Question about Hyundai L91A 19" LCD Monitor
How can I load the ImageQuest Q92 on my windows based computer? I get a message when I plug it up that says Video Mode not supported. I have no idea on how to even start searching. Thanks. Kat
  • Anonymous Feb 17, 2009
    Thanks Rod, which vendor do i contact, my computer or the monitors? Please help and thank you so much...
    Rod, I got it disregard that last comment. I will check with Hyundai. Thanks again.
  • 1,602 Answers
Posted on Feb 17, 2009
Computer is not screen keeps coming with the message input not can i turn my computer on loads on safe mode.
Input not supported could be the screen having problems. It loads in safe mode so the display driver is corrupt or set to a too higher resolution for your screen.
Adjust it as required.
Jan 08, 2011 | Computers & Internet
I have plugged the monitor into my HPmini and the screen reads Video mode not supported
check settings on the mini make sure set up correct ,,sending correct signal,,also chack for driver updates and downloads for monitor and the hp mini,,check support they can help to
Nov 03, 2010 | Hyundai ImageQuest L70S 17" LCD Monitor
Video Mode Not supported message when connecting my laptop to the monitor
Your lap top video resolution is set too high for the external monitor to handle, your monitor can only handle up to 1280 x 1024 @60Hz. You need to lower the PC resolution.
Jun 25, 2010 | Hyundai ImageQuest L70S 17" LCD Monitor
How do I reset the screen? The screen shows (video mode not supported)
You get that message because the PC video out put is too high for the monitor to support, you need to set the PC video output to native resolution:1280 x 1024 @60Hz.
Apr 01, 2010 | Hyundai ImageQuest B70A 17" LCD Monitor
When i turn on the screen it says video mode not supported
you may have configured the resolution or video settings to one setting that is not supported.
this monitor should support 24 bit color depth and make sure you're resolution is not larger than Native (Recommended) Resolution1280 x 1024
right click on an empty space on your desktop and go under properties then click on settings tab and change values accordingly.
Mar 26, 2010 | Hyundai ImageQuest L70S 17" LCD Monitor
GX520 screen display message: cannot display this video mode
This means that the windows setting you have set can not display on your current monitor. There are two ways to fix this, one is to boot the computer in safe mode by pressing f8 after the POST screen and change the resolution and the other is to plug the computer into a different monitor to see if supports that resolution and then change the resolution in windows to a lower setting.
In case you don't know how to change the resolution in windows, follow below.
Right click on the desktop
Settings at the top
Move the slider to 1024x768
Click ok
Try rebooting. If that still doesn't work, try another resolution.
Oct 19, 2009 | Dell OptiPlex GX520 PC Desktop
Screen says video mode not supported
can you hook your old monitor up and change the resolution to 1280x1024? If so, you should then be able to use the L90D
Mar 23, 2009 | Hyundai ImageQuest L90D 19" LCD Monitor
'input not supported'
just had this problem and just fixed it. all you need to do is unplug it directly from the outlet then turn on it worked for us so hiopefully it will work for ya'll
Sep 07, 2008 | Computers & Internet
Input not supported
You may have a video resolution selected on your computer that the screen doesn't support.
The reason you see the the initial startup message is because that is loaded from the bios, prior to the settings for the graphic card output being loaded.
Try booting the computer in safe mode and adjusting the display resolution.
Dec 29, 2007 | Acer AL1916W 19" LCD Monitor
Standby mode
Check the video connection the video card. You can try another monitor to see if it does the same thing. The video card could be bad.
Jul 15, 2007 | Hyundai ImageQuest F770D 17 in.CRT...
Hyundai L91A 19" LCD Monitor Logo
37 people viewed this question
Top Hyundai Computers & Internet Experts
 Zackery G
Zackery G
Level 1 Expert
Are you a Hyundai Computer and Internet Expert? Answer questions, earn points and help others
