Question about Dell XPS 210 PC Desktop
VGA monitor won't work on Dell XPS210
Tried to hook up old Panasonic PanaSyncSM70 monitor to a Dell XPS210 computer (running Vista). It has a PCI Express x16 card installed, but I can't hook my monitor up to the card. I took the card out, plugged the monitor into the standard jack and it worked. Question is, do I need the PCI Express card and if so, what type of adapter do I need so that I can successfully plug the monitor into the card?
One other quirk, not sure if it's connected, but once I removed the card and tried to see how much memory (RAM) the machine had, it just showed "Information not available".
  • 1 more comment
  • john doe Feb 17, 2009
    I did get a DVI to SVGA adapter and it didn't fit. The plug on the adapter did not fit the plug on the card.
    TOPSEARCH E96016 is the video card that came with it. The computer was given to me so I don't have any paperwork on it. I read this off the card itself.
    The adapter I have is exactly like the one pictured in this link, the one on the left that has the horizontal bar on the right side. However, the plug on the card does not have a matching slot. It's white, and looks pretty much like a standard monitor plug (4X15 holes) except it's longer and thinner, which is why my monitor plug won't fit.
    An expert who has written 3 tips or uploaded 2 video tips.
  • 82 Answers
Is the connection different. If so you need a VGA to DVI converter. You can get this at Best Buy or Fry's or any computer store.
The memory issue should not be related. Go to control panel and then to the system icon and click system is should show the memory. You can also go in to the system bios to see actually how much you have. When the system boots. It should give you an option to go to the setup screen. The screen goes by quick so you may need to reboot a couple of times.
Please rate my response.
Posted on Feb 17, 2009
  • Ralph  Walekr
    Ralph Walekr Feb 17, 2009
    What type of card is it. Give me the name of the company and the model number so i can look it up.
  • Ralph  Walekr
    Here is a link
    Not sure why the connector is not fitting. Look at the pictures and see if you the same connections. It should fit. Can you take pictures of the back of the video card and the monitor connections.
How do I fix the error no vga input signal no dvi input signal monitor going to sleep
Check if you VGA is properly settled in the PCI slot. Try to take it out, clean the slot for dust.
If that doesn't help, it is well possible that you VGA is not working any more.
Jun 10, 2012 | HP Computers & Internet
I upgraded optiplex GX260 with Windows Vista. I lost video resolution on the monitor. Can you email me the link for the driver? Thanks, paa
Vista has a cutoff date on desktop computers for supporting drivers for video.
Your options are to go back to XP, or see if your computer has a spare
PCI slot, if so then buy a PCI VGA board that is Vista supported.
When you open your case and install the board, bootup and Vista
will detect the new VGA board and install the required drivers.
Aug 23, 2011 | Dell OptiPlex GX260 PC Desktop
My dell E207WEP monintor start giving me problem, the VGA is connected properly it, blink show me the screen and than blackout, than if i again switch off the monitor and turn on again it show me blink of...
try hooking your monitor to another pc and see if you get the same response. if you do then the obvious is that you have a bad monitor. if not then your problem involves your vga graphics. the vga graphis may be that of an intigrated port or pci/pci e. either way, adding a new grapics card will solve the issue. be sure to research your pc to insure you purchase the correct graphics card. most often with the newer dell pc's , the designated slot is pci express/pci-e
Jan 18, 2011 | Computers & Internet
Trying to hook up dell 2350 computer to hdtv can i use the serial port in any way to be able to have two monitors working at the same time
No, you should get VGA Card/ Graphics Card that support HDTV.
Plug it on the PCI Slot, then you're able to enjoy it..........
Oct 23, 2009 | Dell Dimension 2350 PC Desktop
Monitor on power save mode and using wireless keyboard and mouse
This sounds like the monitor is not reading a signal from the computer. I had the same problem when I installed a DIV cable from my old VGA cable. The video card was still sending the signal via VGA port instead of the DVI port of my video card. You should cheack the cable to you're computer and what port is being used. If everything is hooked up correctly then there might be a problem with the cable. Other then that it could be you're video card. If the hard drive is running and everything is running fine then what I said should be whats wrong. If nothing works go back to the shope and tell them the new problem you have.
Sep 10, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Will a dell dimension 2100 support dual monitors
Yes it will but that will also depend on your graphics card to a degree.
To do it properly you need to install a new graphics card and disable the on-board graphics card from the bios.
Your new card should support std VGA as well as DVI
DVI is also capable of being hooked up to many large screen tvs
Aug 20, 2009 | Dell Computers & Internet
No display on Windows Vista need driver?
Make sure that the settings in the new video card are actually set to run both monitors.I see this happen in my comp. repair shop quite often. It is a common mistake.
May 04, 2009 | Dell 1703FPT 17-inch Flat Panel Monitor
I have a old computer (Dell) and a new flat screen (Dell) i hooked them up and the screen is black (won't work). It's a digital screen and a analog computer does this make a difference?
Not at all - as long as there is a VGA connection (analog) for the monitor, you're fine. Make sure that if you have a video card that you set your bios to automatically send the video signal through the card (where you'd hook your monitor cable to).
In some cases, if you have a video card, (and you're connected to the VGA output from the motherboard), the signal is bypassed and trying to go through the card automatically. If there is no card, disregard this last paragraph.
Apr 06, 2009 | Dell E193FP 19" LCD Monitor
Vista not detecting monitors connected to the VGA port
Try to do the following:
Connect to the new PC, it lowers the resolution of video and connects to the old PC
Dec 16, 2008 | Pine Technology XFX GeForce 7950GT, (512...
Computer monitor
I have never tried that but I would say it won't work that way. I have 2 display cards (3 outputs each, VGA, DVI, TVout) and 3 monitors. When I check the driver software and multiple screen function, it shows only 2 output (VGA and DVI) each. I cannot set TV output as a second screen. Even display properties on windows, it shows only available monitor output. I don't think you can do that.
Thank you,
Mar 05, 2008 | Dell E153FPc 15" TFT LCD Flat Panel...
Dell XPS 210 PC Desktop Logo
898 people viewed this question
Alun Cox
