Question about Dishwashers
Lock light is on
A green light is on with the picture of a pad lock. I have know idea how to turn it off.
  • 188 Answers
Look for a button with a picture of a lock on it. Hold it down until it turns off. It may be the button closest to the actual light.
If not please provide the model and model number.
Posted on Feb 17, 2009
WD-57731 Will turn on, I get sound but no picture.
You should be able to see if lamp itself is lit or not, if lamp does come on or has been replaced recently let me know, I have a idea or two but need more information if possible.
Oct 14, 2012 | Mitsubishi WD-57731 57" Projection HDTV
Any idea why the water dispenser and ice maker are not working?
Press the Dispenser Lock and Water pads at the same time for four (4) seconds and a successful reset will be indicated by three flashes of the green light.
Jun 03, 2012 | Amana ARS2464B Side by Side Refrigerator
Just wall switch works transmitters won't light
You probably have the opener lock turned on. Press and hold the lock button on the wall button pad for four seconds. The green light will go solid instaed of flashing
Jun 14, 2010 | liftmaster Chamberlain Garage Door Opener...
My led lights up 88 but when i push the buttons to unlock pad and set timer it wont do anything
are you holding down the pads long enough to hear a beep? hold down arrow till it beeps then hold up arrow till it beeps then set your hours with the up arrow
now let it lock itself and turn on.
This will take 2-10 minutes keep looking for the second green indicator this lets you know it is gen erating chlorine
Jun 12, 2010 | Intex Automatic Salt Water System for ...
TV won't power on
ya u repair ur smps power sullpy soon ,nither ur power supply gone damage
Jun 02, 2010 | Sampo PME-42S7 42 in. Plasma EDTV
No picture on monitor - green power light blinking
There's an internal electronic part/s of your monitor that is cold soldered / defective. I suggest to bring the unit to an authorized service center to properly diagnose & fix the problem. regards
May 28, 2009 | NEC MultiSync 75 17 in.CRT Conventional...
I turn the tv on the green light comes on three times but no pic
maybe you did the child lock which doesent allow you to turn the tv on unless u clck some buttons look in ur booklet and search for how to unblock the child lock or the 2nd try the turn on button and the ok button at the same time if it doesent work forgive me this happend to me as well
Mar 17, 2009 | Televison & Video
Don't have user manual Get one?
Check to see if Num Lock is turned on. Depending on your computer, it may light up the key with a green light, or a green light may be lit near the part of the computer where the screen is connected to the computer.
Jan 15, 2009 | IBM ThinkPad T30 2366 Notebook
Dishwasher locked key has been activated.
To turn on Lock:
Press and hold Heat Dry for at least 4 seconds. The Locked light
glows. If you press any pad while your dishwasher is locked, the
light flashes 3 times.
To turn off Lock:
Press and hold Heat Dry for at least 4 seconds. The Control Lock
light turns off.
Dec 18, 2008 | Whirlpool Dishwashers
Describe your Xerox WorkCentre Pro 412... Problem:Scanner
Turn off the copier first.
Look under the copier, there by where the copies come out, look just above that portion of the machine. There will be a green sliding latch; one side has a picture of a pad lock for lock, the other side has a un-lock position, slide the latch to the unlock position.
Turn on the copier, and the machine should work.
That latch is for transporting the copier when being moved. It will hold the scanner in place so it does not move around.
Apr 23, 2008 | Xerox WorkCentre Pro 412 All-In-One Laser...
Dishwashers Logo
66 people viewed this question
Top Dishwashers Experts
