Question about Dell Dimension 4600 PC Desktop
My dell dimension 4600 will not boot from cd drive first
I changed the order in the bios to boot up from the cd drive first but it still goes to the hard drive first. please tell me how to correct this problem.
  • henry_sulliv Feb 18, 2009
    rwalkero was correct, his advise worked the first time. it went right out to the drive and booted up from the cd reader.
    thanks for your help.
    henry_sulliv
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 82 Answers
Go back to the Dell BIOS screen and change all setting back to the default settings. Put in a Bootable CD and press F12, this will give you boot menu. Then you can boot to any device that you need to.
Please rate my response
Posted on Feb 17, 2009
Dimension 4600 dvd drive keeps opening
Try this first - open up the BIOS part of the system. To do this, shut the computer off; wait at least 10 seconds; turn the computer back on and then press F2 when the Dell logo appears. Press continually until the message Entering Setup appears. In the Boot Order section, remove the CD/DVD drive from the boot order by clicking on Disable from the drop-down menu. If this doesn't fix it, please resubmit your question
Feb 19, 2015 | Dell Dimension 4600 PC Desktop
My Dell Dimension 4600C Series will not go pass the part where it shows the Dell logo - after that it is just a blinking dash, then it just disappears. I've tried to reset the BIOS but that didn't do...
The blinking dash is the way in which the BIOS is telling you that it was unable to find an operating system - the screen blanks out because it goes in stand-by.
If even after you have changed the boot order from the BIOS you can't load the Recovery Disc then this is a hardware problem - the chip that controls the disks (hard and optical) is defective. That means that the motherboard is defective and you will have to replace it.
Dec 29, 2010 | Dell Dimension 4600 PC Desktop
I can't boot up normal, safe mode, or to the cd-rom on my dell dimension 4600 desktop, i've set to boot to cd rom in bios, but still nothing
If you are trying to boot off an Windows Installation disc then you might have a problem. On some computer the CD-ROM drive won't be able to read the operating system disc.
The solution to this issue would be to put in a DVD drive and try to boot from that.
More details on the normal and safe mode boot attempts would be nice too. Are you getting a blue screen or is it just hanging up?
Jun 06, 2010 | Dell Dimension 4600 PC Desktop
I have a Dell Dimension 4600. I need to re-install Windows XP Professional. The PC won't boot from the CD-ROM. When I choose F12, then Boot from IDE CD-ROM, the PC boots directly to Windows. how can I get...
Check the BIOS to make sure that the CD rom is the first boot devices in the bootup sequence, also make sure that the cd rom does show up in the BIOS.
Make sure that the CD Rom itself is good or the boot cd you are using is good, try it on other PC.
Oct 29, 2009 | Dell Dimension 4600 PC Desktop
Dell Dimension 4600 will not reconize cd or dvd drive
  1. ensure the drives are jumpered Cable select.
  2. Boot to the BIOS, turn on Caps Lock, Scroll Lock, Numlock. Then press ALT+E (You should hear one beep) then ALT+F (You should hear one beep) if you have no floppy disk drive, turn off the Floppy Drive and the diskette controller the ALT+B to save and reboot.
Mar 01, 2009 | Dell Dimension 4600 PC Desktop
Windows will not boot up
Hello.
If you got a Windows CD try the following...
Reboot the computer and enter bios by..
When the blue DELL™ logo appears, press <F2> immediately
You might have to try this a few times since you have to be really quick,
In system setup (bios)
Set CD Drive as first device in the boot sequence. Press F10 then chose "Y" to save.
Reboot.
When asked if you want to start on CD just press any key.
The menu on your cd should have a repair option.
Hope this helps.
Regards...
/Tech5508
Feb 14, 2009 | Dell Dimension 4600 PC Desktop
PC will not boot from CD drive
Download the six winxp install floppies,,from bootdisk.com and install that way.
Your PC was not meant for XP it was meant for Millenium at most.
But if you load through floppies and then use the cd you should be OK
Jan 19, 2009 | Dell Dimension 4600 PC Desktop
Dell dimension 4600
check in the bios that it is your new hardrive it is seeing, and not your old one still sitting in thr bios memory, as taking out the battery doesnt always delete the cmos memory.
There shoul be an option in the bios to auto recognise the drive
Aug 24, 2008 | Dell Dimension 4600 PC Desktop
Dell Dimension 4600 PC Desktop Logo
203 people viewed this question
Alun Cox
