FixYa.com
Tags:
Jensen AS-2 Speaker
Speaker Construction
By Mini Me - usenet poster
Most of the responses to building a 4' speaker have been tales of the
largest speakers made. The problem is most of you mention companies that
have constructed very large HORNS with multiple drivers, whereas the
original author is asking about the construction of a 4' driver. I am by
no means an expert, but the largest drivers I've heard about are 30". I'd
like to hear if anyone has heard of DRIVERS made that have been larger
than this!
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 01, 2007
Not Rated (0)
Joey2
Joey2 - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I believe Mitsubishi via their Diatone subsidiary made a rather large
woofer possibly around 60" or so.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Charlie
Charlie - usenet poster
Rating: 0%, 0 votes
Hi Tlidd,
References: <49ivfl$
TT TT TT TT TT TT TT
if we are talking standard jensen-type dynamic drivers, then the 30"
size is already in the vicinity of the size of driver where the gain in
sensitivity by increasing the size is lost by the increase of cone
weight needed to make the cone behave in a reasonably rigid manner, and
it may even be above the optimum size, also because you have the problem
of getting enough magnetic field strength into the airgap.
This is why all replies seem to have focused on either multiple drivers
or horns or 'all of the above'. For a practical design, say 4 30"
drivers on a front horn with a 2:1 to 3:1 compression ratio might be a
workable solution. Efficiency would be some 5 to 10 percent (just a
guess), and powerhandling in burst and/or 'integrated programme' could
run as high as 2 kW. Radiated acoustic power would then be some 100 to
200 watts (peak), and you probably could build the thingy to fit
reasonably on a flatbed truck. The most difficult part of it would be to
get the cabinet rigid enough, carbon fiber might be an attractive
solution, just build the horn in that material and encase it in sand.
You would of course need custom designed speaker units, I don't think
the 30" units on the market are designed for front horn use, simply
because such designs as the one outlined about falls in the category of
near technical folly, and also they do in fact remind about weapons.
Construction of a 4' loudspeaker cone would be fairly close to the
impossible, simply because its inevitable breakup modes would be at
unpleasantly low frequencies, and even bass linearity would be very very
poor.
Kind regards
Peter Larsen
* Internet: , Copenhagen, Denmark *
* Fidonet: Peter Larsen@2:235/334.4 *
* Relaynet(tm): Address to Peter Larsen, route - * Conference Host for the Relaynet Amiga Conference *
?? RM 1.3 03104 ?? Internet: , Fidonet: Peter Larsen@2:235/334.4
Solution #3
Not Rated (0)
M0nica L
M0nica L - usenet poster
Rating: 0%, 0 votes
Sounds a lot like a more modern implementation of an old French
pre-electronic design that used steam pressure for acoustic
output down in the sub 10 Hz area.
When was this beast at White Sands? I saw some of the electronic
transducers used to test missile components...these were multi KW
amplifiers and some huge voice coils. The coils didn't have
cones, they were bolted directly to whatever was to be vibrated.
[And on at least one occasion, a sheet of plywood for playing
XMAS carols but thats another story.]
Can you Help with these Home Theater Speakers and Subwoofers problems?
sts96 speaker wire
speaker wire's not long enough Answer This...
Refund money back to Best Buy...
I placed an online order last... Answer This...
turning off the speakers on my...
Iwant to turn off my speakers... Answer This...
Popping sound
Sub has an auto off when not... Answer This...
Sub-Woofer Magnavox MRD-200
El sub-woofer dejo de funcionar... Answer This...
Repair Service
Find Home Theater Spe. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
