Question about Proview PL926WBi 19" LCD Monitor
Pl926wbi 19"proview monitor,screen goes black every 3 seconds,
Where can i buy new inverter board???????
  • crisstiaan Mar 03, 2009
    i kinda have the same problem... when i power the unit, i see something, but it goes away then i've changed the signal cable - nothing changed.
  • Lou Ebert May 11, 2010
    ajbl2006, What do you really mean by "screen goes black'??? When you power the unit on do you see something and then it goes away? or do you think it is completely 'dead'? Does the screen even flicker a little bit when turned on? I'm lmistyrel @ aol or louie12fix on fixya.
  • 558 Answers
Bad capacitors on the pcb boards internally unsoldering ad replacement is indicated.
Posted on Mar 21, 2009
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Proview Master
  • 848 Answers
Pl926wbi 19"proview this trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
200 000 170DTLBMH PI 190DTLB Proview 899 AB0 220DTLB PCTH Power Supply...
Posted on Nov 11, 2014
My proview monitor stays on for 10 sec then goes black. but i can faintly see my page.
This indicates an inverter board failure, caused by bad capacitors that sometimes bulge at the top showing that they are open, an attempt can be made to repair or replace the board.
Mar 05, 2011 | Proview PL926WBi 19" LCD Monitor
I need a base for a 19" PL926WBI LCD monitor. Have
i have the same monitor and it flashes on and off! i am willing to sell if you want to buy it
Dec 12, 2010 | Proview PL926WBi 19" LCD Monitor
Does my Proview PL926WBi 19
Any monitor will work with any computer provided the correct graphics card driver is installed. When you install Vista and you do not install the graphics driver, Windows will default to Generic VGA driver and you will not get the best resolution that the monitor can display.
Jan 29, 2010 | Proview PL926WBi 19" LCD Monitor
Proview Monitor PL926 Wbi The power indicator
Repair estimate will be according to problem.
Nov 13, 2009 | Proview PL926WBi 19" LCD Monitor
Computer Monitor Goes Blank
Pink tink = bad LCD Inverter (aka backlight) thats what you will need to replace :)
Jun 26, 2009 | Proview PL926WBi 19" LCD Monitor
Screen goes black
The video adapter board is what controls the monitor. If you are going to replace a board that would be the one.
Dec 27, 2008 | Proview PL926WBi 19" LCD Monitor
ProView PL926WBi
bad capacitors on the board, replace these and the inverters should get there power.
Dec 01, 2008 | Proview PL926WBi 19" LCD Monitor
LCD display Proview
If the screen is pinkish chances are the panel is defective.Should follow-up with Company Proview and do some correspondence.
Samir
May 23, 2008 | Proview PL926WBi 19" LCD Monitor
Proview Pl926wbi
This is an inverter board problem. The inverter supplies the high voltage and frequency to run the CCFL backlights. The board has a sensing circuit to shut down the output if too much current is going to the backlights or it will shut down if the transistors overheat. I have replaced transistors on some boards with higher rated transistors and they have worked great for years. Sometimes it is just a cold solder joint on the inverter board. Replacement boards are expensive but not too difficult to replace. Repair requires some ability with electronic boards and should not be attempted if you do not posess the skill. You could end up damging other parts that cost more.
Jan 18, 2008 | Proview PL926WBi 19" LCD Monitor
Proview PL926WBi 19" LCD Monitor Logo
424 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Pawan Ambastha
Level 1 Expert
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
