3 on each side. Then it snaps off, seems like its going to break but you have to pop it off pretty good.
Once its loose you have to remove a cardboard like cover plate in the center that will give you access to the small controller board.
Now be very careful while experimenting on which knob controls which colors. Turn them very slow, if you turn to fast you will cause your TV to shut down. If this happens, turn the adjustment back to original spot and turn TV back on and take it slow.
Adjust the correct color until the line just goes away. Its easiest to do this with a black screen.
Nov 18, 2008 | Sony KP-65WV700 65" Rear Projection HDTV
Sony_grand_wega_kf_50we620_television
Could be that the CRT's need to be replaced.
May 19, 2008 | Sony Grand WEGA KF-50WE620 Television
Red Screen
first try going to the menu on the tv and adjusting the red blue and green tint....if not the u need to remove the front pannel and move the the the top left knob on the setting to lower the tint...
Aug 15, 2007 | Hitachi 57S700 57" Rear Projection HDTV
Sony 51inch tv blue screen appears
could be a blu tuibe but also i've seen many bad sony CRT Drive bds(the circuit board connected to the neck of the tube). You won't find really any place cheaper than the next if your a consumer. just try partstore.com Oh, and forget about sony paying for it 4 years is way out of warranty.
Apr 22, 2007 | Sony KP-51HW40 51" Rear Projection...
Faint red lines in a curved arch like pattern
Guys I did this myself real easy. Just don't turn the corresponding screw too far. Only need to adjust it until the lines go away. Do it on a darker screen so the lines are more visible. I did the red 2 years ago and the green 6months before that. The blue lines are coming on my screen now and I've fixed it in 10 minutes. The TV is amazing.
Apr 10, 2007 | Sony KP-51WS500 51" Rear Projection...
Sony Grand WEGA KDF-70XBR950 70" Rear Projection HDTV Logo
137 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
