Question about Dryers
Hoover HNC382T - ? worn/dry bearing
When the above tumble dryer is switched on there is a dreadful squealing noise (heard when drum is rotating one direction only) - sounds like a worn or dry bearing which might just need lubricating. I have removed lots of screws and can see the motor from both front and back but I still can't get to it to make any meaningful assessment of said bearing.
I need an 'exploded' diagram or some advice on how to reach the motor area please. It would also be useful to know which spare part I might need before I strip it down as I'd rather be able to sort this in a oner!
  • d_ashburn Feb 19, 2009
    Are you suggesting that there is a build up of felt from the drying process around the drum? There is a band running around the drum but I assumed that this was a friction material used in the drive process.
  • 547 Answers
The felt around drum
Posted on Feb 18, 2009
  • albert getty
    albert getty Feb 19, 2009
    no the drum sits on felt at the front of the dryer I think there is wear and it needs to be changed
  • albert getty
Beko DRVS6W tumble dryer squeaks when the drum comes to a halt
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
GOD IS GOOD !!!!
May 22, 2015 | Beko DSV64W White Vented Tumble Dryer 6...
What could make a noise when drum tumbles on Fisher Paykel top loading dryer, Model DEGX2?
GOD IS GOOD !!!!
DRYER MAKES NOISES.
The blower:
The bearings:
Sep 30, 2014 | Fisher and Paykel DEGX2 Dryer
I have a creda tcr. 13 tumble dryer that squeals when in use
GOD IS GOOD !!!!
DRYER MAKES NOISES.
The blower:
The bearings:
Sep 28, 2014 | Dryers
How do I fix squealing and scraping noise in my Kenmore gas dryer 110.74812200?
GOD IS GOOD !!!!
DRYER MAKES NOISES.
The blower:
The bearings:
Sep 21, 2014 | Dryers
Have a 6kg hoover tumble dryer making noises when on sounds like something trappped under drum
it sounds like your bearing are gone you can buy a bearing kit its not an easy job but if your a handy man or woman it can be done
Jul 29, 2014 | Hoover VHC391 T-80 Dryer
It makes a noise and wont tumble
you have 2 kind of problem:
1) Noises:
Rollers
worn rollers replace
Idler pulley
worn replace
Glides
worn plastic or nylon replace
Rear drum bearing
worn bearing replace
Blower wheel
clogged, clean it.
2)Not Tumble:
1) Clean the blower fan for clogged
2) Rotate easy the motor manual, otherwise motor defective replace
3)belt worn or defective.
4) door switch, test for open or defecive. see the video.
5_24_2012_1_06_17_pm.gif5_24_2012_1_06_34_pm.gif5_24_2012_1_06_59_pm.gif5_24_2012_1_07_19_pm.gif5_24_2012_1_07_45_pm.gif
May 23, 2012 | GE Profile Wizard DPSE592EAWW Electric...
Tumble dryer is very noisy
i had the same problem.it ended up being the bearing that holds the drum in place.it had worn that bad that the drum was rubbing the bottom of the dryer.the bearing is located on the back of the dryer if the bearing is worn there will be like black dust around the area.this does stain so be carefull
Feb 19, 2010 | Miele Dryers
Hoover Maxi 6 TC50 Tumble Dryer making squealing noise
Have you fixed this problem? I also have a Hoover condenser dryer, only a few months old, and has started to make a squeal/whistle. I'm thinking it might be the front fan needing some WD40, OR too much water vapour around the belt that moves the drum causing the sounds.
If it's the fan, lubricating the shaft and its components should fix the problem, if a wet fan then I'd think maybe fully cleaning the condenser filter, reservoir ect will fix the problem.
The problem seems to go away though "mostly" 15 or so minutes after you start the dryer, so that makes me think ones it gets warm something is expanding to allow more "give" so maybe the belt.
Aug 26, 2009 | Hoover Dryers
Squealing noise
it sounds like your drum guides that go around your drum they may be worn now. or your bearing in the back of your drum
Jun 11, 2009 | Amana DLE330RAW Electric Dryer
Frigidaire LEQ332DSO Squealing Noise
sounds like rear bearing is dry you will need to remove drum to get to it pop clips in top and raise 2 phillips scews 1 in each side remove front remove belt from drum lift drum up in rear and remove ck to make sure plastic bearing is not worn down to metal bracket if it is it will need to be replaced
Jul 07, 2008 | Frigidaire GLER341A Electric Dryer
Dryers Logo
256 people viewed this question
Top Dryers Experts
Richard Roth
Richard Roth
