ZyXEL G-202 quits after establishing connection.
Error message:
ZyXEL G-202 Wireless Adapter Utility has encountered a problem and needs to close.
Has anybody any ideas what is causing this - I believe I have the latest driver installed.
  • alanmac950 Mar 16, 2009
    Thanks, Charlie
    I have downloaded the latest driver from the manufacturers website, uninstalled the existng one, and reinstalled to no effect - there is obviously some incompatibility with my windows XP pro set up. However, i can live with the problem as my wireless link continues to work after the zyxel utility crashes and burns. How odd.
    Cheers Alan.
  • Anonymous Apr 30, 2009
    Pretty much the same problem, are you with Euphony as an isp?
    If i use my netgear adapter instead then it works much better.
    Problem Solver:
  • 8 Answers
What OS? Is it Vista/XP compatible? Check the documentation that came with the device and see what it is compatible with.
If that is a dead end, you could try to check the web sight for a firmware flash utility and hex file.
Did you use the disk to install the driver? If so you most likely do NOT have the most up to date driver.
Did you plug it in to your computer before you installed the driver? Some times when you do this Windoz try’s to install the best-matched driver it can find and this can cause all kinds of problems.
1: Remove the device
2: Uninstall the driver and all the software that came with it
3: Restart the computer
4: Reinstall the software from the disk.
5: go to their web site and download and install up to date drivers
6: Plug in the device
If none of this helps then you have two options. Wait until they fix the problem, if they ever do (could be specific to you). Or go buy a new one. I recommend Belkin or Linksys. If you buy a new one you may be interested in the idea of a "Cantena". They can extend your WiFi by a lot. You can buy them or you can make one. Tiger Direct sells them. And the plans are every were
Best of Luck
-Charlie
Posted on Mar 12, 2009
I need to download ZyXEL G-202 usb wirless driver.Is there someone who could help me to download this driver?
put wirless driver into port 1 then access the usb icon in taskbar this should then prompt you to down load correct driver for usb router hope that helps pal it worked for me
Jul 28, 2011 | Zyxel Zyair G-202 USB 2.0 Adapter
Another application is controlling the wireless adapter
I believe you are using WINDOWS XP.
In case of windows XP, there might be 2 different wireless utilities can control your wireless adapter.
First utility is the manufacturer's utility. If you have Dell wireless adapter then you can use Dell utility to connect to the network.
Another utility is Window's utility. You are getting the error message in this utility because your computer is using another utility.
To use window's utility you will need to start the " wireless zero configuration ".
Click Here
for more information about wireless connection
Feb 22, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
Error message
It seems that the adapter is not installed properly ..... uninstall the adapter from control panel >> Add & remove programs Reinstall the adapter again by using it on different port .....
thus says linksys...
May 08, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
Router cannot connect to belkin g usb adapter it worked fine yesterday and today nothing!
Make sure to install the USB adapter's driver and utility. If it's installed, you need to use the Belkin WLAN Utility to connect to the wireless network. You should be able to find the signla coming the router and you can connect to it
May 07, 2009 | Zyxel P660HW-D1 Router
Wireless connection
go to zyxel.com in that you searche it you get it you product and configure it
May 15, 2008 | Zyxel Zyair G-202 USB 2.0 Adapter
Computers & Internet Logo
725 people viewed this question
David Payne
David Payne
