Question about Panasonic PT-47WX53 47" Rear Projection HDTV
I have a panasonic HDTV 1080i. seeing double images
It just started all of a sudden, all the channels are double images. Is there anything i could do?
  • 1 more comment
  • Anonymous Mar 08, 2009
    all the sudden i also had a double image on all channels
  • Anonymous Apr 04, 2009
    same
    solution plz
  • Anonymous Apr 22, 2009
    I started seeing double images and then suddently the TV does not work. I have a flashing red light with no image.
  • Panasonic Master
  • 3,459 Answers
Your TV most likely has a Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together convergence repair kits for most models.
The kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, etc. Everything you will need to do the repair yourself.
Posted on May 14, 2009
Do my panasonic hdtv 1080i need a converter box in order to work?
None of the newer style TV's need a converter box because all the tv channel tuners use a digital signal. The tv signal in the air is now digital when using a tv antenna.
Sep 13, 2015 | Panasonic Televison & Video
Stuck on 480i with Panasonic HD Plasma
It sounds that a software update is necessary. Contact the service centre for Panasonic, to get the latest software to this model Plasma tv.
Jul 04, 2013 | Panasonic VIERA TC-P55ST50 55 in. 3D...
Panasonic rear projection 52inch cinema vision 1080i hdtv looks 3D with double vision red, blue and green how do I fix
Replace the convergence chips--should be stk-392-110's in the Panasonic.
I have start to finish free instructions for this repair based on the model number----a email address will get them for free.
Jun 06, 2012 | Panasonic Televison & Video
Panasonic HDTV from 2001. 51
I had the same problem and fixed it myself with a kit from www.TvRepairKits.com. Works great now.
Jan 09, 2010 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic hdtv 1080i all of the sudden has double
Go INTO the customer menu and select CONVERGENCE--what you are looking for is will blue or red not move in some direction?
If you find in your case blue OR red is wacked and will not adjust let me know--I can post here start to finish instructions for this repair on this set.....
You only need to be able to know how to solder and get at the chips--you can buy a pair of the chips on Ebay for less than 14 dollars plus shipping.
If you cannot do it yourself--let me know and I will give you options.
I am here to help people--if this information helps you rate this solution--I do this here for free.
SD TECH
Nov 03, 2009 | Panasonic PT-53WX52 53" Rear Projection...
Blury screen on panasonic 1080i hdtv
seeing double and a lot of green on my panisonic hdtv 1080i what do i need to replace?
Aug 23, 2009 | Panasonic Televison & Video
How do I scan the channels on a Panasonic 1080i HDTV? This is for the conveter box hooked up to the DVD/VCR to the Panasonic 1080i HDTV'
The cable to the antenna and another cable from the TV needed to be hooked up and THEN follow the directions that came along with the converter box.
Channel 3/4 and scan., be sure the antenna is strong enough.
There was no need to touch the DVD/VCR box.
Jun 12, 2009 | Panasonic PT-53WX53 53" Rear Projection...
1- I have a Panasonic TV (PT-53TW54)that has a "digital scan rate of 1080i,540P". I'm not sure if that means it has a digital tuner. Do I need a digital converter for this unit? 2- I'm using a...
1. Do I need any additional equipment to watch HDTV broadcasts on my HDTV-compatible TV?
In order to view over-the-air (OTA) HDTV broadcasts, you need to be within the reception area of a TV station broadcasting HDTV signals. Some TVs may require a set-top HDTV tuner and an external antenna to receive the broadcasts. Your cable or satellite provider may also offer HDTV channels as a part of their service, eliminating the need for a separate tuner. Please contact your local service provider to find out what kind of HDTV services they may offer.
2. What is CableCARD and how does it work?
HDTVs with CableCARD slots can accept a small card from your cable provider that allows you to receive standard definition and high definition digital broadcasts without a bulky set-top cable box. Please call your cable company to find out if they offer this service in your area.
btn_top_gold.gif spacer.gif line_gold.gif spacer.gif spacer.gif3. What is HDMI? Is it compatible with DVI?
HDMI, which stands for "High-Definition Multimedia Interface", is the consumer electronic industry's first connection capable of transmitting uncompressed digital audio/video signals. Components featuring HDMI can transmit both digital audio and video over one convenient cable, replacing the tangled mess that resides behind many home theater components. HDMI also offers improved quality over traditional analog connections thanks to all-digital transmission. Digital sources like DVDs and HDTV programming can now be transferred digitally from source to display without analog conversions that can degrade the original signal.
Unlike the HDMI interface, DVI only handles digital video. Through the use of an adapter, a DVI device can be connected to an HDMI device, but only video content can be transmitted. The audio signal would have to be transmitted through other methods such as analog RCA outputs or an optical digital output.
4. What's the difference between 720p and 1080i HDTV broadcasts? Does my CRT projection HDTV support both?
HDTV signals can be broadcast in either 720p and 1080i. It's up to the broadcaster which signal format to use, and both have their benefits. Our CRT projection HDTVs display 1080i signals in their native format. For 720p broadcasts, you can use the settings on your HDTV set-top tuner, cable box, or satellite tuner to convert a 720p signal into a 1080i signal that your TV can display.
btn_top_gold.gif spacer.gif line_gold.gif spacer.gif spacer.gif5. Why do I still see black bars on my widescreen TV when viewing certain widescreen DVDs and HDTV broadcasts?
Your widescreen TV has an aspect ratio of 16:9 (1.78:1), which is the aspect ratio of HDTV. However, movies are filmed at several different aspect ratios, including 2.35:1. Also referred to as "scope", 2.35:1 is a very panoramic aspect ratio that provides a wide field of view in the theater. Scope is much wider than your widescreen TV, so it still requires the use of letterboxing ("black bars") to fit the entire image on screen. Some TVs and DVD players have a zoom function that allows you to blow up the image so it fills the screen, but the sides of the image must be cropped in order to do so.
6. What will 4:3 broadcasts and DVDs look like on a widescreen TV?
There are multiple settings for adjusting the appearance of 4:3 material on Panasonic widescreen TVs. It can be viewed with black bars on the sides, preserving the way it was originally intended to be viewed. Some viewers find the black bars distracting, so they might prefer one of the stretch modes that lets you fill the entire TV screen with the image. One such mode is the JUST (justify) mode, which stretches only the outer portion of the picture while leaving the center untouched.
Oct 21, 2008 | Panasonic Televison & Video
My panasonic HDTV bbl 1080i was purchased about 6 or 7 years ago. The image shows two or three other images from the original image which are florence green and pink. So basically I see a triple image of...
I have a Panasonic PT-47WX53 rear projection TV and the picture was pretty dark for the last year but for game it was OK but know the blue is out of sequence, do I need to change the lamps?
And where to find them?
Jul 26, 2008 | Panasonic Televison & Video
Tv below listed on ebay i'm interested in buying not sure if worth or what repair would be?
Depends on how much do they want for set repair cost verys anywhere from 250 up to 375.00.Set might only need to realine convergence on customer level.
Sep 09, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
1,613 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
