Question about Hampton Bay 48670 Flemish Pewter Finish Ceiling Fan
Hampton Bay Wiring?
I have 4 wires coming from my switch white,black,red and ground.I have 4 wires from fan,white ,black,blue and ground.The manual says to wire the blue in with the black,what do I do with the red wire from the switch?
    Brigadier General:
  • 4,669 Answers
You have two switches right? One for the light and one for the fan? White should be neutral. Green should be ground. Black should be hot from one switch and red should be hot from the other. Hook black to black and blue to red. If you wire blue and black together then one switch will turn on the fan and the light at the same time.
Posted on Jun 05, 2009
3 Suggested Answers
bigg t
  • 640 Answers
SOURCE: 2 many ceiling wires
ok lori connect the fan wires like this-----white from fan to both white wires---blue from fan to red---black from fan to both black wires then copper wires to a ground.let me know.
Posted on Jan 17, 2008
SOURCE: Wiring a Hampton Bay ceiling fan
we are installed in new fan which is the glendale model what is the purpose of the red wire. Do we connect them with the black and blue wires?
Posted on Jul 06, 2008
Need a wiring diagram for a hampton bay ceiling fan
most of the manuals have wiring instructions - check out any one of the manuals here
Jul 12, 2012 | Hampton Bay 24002 Ceiling Fan
Just installed a new Hampton Bay 36" ceiling fan.
I suggtes recheck your wires, could use this wiring guide (click image for zoom)... support/t9590572-hunter_fan
Jun 29, 2011 | Hampton Bay 24002 Ceiling Fan
No wiring diagram with fan ( hampton bay three speed fan with light)
white to white, black to black, blue to red, & green to ground.
If you don't have a second hot house wire(red), then put black & blue from fan to house black.
Nov 29, 2010 | Hampton Bay 52 In. Cameron II Plus Ceiling...
I need help wiring my fan. I can't get the fan to work, but I do have the light working. From the ceiling I have a white, black, red and ground wire. How should these wires connect to the White, Black,...
White is your neutral so white goes to white. Blue on the fan is for the light kit you need to wire that to the wire from your switch so it works the lights. Black is the hot wire that is always hot not switched so tie that to the wire that is not on your switch. Green is ground so green to green. white to white / green to green/ black to black/ red to blue/
Nov 06, 2010 | Hampton Bay 24750 Huntington III Ceiling...
Ceiling fan wiring
blue would be your earth.
black and white are phase and neutral.
for the wiring in your roof you need to call a local sparky. just ask which is which and connect them appropriately.
Sep 01, 2008 | Hampton Bay 24002 Ceiling Fan
Need Wiring instructions
no problem just wire the black to black and white to white. connect the ground and cap off the blue wire, its used only for ooptional light assy
Apr 03, 2008 | Hampton Bay 73554 Antigua Ceiling Fan
Jan 15, 2008 | Hampton Bay 46056 Callaway II Ceiling Fan
Hi Rexter,
I would pull the cover off of the Light switch and look at the color of the wire leaving the Variable speed device. I only assume the red wire is from that. I do not like to assume anything. So you must verify that a red wire leaves the Variable speed device. If it does, then i am assuming you dim the lights with this Variable device. The fan has its own built in Variable speed setup. In the case that the red wire belongs to the variable device, wire the Red to Blue(light), and Black to Black Whites to white. Green to Ground. bare wires to ground.
Nov 30, 2007 | Hampton Bay 24002 Ceiling Fan
Wiring ceiling fans to wall switch
Hi Bigelow,
You need two switches.  It sounds like the Electrician set up the junction box for two circuits(Lights and Fans).  i say this because your supply has 4 wires, Red , Black, White and Bare. We may be able to oversome this with one Lutron Switch. Allow me to investigate, and I will be back.
Oct 20, 2007 | Hampton Bay 24002 Ceiling Fan
Hampton Bay 48670 Flemish Pewter Finish Ceiling Fan Logo
368 people viewed this question
Top Hampton Bay Dryers Experts
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
