Question about Epson Stylus C86 InkJet Printer
Epson stylus cx7800 nozzle check blue color missing. prints are all orange & yellow in color. My printer has a mind of it's own. After a few days it goes back to normal...been this way for ages.
  • Thomas F. Schneider May 11, 2010
    Try taking the cartridges out , cleaning the contacts with a pencil eracer and reinstalling them.
  • 353 Answers
In view of this being a CX7800 problem mis-posted in the C86 section, and, it seems, Smithbrother having lost interest in the problem, let's call it "solved by poster".
Posted on Mar 28, 2009
I have been using an epson stylus color 880 for years. One day it would not print. Replaced the cartridges and still will not print. It goes through the printing procedures but nothing shows up on...
The print head nozzles may be clogged. From the Utility section found in the EPSON printer driver, clean the print heads by performing a head cleaning followed by printing a nozzle check pattern. A head cleaning and nozzle check must be performed as a cycle. After printing a nozzle check, examine the printed dot pattern. Each staggered horizontal and straight vertical line should be complete, with no gaps in the dot pattern. If there are gaps in the dot pattern, continue with another cycle. Perform up to 3 cycles if necessary. If the nozzle check is not printing completely, and if the head cleanings do not help the nozzle check pattern to print completely, try replacing the ink cartridge. Any ink cartridge installed into the printer must have a blue label on top of it. If the blue label has been removed from the ink cartridge, do not install the cartridge. Using an ink cartridge, which does not have the blue label on it, may damage the printer. Caution: If you have already installed a cartridge which is missing the blue label, or if a previously installed ink cartridge was missing its blue label at the time it was installed, and now head cleanings do not help the nozzle check pattern to print completely, your printer may require service and you should contact the EPSON Connection for further assistance.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jul 08, 2011 | Epson Stylus 880 InkJet Color Printer
When printing a picture, the picture is blue when printed the printer has new ink cartirages
goto printer properties and under the utility tab, print the nozzle check print out to see which color is missing.. if your picture is only in Cyan color, most probably your Yellow and Megenta is clogged.. try doing the print head cleaning and see if there is any improvement to your print out.
May 28, 2010 | Epson Stylus NX400 InkJet Printer
Epsonstylus CX7800- when printing color
well you must use the correct ink, you use a very thin ink, that´s way it´s bleeds, the ink is very metal corrosive, and destoy al mec. parts and bunsout the print head. NOTE:you have ruined your printer, the repair is very expensive.
Jan 13, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Replacing Blue Ink cartridge
The nozzle check takes very little ink it sounds as though you need to do a head clen though.
Aug 01, 2009 | Epson Office Equipment & Supplies
Epson SX 205 ink insn't low but is not printing yellow or green
Status monitor just show approximately, not real level. It might be yellow and cyan ink is out actually.Others, yellow and cyan nozzle may be clog. Check nozzle, do head cleaning. Check nozzle again.
Jun 19, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Stylus printing striped alternating shades of yellow and green of image
Possible printhead issue.
Please reseat the black cartridge. Let the printer charge like it normally does.
Print a nozzle check pattern. If you see gaps, missing lines or missing colors on the pattern, clean the printhead using the driver. 3 consecutive cleaning cycle is recommended. Compare the nozzle pattern over the last printout. If you see any improvement, you can clean the head numerous times until you get a perfect nozzle check pattern.
Apr 30, 2009 | Epson Stylus C86 InkJet Printer
Epson Stylus Photo R340 Faces in photo are printing day-glo green
Possible printhead or driver issue.
Are you using Adobe photoshop? Please try to print also using a different application to isolate the issue.
Make sure that you are using correct epson cartridges.
Please print a nozzle check pattern. If you see gaps, missing colors or missing lines on the pattern, clean the printhead using the driver.
If the nozzle check pattern printed out successfully, please trash and re-install the drivers. The driver is available on epson.com
Apr 29, 2009 | Epson Stylus Photo R340 InkJet Printer
Epson CX7800 print head not working
it would be better if you get a new printer or the best to use is vodk and leave it over night to get rid of all the dryed ink
Aug 21, 2008 | Epson Stylus CX7800 All-In-One InkJet...
Prints yellow vertical lines on all color print jobs
Try to do a nozzle check/ Turn printer off/ put in a plain paper
Press and hold the middle button on the printer while turning it on. When it turns on you can realease the buttons. Should [print the nozzles/ check if there would be gaps of missing colors/ if yes do head cleaning by going to printers and faxes under contorl panel>right click on c66 and go to printing preferences>maintenance tab>print head cleaning>do it 3 times and then try to print
Jan 21, 2008 | Epson Stylus C66 Inkjet Printer
Epson 9600 suddendly stopped printing yellow
It's NOT a cartridge if this works... I had a similar problem with a 9600 I bought on eBay that had been inoperable over 18 months. Three colors would NOT clear up after multiple power cleanings. Epson support politely solved the issue at no charge on the phone... he had me drop a few drops of warm water on the pad the printhead rests on when not printing. You have to move the printhead to the left to do that by moving up the little lever near the cutter. The pad is easier to reach with a long eye dropper. I used very warm water- not boiling. I replaced the printhead over the warm water pad for an hour. Then I repeated the process and let it be for another 60 minutes. Then I did a nozzle check and what was gummed up yellow, cyan, and magenta nozzles became clear and it's worked fine since. Good luck!
Oct 10, 2007 | Epson Stylus Pro 9600 InkJet Printer
Epson Stylus C86 InkJet Printer Logo
216 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
