Question about Mustek MP100 Portable DVD Player
Error say no disc but the disc is inside spinning????
Jvc DR-MV5S disc error
Could be drive failure. The non-spinning DVD is an indication.
Nov 10, 2017 | JVC Televison & Video
Vauxhall insignia dvd800
Laser is offline. Needs to be serviced or junked.
Mar 10, 2014 | Car Audio & Video
My LG RH397D will not play a disk. It gives a navigation error.
Does not play disc
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
    See the diagram attached.and if the problem persist. Lube the plastic parts with small grease or vaseline very carefully
Feb 09, 2013 | Televison & Video
CDJ NOT READING CDS. STATES (DISC ERROR)
If it shows No Disc error to all CDs, either its Sled Motor [The motor which spins the disc inside], or its optical picku unit has the fault. You have to contact the nearest Denon authorised service center to get it repaired, as Denon uses special type machanism with theirs sets, and it can't be available at open electonic spare part market.
Apr 23, 2012 | Denon DN-S700
Crunching sound after disc inserted and it starts spinning. then screen reads "error occurred, eject disc..."
there mite be something jammed inside the disk drive take a look inside to see if theres anything inside if so just pull it out with something long and thin that dosnt conduct electricity.
Dec 20, 2009 | Nintendo Wii Console
Disc wont spin
There are 4 reasons a disc won't spin on the Slim PSP. The most common is a failed laser.
1. Failed laser -- the disc will not spin up to speed, or not spin at all, due to a bad laser. If you close the PS2 with no disc inside, the ps2 will never spin the disc. If you chose the PS2 with a disc inside but a bad laser, it still thinks no disc is inside and will not spin.
2. Lid closed sensors. There are two of them. One on the motherboard and one on the reset switch. These sensors let the PS2 know that the lid is closed. If one or both of these break, the disc will never spin because the PS2 will think the lid is still open.
3. Damaged case. If the case of the PS2 is damaged, the two parts of the lid that are supposed to press the lid-closed sensors will never press them.
For more information, pictures, and parts, click into the following page:
http://store.richspsxparts.com/slpsnospdi1a.html
Oct 21, 2009 | Sony PlayStation 2 Slimline Console
Every time I put a game in it will play for a good while and then all of sudden it will say, problems reading disc check owners manual, or something like that.
This is not nessesarily a solve issue, however it worked with mine, I had the same issues when playing games. I would be in the middle of gameplay, and the the error screen would pop up and say that the disc coudnt be read, All I did to fix the issue was open the unit, blow the dust off the disc drive motor and attatched ****, then I used some 3 in one oil on all the motors inside the system. So far it hasnt messed up (FINGERS CROSSED) I hope this helps.....I noticed with my gamecube that it would quit spinning the game, and after I made it past the gameplay loaded in memory it would error out because it needed to spin the disc and load more programing into memory.....if your disc dont spin you are guarenteed a disc read error
Sep 26, 2009 | Nintendo GameCube Console
I have a trutech dvd player modelT600-D. Loading only..
It clicks and keeps loading after a while it says"wrong disc," I just have it for a few months and it acted like this. I checked inside, it seems like everything is correct but it just clicks and never spins. or it says error disc... i just bought this GRRRRRR!!!!!!!
Dec 09, 2007 | TruTech TT320
Mustek MP100 Portable DVD Player Logo
Top Mustek Televison & Video Experts
richie46
JonSnell Electronic
JonSnell Electronic
Are you a Mustek Televison and Video Expert? Answer questions, earn points and help others
