Question about Canon NP 6551 Black and White Copier
Error message - re insert unit 1
After putting copies thru the feeder we received this message re insert Unit 1. Has anyone been able to remove this error message and fix the problem?
  • 1,602 Answers
GO ON LINE AND TYPE THE FOLLOWING:
CANON NP 6551 B/W RE INSERT UNIT 1
ENTER
WHAT IS CANON NP6551 B/W UNIT 1
ENTER
CANON NP 6551 B/W SERVICE MANUAL
ENTER
ROD
Posted on Feb 17, 2009
E000012-0106
The machine cannot be operated and the error code <E000012> appears on the display.
Cause and Solution
The delivery feeder unit may not be installed correctly. Follow the procedure below to install the delivery feeder unit correctly. If the error code persists after the delivery feeder unit is installed correctly, contact your local authorized Canon dealer.
Re-install the Delivery Feeder Unit
NOTE
  • You have to remove the delivery feeder unit and reinstall the delivery feeder unit correctly.
  • When you remove the delivery feeder unit, you have to turn the main power switch OFF.
  • Sending or receiving documents cannot be done when the main power switch is OFF or the power cord is disconnected.
  • If the main power switch is turned OFF, all jobs waiting in the print queue will be erased.
  • Documents received into memory and documents stored for delayed send will be retained for approximately 60 minutes after the power cord has been disconnected.
1. Turn OFF the main power switch and disconnect the power cord.
2. Open the front cover.
If you are using the stack bypass tray, close it before opening the front cover. Open the front cover gently holding the handle (A).
3. Push the levers (A) on both sides of the delivery feeder unit and remove the delivery feeder unit gently, holding it by the tabs (B).
CAUTION
Do not place any object on or touch the transfer belt (A) of the delivery feeder unit. You do not need to manually clean the transfer belt even when it is stained by toner, as the delivery feeder unit has a self cleaning function for the belt. Breaking the delivery feeder unit or damaging the transfer belt may result in misfeeds or deterioration in print quality.
4. Install the delivery feeder unit so that the protrusions (A) of the delivery feeder unit fit into the guides (B) and click into place.
5. Confirm that the triangle marks (A) on the delivery feeder unit are aligned with the triangle marks (B) on the machine.
6. Close the front cover.
Close the front cover gently holding the handle.
CAUTION
Be careful not to get your fingers caught.
7. Reconnect the power cord and turn on the main power switch.
Jun 22, 2015 | Office Equipment & Supplies
"remove original from document processor"
Sensor in feeder is probably broken. To get around this until you can get it fixed power down the unit and unplug it. Unplug the cable that connects the Doc feeder (in the back) to the main unit (two screws hold it on. Then power the unit back up it will work with out the Doc feeder. You will just have to put the copies on the main glass.
Jun 29, 2011 | Kyocera Copystar CS-1820 Black and White...
Wat is an LSU error on a phaser 3200 MFP
Change the toner cartridge , i have many units phaser3200 and this is one of the problem , but only if the toner cartridge is very old and many time refilled , if not , change the Laser unit .
  1. Remove a misfed document if the copier displays a message reading "Document Jam." Lift up the document feeder cover and turn the roller to remove an Exit Misfed document. Lower the document feeder back into place and feed the document through again. If the document is jammed on the Input side, open the cover and gently pull the misfed document to the right and out of the feeder.
  2. Pull out the paper tray and lift the tray to release it from the copier if the copier displays a message reading "Paper Jam O." Remove the jammed document, and open and close the side panel of the copier to clear the error message.
  3. Unplug the power cord and plug it back in again if the copier displays a message reading "Fuser Error, Open Heat Error, Heating Error and Overheat." If the problem persists, call for a service.
  4. Remove the toner cartridge and shake it from side to side if the copier displays a message reading "No Developer Cartridge." If this does not do the trick, you may need to replace the cartridge. Pull the release latch to open the side cover, and open the front cover. Twist the cartridge locking-lever upwards and remove the toner cartridge. Insert the new cartridge and lock the lever into place. Shut the front cover and the side cover.
  5. Power off the unit and power it on again if the copier displays a message reading "LSU Error." A problem has occurred with the Laser Scanning Unit. If the problem persists, call for a service.
Jan 04, 2011 | Xerox Phaser 3200MFP/N Laser Printer
Cannot print, scan or copy. Continue to receive
Solution
  1. Remove and then reinsert the cartridge indicated in the error message.
  2. If the error is still displayed, clean the contacts. Click here to see how.
  3. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. Remove both cartridges, lower the latches, and close the printer access door.
    2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
    3. Turn the printer back on by pressing the On button.
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
  4. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty.5. Replace Cartridge.Please rate my response!!!Thanks,SF
Jan 28, 2010 | HP PSC 2410 All-In-One InkJet Printer
Dust on drum error message. How to clear
On most fax machines a Dust on Drum error simply means that the drum unit needs to be removed and the charger cleaned by sliding the small built in charger cleaner back and forth but be sure to place it back in it's home position or your received faxes and copies will have a blank line thru them. See your operators guide for more details.
Aug 18, 2009 | Office Equipment & Supplies
Error 50 c
  1. Power off your printer.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the printer on. The print cartridge carrier moves and stops at the loading position, unless the printer is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
Hope this helps.
  1. Lower the scanner unit until it is completely closed.
  2. If you receive the error message again, replace both cartridges.
Jul 29, 2009 | Lexmark X6170 All-In-One InkJet Printer
When scanning several pages of a document some pages scan fine, some you'll hear a draggin noise and there are smudge lines thru the document (putting thru feeder). Other times when you place 1 copy to be...
Well, if both feeder and pattern glass also having line on print, suspect hardwares problem...
U can check below items:
1. drum
2. laser unit
3. fuser unit
Mar 03, 2009 | Office Equipment & Supplies
Error inkcartridge
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200
Nov 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Ricoh Aficio 2035G Duplex issue
When you open the whole duplex unit you will see a very small metal tab with a screw, on the top right side on the machine. This activates the switch on the duplex unit.
Or with the duplex unit open you will se a small rectangle hole inside a switch, put a piece of paper or something to activate it, might got stuck.
This problem is very common on this machines.
Nov 18, 2008 | Ricoh Aficio 450 Copier
Cartridge problems
Clean the heads, printer is not reading new cartridge or refilled cartridge. You may also have a paper jam if alignment is affected. Check for little jams, post back if no go lilacgerry xxx
Dec 28, 2007 | Lexmark X4270 All-In-One InkJet Printer
Canon NP 6551 Black and White Copier Logo
374 people viewed this question
old marine
old marine
