Question about Sabrent SBT-FWPH (SBTFWPH) Serial Adapter
Using sabrent 5-in-1
Bought a sabrent 5-in-1. Used the usb cable to plug into my laptop. The green light [ide/busy] is on and the red [usb] light is on. My Computer doesn't see the drive. When I plugged it in the first time, my computer found the new hardware and said it was ready to use.
Using Acer Aspire One, Win XP.
I have two drives to test. This is an old one from my old computer. The problem is my new drive [sata drive] from my new computer. I am trying the old one first because if it fails, it won't kill me.
You can check 'Drive Management' via right-clicking 'My Computer' and clicking 'Manage'.
If you can see the drive in 'Drive Management', try changing the drive letter. Sometimes, newly added external hard drives end up having the same drive letter as an existing drive. This will cause 'My Computer' to not recognize the drive. Changing the drive letter can help.
Posted on Mar 31, 2009
Usb port connection
are the devices drivers are installed???
Mar 04, 2008 | Sabrent (USB-2535) (USB2535) IDE...
What happened and what can I do.
You can remove the hard drive from your computer and hook it up to another computer using an adapter that plugs into the USB port of the other computer. I will share a link to Amazon, the are very inexpensive. Amazon com Sabrent USB DSC9 USB 3 0 TO SATA IDE 2 5 3 5 5 25 Inch Hard...
Apr 16, 2017 | Computers & Internet
How do you install a sabrent vga converter?
TV-LCDHR does NOT require a computer. It only needs a working VGA monitor and a Cable TV service.
1. Connect your coaxial TV cable directly to the "Antenna" port on the back of TV-LCDHR. Plug in the power supply. You should now see a red light on TV-LCDHR.
2. Connect your VGA monitor to "VGA-Out" port on the back of TV-LCDHR.
3. Press the "Power" button on the remote to turn it on. The red light on TV-LCDHR should now turn green.
4. Turn on your VGA monitor.
5. Press "Menu" button on the remote. Go to "Search", select "Auto Scan", and choose "Normal Scan".
TV-LCDHR will now scan through all channel frequencies it may find on your Cable TV service. When it's done, use the remote to change channels and adjust volume.
Note: TV-LCDHR has a built-in mono speaker. For optimum sound quality, we recommend using a pair of amplified stereo speakers. Connect them to the "Audio-Out" port on the side of TV-LCDHR.
Aug 17, 2011 | Sabrent TV-PC85 PC to TV Converter Box
I have a Sabrent 2.5" IDE Hard Drive Enclosure --I just bought it. I put my disk into it, but when I try to use it I get "Cannot read--I/O Device Error". I am running this on a Dell Latitude D620 which is...
Did you format the disk using NTFS? Have you loaded the software that came with the drive? Once the software is loaded it will take you thu the steps to set it up properly
Oct 10, 2009 | Sabrent 1 Bay USB 2.0 External Drive Case
My fujitsu laptop recently had a new hard drive installed in it ,but i want to transfer the data i have on the old hard drive that was removed from laptop to my new hard drive. I bought the all in one...
The Coolmax adapter is an USB hard drive adapter that can connect various types hard drives to your computer. This is used for testing and and transferring data to and from hard drives connected to the computer via the computer's USB port.
This Coolmax USB hard disk adapter can connect a 2.5-, 3.5- and 5.25-inch IDE or SATA hard disk to a PC. The black adapter box connects the hard disk, while the secondary power plug/adapter powers the drive. In the case of smaller notebook or SATA disks, the power cable is plugged directly into the adapter (as opposed to straight into the IDE hard disk).
The red USB cable, meanwhile, can be used to power hard disks directly from the host PC's bus via another USB port.
Connect the hard drive to the adapter as detailed above, power up your computer and plug the Coolmax USB cable into the conputer's USB port. The computer will detect and see this as an external drive, most likely as a E drive (the next drive letter that is available). Click on this drive and open to open the folder/s where your data is stored then select the folder/s and/or data and copy them, then open the hard drive on the computer and paste the folder/s and/or files onto the new hard drive.
Sep 29, 2009 | Fujitsu Siemens Computers & Internet
Sabrent USB-AVCPT on a Vista not installing
Try installing the drivers first before plugging in the device.
Jul 25, 2009 | Sabrent USB-AVCPT Video Capture
Sabrent 5in1 USB-DSC5 doesn't recognize 2.5" WD hard drive
I have had a different problem with this product. But, I have read many postings on its problems. It seems that for certain hard drives the jumper should be set for something other than 'master', either CS or no jumper at all. This seems to be true for only certain HD's.
Hope this helps.
Scott Bolton
Mar 18, 2009 | Sabrent (USB-2535) (USB2535) IDE...
Computer doesn't see hd
hi, re: sabrent enclosure:
sort of same issues. documentation is feeble. hd powers up. red light is on.
but the new pc doesn't recognize the drive and, obvously doesn't assign a
drive letter to it.
i tried reversing the cable, changing the hard drive, using different usb port,
re-booting. still doesn't see the drive.
1. jumper settings are correct
2 i use vista, not win 2000 or xp
2 harddrive is old, from old computer
vista doesn't have 'my computer'
i can find manage disk management
can't right click becausse the drive isn't there
how do i change the hdd settings from dynamic to basic if i can't see the drive?
answers to your questions":
1. i'm running windows vista home
2 size of drive... it's old and probably fat(32) under 1g
3 i cycled through the settings
j8 jumper settings
slave, master, & single
no settings work
4. yes i heard the drive spin up
5 the led is red, not green
thx again for your efforts
ken bossewitch
kb@bossewitch.net
Dec 03, 2007 | Sabrent (USB-2535) (USB2535) IDE...
How to connect a IDE-to-USB cable to a 2.5 inch drive?
1) You will do no harm by reversing the connector, but the PC won't "see" the drive at that point (if your drive has an activity LED it will be permanently ON if the cable is reversed) 2) Most times the USB will have enough power to drive the HD all by itself, but if you are going through a hub that may not be the case. In that situation, plug the device directly into a USB port on the PC.
Apr 22, 2007 | Sabrent (USB-2535) (USB2535) IDE...
Sabrent SBT-FWPH (SBTFWPH) Serial Adapter Logo
981 people viewed this question
Top Sabrent Computers & Internet Experts
Martin Murray
Colin Stickland
Colin Stickland
Steve
Are you a Sabrent Computer and Internet Expert? Answer questions, earn points and help others
