Question about Craftsman 8.50 Torque Rating Dual Rotating Tine Tiller
Homelite htc-12 tiller starts but tines won't turn
  • 5 more comments
  • mlpotast Mar 20, 2009
    I have a htc12 tiller and it has the same problem. It will start but the tines won't turn. What is the problem and how do it fix it?
  • grlien Apr 09, 2009
    Homelite Tiller HTC-12 works ok until tines hit the dirt - then it bogs down like it has no power. Can it be the gear box or clutch? The same thing happens when trying to use the dethatcher attachment. What do I do??
  • peppergrower Apr 17, 2009
    I have the same problem. My htc-12 starts but tines won't turn.
  • Anonymous May 05, 2009
    yes I have the same problem.....the motor runs great but the tines are bound up
  • karla3 May 06, 2009
    the tiller will engage in gear but the tines will not rotate
  • JERRY ABELL
    JERRY ABELL May 11, 2010
    hello mr t,is this a minnie,or a big tiller.two or four cycle.brand,model#,type#,code#,would be nice to know if i am going to help you.thank you.MrFixIt.
  • Anonymous Mar 26, 2014
    motor runs tiller part not turning
No I don't need any help with this problem. I oiled it well and it broke free and works fine now
thank you
Posted on Feb 18, 2009
I have the same problem and the toggle switch on the handle needs to be replaced. I could really use a manual for this unit. Anyone know what I use for fuel? How I mix it? Any other info would be appreciated.
Posted on Apr 22, 2009
MDT Tiller starts and runs but tines won't turn
-Won out drive or driven gears.
Good luck
Mai
Jun 28, 2014 | Mantis 2-Cycle Tiller
I have a Yard Machine rear tine tiller that has sat unused for 4 years. I replaced the engine and while in goes forward and backward, when I engage the tines they won't rotate and the engine bogs
Transmission/differential.
Perhaps the unit sat for 4 years because the tines would not turn and your replacement engine has not solved the real problem.
I'd say disassemble the chain case to discover what's locking the tine drive.
Apr 12, 2013 | Garden
Tiller engine won't turn over after the till was on its side to clean tines
remove the spark plug and pull it to force any fuel and oil from the cylinder hold a rag over the top of the spark plug hole as fuel and oil will spray out check the oil level before running the engine again
Apr 30, 2012 | Troy Bilt Bronco 208cc 4Cycle Gas Powered...
Ryobi ry64400 tiller tines won't move engine runs fine
then you need to open the gear box and find out why if it has a forward and reverse the the shifting linkage it could be stuck in one gear and adding the other will lock it up as well
Apr 17, 2012 | Ryobi Cultivator
Homelite htc 12 tiller.. motor runs ok but tines wont turn under load free wheeling they turn but under load no clutch?
Hi bh1149...
You have bad gears on the inside of the tiller gear box...
I had this same problem with mine.
You will have to take the gearbox apart in order to know what parts are bad.
Be sure to check the lube more often when you install the new gears/parts.
Go to the following website and order your parts.
Please take time to rate me
http://www.ereplacementparts.com/homelite-parts-c-18807.html
Sep 08, 2011 | Homelite Consumer Products Tiller...
Looking for a primer pump for Homelite htc12 tiller
Hi, I live in cedar rapids, Iowa. I just bought a primer bulb for my htc-12 homelite tiller. You should be able to order as many as you need, but I don't have the part #. Find out what the part # is and call this # 1-319-393-0443. They have 2 sizes, the bigger one is for the chain saws, the small one is for the tiller.( they have both) Carefully pry the plastic band off the primer bulb, press the new bulb through the band, then go get a tube of permetex weather strip adhesive ( orange box, black adhesive). Don't buy any other brand!. Lay a thin bead around the base of the bottom of the ring, press into place and let dry for a couple of hours. This adhesive works on almost any thing, and is not affected by gas, oil, or anything.
Apr 24, 2009 | Homelite Consumer Products Tiller...
Tines won't turn.
Sounds like you hit something (like a rock or a big root) to make it Stop suddenly and smash one of the gears in the housing, The shaft that runs through the housing has a brass gear that is easily damaged when it comes to a sudden stop from hitting something. Snow blowers are famous for this problem.
Apr 17, 2009 | Homelite Consumer Products Tiller...
Craftsman 8.50 Torque Rating  Dual Rotating Tine Tiller Logo
1,792 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
