Question about BenQ G2110W 21" Monitor
Sudden lost of color gamma - "discoloration"
Experienced problems from the second day (owning it less than 2 months), like stuck pixels, which later disappeared on their own after a couple of weeks, and the main problem of sudden discoloration which manifested once 7 weeks ago, but now it's so strong that i'm going to return the monitor. Discoloration or sudden sponteneous switching to 256-color like gamma (despite that display properties show 32bits albeit with a row of tiled colors instead of smooth spectrum) occurs after a certain interval after power on and strongly correlates with the time off - the longer the monitor rests the longer it works properly. And IT IS monitor problem because i have second one at hand which works OK. BTW, same s... happened when the cable was disconnected...
  • 1,602 Answers
GO ON LINE AND SEE IF ANYONE ELSE HAS BEEN HAVING THE SAME OR SIMERLY PROBLEMS OR MAYBE A RECALL ON THAT CERTAIN ITEM.
ADDRESS BAR:
BENQ G2110W GAMMA ISSUES,
GAMMA FAILURE,
LOST GAMMA.
ENTER...................... AFTER EACH COMA
ANYTYPE OF PROBLEMS WITH BENQ G2110W
ENTER
GO ON TO ABOUT.COM, ASK.COM, INFO.COM
ROD
Posted on Feb 17, 2009
GREY SPOTS ON BACK OF SCREEN NOTICEABLE WITH WHITE
Hi if your tv is a dlp it might be an issue with the DMD board Hi,Yes your problem sounds like the DMD board.This is how it works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens. Here's a video that will help you find where the DMd chip is located : http://www.youtube.com/watch?v=0jr_9A5Xd2Q Have a blessed one!
May 03, 2010 | Televison & Video
Everything that is supposed to be black is showing
Hi,It sounds like a problem with the color wheel or DMD board. The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will hear ,humming,buzzing,high pitch noises ,you might also experiment color distortion ,black and white picture. This is how the DMD works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens. Here's a video that will help you find where the DMd chip is located : http://www.youtube.com/watch?v=0jr_9A5Xd2Q Have a blessed one!
Apr 29, 2010 | Televison & Video
Samsung HPR4272X/XAA has 2 black bars going from top to bottom.
I really do not know there is the "Stuck Pixel Fixer programs" I think that Program Breakdown another IC. For this issue is absolutely the Plasma display panel have problem. You shall exchange it.
Apr 17, 2010 | Samsung HP-R4272 42 in. Plasma HDTV
Little green and white boxes on the screen
Hi,Yes your problem sounds like the DMD board.This is how it works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens.Found it right here http://www.discount-merchant.com/MITSUBISHI-RMD62-939P977A20-Light-Engine-p/1138084.htm?Click=48173 Have a blessed one!
Apr 16, 2010 | Mitsubishi WD-52525 52" Rear Projection...
I have a samsung DLP TV, model HLN5065WX. When I plug it in after a few seconds both the lamp, and temp lights flash on the front. It did have just the lamp light flashing and it would have horizontal...
Apr 02, 2010 | Samsung HLN5065W 50" Rear Projection...
Discolored Sides
Hi,Yes your problem sounds like the DMD board.This is how it works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens.Ths if your tv is a dlp if its a Lcd it will be an issue with your light engine: Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine. Have a blessed one!
Mar 29, 2010 | Televison & Video
The colors seem to be overlapping the red is further off than the other two
Hi, you might be experimenting a color wheel problem.The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises.The other thing that it could be is the DMD board.This is how it works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens. Here's a video that will help you find where the DMd chip is located : http://www.youtube.com/watch?v=0jr_9A5Xd2Q Have a blessed one!
Mar 24, 2010 | Samsung HLN5065W 50" Rear Projection...
The image seems to bend or convex. The colors are not aligned, red and blue can be aligned but will not merge with green.
This does sound like a convergence problem but the model you listed does not have a convergence circuit.
If you tell me the full model number and brand I can if it is Mitsubishi I have start to finish step by step instructions for this kind of repair in those sets.
To help you more I need the model and brand.
SD TECH
Nov 09, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Vizio tv first screen had bluish discoloration and than few days later a pop and screen went black .ANY IDEA OR SUGGESTION all of the sudden started experiencing severe discoloration
This is called the pop of death! If you call vizio they will ask you if you heard a pop, this is a common issue and unless your under warrenty your looking at 916$ to fix it. (assuming you have no sound! If you do its 430$ plus tax for parts and repair. You can buy a used one on ebay for that price!
I have the parts numbers if you want them!
Call vizio if you have had this system for under a yr the will fix it free!
As for me my 50 and 42 inch had this issue and well I am out of warrenty.. I hate vizio lol!
May 24, 2008 | Vizio L32 32 in. LCD HDTV
Dead Pixel in Toshiba Porteg? M600 laptop
Without rplacing the main part of the lcd, I'm afraid you're stuck.
Nice laptop. Toshiba service has always been reasonable in my experience.
Sorry I couldn't offer better advice.
Good luck
Nov 25, 2007 | Toshiba Portege M200 Notebook
BenQ G2110W 21" Monitor Logo
153 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
