Question about Microsoft Computers & Internet
How to increase the size of the excel page?
How to increase the size of the excel page, min 10 kb?
Quite simply, as far as i know, you can't, excel sheets are limited to 256 columns X 60,000 odd rows.
Posted on Feb 17, 2009
Size of the excel file increased from 721 KB to 50MB
Many businesses use Excel to track their data and expenses.
However, you can run into problems when files grow too big.
Try reducing the size of your Excel files in different ways to eliminate your storage problems.
Remove unnecessary graphics and fonts from the Excel file.
Simple report data doesn't need a lot of excess formatting to make it attractive.
If you need to keep different fonts in your file, reduce some of the font sizes you originally used.
Reduce the number of pivot tables you allow in your data analysis.
Run your pivot table wizard when dealing with involved calculations.
When given options to format the file, choose those that allow the data to refresh instead of adding a new table.
Input your data, close the file and save as an Excel (XLS format) file and as an HTML (XML format) file.
To do this, choose "XML Data" in the "Save as type" drop down box.
Change the name of your document as well, so you can tell the difference between the two files.
Open the XML file and save it back into the regular XLS file to create a smaller file than the original.
Again, rename this file, as well as changing its type. This act removes odd programming left from past calculations since the last "save."
Check into file compression software such as OzGrid.
These products exist because you cannot open a file once it gets too big.
Compress the XLS data by compelling the program to recalculate the cells used for your file.
Excel File Size Reduce Software 7.0
http://www.newfreedownloads.com/Business/Spreadsheets/Excel-File-Size-Reduce-Software.html
http://www.ozgrid.com/
or
Microsoft Excel files can contain thousands of cells filled with data.
When you combine this information with graphics, such as charts and graphs, as well as ever-expanding links to other worksheets, you can end up with an enormous file that takes up precious system space and slows Excel down.
While there are many software programs available that promise to shrink Excel files, there are many ways to reduce the bulk without downloading a new application.
1. Click on any cell in the Excel file you want to reduce.
Open the "Go To" dialog box in Excel 2007 by clicking the "Find" drop-down arrow on the Home tab of the ribbon and selecting "Go To."
In Excel 2003 or earlier, go to the "Edit" menu and select "Go To."
You can also use the keyboard shortcut "Ctrl+G" in any version of Excel.
2. Click the "Special" button on the "Go To" dialog box.
Select "Blanks" and click "OK." Click the "Clear" drop-down in the "Editing" group in Excel 2007 and select "Clear All."
In Excel 2003 or earlier, go to the "Edit" menu, point to "Clear" and select "All." This will clear any blank cells to help reduce the file size.
3. Go to the very last cell containing data in the Excel file.
Select the entire row beneath this cell by clicking the number to the left of it.
Hold "Ctrl+Shift" and then press the down arrow key to select all of the cells beneath this point.
4. Click the "Clear" drop-down in the "Editing" group in Excel 2007 and select "Clear All."
Select the column to the right of the last cell. Hold "Ctrl+Shift" and then press the right arrow key. Again, select "Clear All."
5. Repeat Steps 1 through 5 for any other Excel files that are linked to the workbook you are trying to reduce.
Save the files and then check the new file size by clicking the "Office Button" in Excel 2007.
Point to "Prepare" and then click on "Properties." In Excel 2003 or earlier, go to the "File" menu and select "Properties."
The file size will be listed on the "General" tab.
http://www.ozgrid.com/Excel/ExcelProblems.htm
Apr 22, 2013 | Microsoft Office Professional 2010
First page of PDF files is printed in 10% size - rest of document is ok
Sir/Mam,
Does this happen with a word file, or a web page, or outlook, excel
please check. if OK with them its the file its bad. Mite want to upgrade the adobe to 10 or 11 current. Try different computer also. Print different adobe files also.
Dec 17, 2012 | Konica Minolta KONICA BR BIZHUB C451...
Increase font size when printing from Google pages
You cannot change the font size if you are using the web page. What I can suggest is to highlight the text that you want to print, then you should have an applications like a Microsoft word, excel, power point etc., Paste it on that application, in that way you can now change the font size and also the font phase.
I hope it help you a lot! Good luck :)
Feb 02, 2011 | Office Equipment & Supplies
When i scan a document the file size is too large. a 1 page document scans as over 27,000 KB using 300 dpi. if i use smaller dpi the print is too light.
1. Increase the contrast on the print. That is increase the ink that is dispensed.
2. Check the user manual as to how to do this function.
3. It seems at this resolution the printer reserves the ink dispensed when this size print is selected.
Feb 03, 2010 | Lexmark X8350 All-In-One InkJet Printer
Loaded Software - Excel crashes after displaying print setup box.
The reson is because you have not installed the latest printer drivers. try updating printer drivers or contact you printer manufacturer for further assitance
Feb 06, 2009 | HP Officejet J5780 All-In-One InkJet...
Printer cant print excel files
Chjange the page size of the excel document, it at present is set to letter, ...file page set up in excel
Sep 23, 2008 | HP LaserJet 4 plus Printer
How to formulate log function with excel
Here try this link
http://support.microsoft.com/kb/214116
Nov 12, 2007 | Microsoft Excel for PC
Open Questions:
What is Microsoft office applications? Microsoft office is a set of interrelated desktop applications, servers, and services, collectively referred to as an office suite, for Microsoft Word: a word processor included in Microsoft Office and some editions of the now-discontinued Microsoft Works Microsoft Windows and macOS operating systems. Microsoft Excel: a spreadsheet. Microsoft released the first version of Excel for the Mac OS in 1985, and the first Windows version (numbered 2.05 to line up with the Mac) in November 1987. Microsoft PowerPoint: a presentation program used to create slideshows composed of text, graphics, and other objects, which can be displayed on-screen and shown by the presenter or printed out on slides. Microsoft Access: a database management system for Windows that combines the relational Microsoft Jet Database Engine with a graphical user interface and software development tools. Microsoft Access stores data in its own format based on the Access Jet Database Engine. Microsoft Outlook: a personal information manager that replaces Windows starting in Office 97, it includes an e-mail client, calendar, task manager and address book. Microsoft OneNote: a notetaking program that gathers handwritten or typed notes, drawings, and audio commentaries. Notes can be shared with other OneNote users over the Internet or a network. Microsoft Publisher: a desktop publishing app for Windows mostly used for designing brochures, labels, calendars, greeting cards, business cards, newsletters, website, and postcards. Microsoft Project: a project management app for Windows to keep track of events and to create network charts and Gantt charts, not bundled in any Office suite. Microsoft Visio: a diagram and flowcharting app for Windows not bundled in any Office suite
Dec 28, 2017 | Microsoft Computers & Internet
Computers & Internet Logo
59 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
