Question about Samsung SYNC SGH-A707 Cellular Phone
Phone not charging unless i hold it in my hand and squeeze the charger. Same thing happens with a new charger
  • Anonymous Feb 18, 2009
    My phone wont charge being held upright ! could this be due to water damage ?
    Guru:
  • 188 Answers
Try to reduce the length of wire of your cell's charger.Cut the wire of your charger and reduce its length.Reconnect both wires the same way they were connected before and please make sure wires wont touch each other.Set your phone at charge and see if its charging,if not then connect the wires again but differently.
If you have the same problem with other chargers too then the problem is with your charging port.You'll have to take your cell to cell phone repairer.
Thank you!
Posted on Dec 03, 2009
CE110 cell phone would not hold a charge. Bought a new battery, thought the problem was solved. But noooooo. After a day or so with the new battery, same thing was happening. Phone will not charge, and...
Since you have try several battery, the problem is not battery problem,the problem could be either of any of this two, it might be a charger problem, i will suggest you try using a similar charger to charge the phone, see if it will charge, if it is not charger problem, then, the problem is the charging port of your phone. The charging port of your phone is bad and will need to be replace. once the charging port is replaced, the problem is solve.
Take care.
Aug 24, 2010 | LG CE110 Cellular Phone
My phone wont charge unless i am holding it at a certain angle with a certain pressure... i got a new charger thinking that was the problem... but it does the same thing. unless i'm holding it, it won't...
its may be your chager point problem after changing charger is not done then you will change your ph charger point i think then the problem will remove
Jul 15, 2010 | Pantech Matrix Cell Phone
Samsung A767 constantly needs charging. Why does
it happened to my fone too but i then i just had to put it into a new plug place...or you need to replace your charger dock thing
Feb 13, 2010 | Samsung Propel A767 Cell Phone
Can't turn on samsung m620
have you ever figured out what happened???
the same thing happened to me over the weekend and it's annoying that there's no information at all about anything.
I can't figure out what's wrong and your description is EXACTLY what happened to me. One moment everything was great - the next it's dead.
Please let me know if you figured it out somehow ??? Thanks
Geni
dyna_bella@hotmail.com
Aug 05, 2009 | Samsung UpStage SPH-m620 Cellular Phone
LG shine wont charge
Zoe-
The charger port is going bad. It happens over time The symptom of this is you have to hold it into place.
The first step is to contact your carrier to see if it is covered under warranty. If it is, great get it replaced.
If not, you have 3 options:
1. you can get the charging port repaired. The cost is about 50 dollars. I recommend Cellulardr.com
2. you can get a new phone. cost ???
3.Youcan get an external battery charger to charger the battery separate fromphone. An extra battery is a good idea as well so you canhave one charging at all times. The best and cheapest place to buy a new charger for yourshine is ebay. They run about 5 dollars shipped. Check out thefollowing link for the selection.
LG Shine Battery Charger
I hope that helps
Jan 31, 2009 | LG Shine CU720 Cellular Phone
Power chord
get a power cord as it would be less expensive because if the connector on your system is faulty you may have to spend a lot of monet
it happen with the power cord that they go gad
so don'y worry about that
Jun 10, 2008 | IBM ThinkPad T43 Notebook
My enV won't hold a charge
You said the new battery worked but wont charge in the phone. You had water damage to the phone before getting the new battery correct?
First remove any Mini S/D card in the phone, power it off and remove the battery. ( only do this if its out of warranty and nothing else works. ) Your need to take the phone apart and get some alcohol wipes and wipe down the circuit board and connectors and anything that may have had water on it, if you see any crude, try to rub it off, there may be water and crude built up on contacts from the water damage that may be shorting the phone. Also check the battery contacts for greas or crud on the contacts. Once you have wiped down everything the alcohole should evaporate and take any moisture with it. Leave it out for a day dis assembled so it can air dry completely.
Put phone back together and hook up the charger and see if it charges. wait to put the memory card back in as in case you screwed anything up, you dont want it to take out your memory card with it.
I have performed this task with many of my friends cell phone that have gone through washing machines or got moisture in it because they take there phones into a steamy shower and moisture ends up shorting it out.
If nothing else works and you want to try it, go for it.
remember theres 6 screws in back and 4 around the mainscreen that are covered with triangular sticky covers, then use a thin knife or something to pry from one of the corners, one it gets started you just have to pop it apart with your fingers. Everything snaps back together easily.
Be carefull on the side with the screens, you dont wanto to pop apart the front screen from the mainscreen as its a pain to keep together when putting it back, also dont get any dust or fingerprints on the screen as they will drive you nuts if you put it all back together and theres a greasy fingerprint under the plastic that protects the screen.
Good luck
Mar 21, 2008 | LG enV VX9900 Cellular Phone
Motorola V3 RAZR won't charge!!!
i think due to over charging your cell s capacitor is gone so it not getting charged...
this repairable by replacing capacitor...
so just visit technician................
Feb 11, 2008 | Motorola Mobility RAZR V3
LG vx8300 phone will not turn on
dunno. try to have it on the charger, and at the same time try to push and hold the power button. try it a couple times. my v180 from motorola did that and it seemed to work.
Sep 18, 2007 | LG VX8300 Cellular Phone
Samsung SYNC SGH-A707 Cellular Phone Logo
331 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
