Question about Insignia NS-DVDR1 DVD Recorder
I cannot get the discs it records to play on any other unit, computer or otherwise. Without that, it is useless to me.
  • 2 more comments
  • magenstein Feb 17, 2009
    Yes it plays on the machine that records it.
  • magenstein Feb 18, 2009
    Thanks, I will try it again and make sure that process is done and see how that works. I do not have the original anymore so I might have to borrow that again.
  • jim beckwith May 11, 2010
    I have a machine that does the same thing so what i found out that there is a finalization at the end and that is what I am being told
    but I have not done the finalization yet at this moment .
    but that is what I am going to do
    does it play on the recorder
This problem was solved by reinserting the DVD and finding Finalize on the menu. Once it was finalized, it played fine in other machines and on the computer.
Thanks,
Mags
Posted on Feb 23, 2009
Error 0507
see the cause and fix it:
1 alternative for playing DVD:
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
2ND ALTERNATIVE: FOR VHS RECORDING:
play the VHS TAPE CLEANING , FOR clean the sensors, rollers, drum etc.
b) Try it.
c)Otherwise you must go to the repair shop TV for fix it.
God bless you
Jul 21, 2012 | Samsung VR-325 DVD Recorder / VCR Combo
Our church uses the Marantz Cd 633 Recorder. The problem we are having is that the playback volume of the CD is not high enough. You have to crank up the playback device all the way to hear recording at...
You have to isolate where problem is. Does a prerecorded disc play at normal volume levels? no? Check fade settings in menu. If yes, substitute another line level analog input from another device right at the recorders back panel. Test recording with that input and verify if recording level display can reach clipping level. If you have that and still have weak playback, again check for an in/out fade function being programmed. Also check volume selection in menu and try different settings, including 0.0. There is also a monitor mode to check input levels without using a test disc. Otherwise have unit checked by a repair business
Nov 22, 2017 | Marantz CDR633 CD Player Recorder
Pansonic e 85h won't play recorded disc or finalize recorded discs also unable to play previously finalized discs, hdd is working and recording fine, what could be the problem on this dmr e 85h panasonic...
The symptoms sound like the laser needs cleaning adjusting or replacing by a qualified technician. If it is under warranty then you can return it. The only other thing youmight try is to open it and gently clean the laser lens with a q tip and a drop of alcohol if you know how. Otherwise get it professionally serviced.
Kind Regards
Chris
Mar 12, 2010 | Panasonic DMR-E85H DVD Recorder
Recorded DVD will not play in another player
try playing on computer. if ok copy on hard drive and burn it. if it wont work on your computer. there was an error in the making of the disk..
Apr 15, 2009 | Televison & Video
Can't play recorded discs on other players or computer only DMR-E
TRY FINALIZING THE DISC IN THE SAME UNIT IT WAS RECORDED IN.
Mar 17, 2009 | Panasonic DMR-E55 DVD Recorder
CD's won't play in other machines
Your problem is an easy one.....you need to "finalize" your completed/burned CD first...then it'll play in tray A...and others. Good luck....from Middleman
Feb 07, 2009 | RCA CDRW120 2-Disc CD Recorder
I have toshiba dvd recorder,the problem is the recorded dvd cannot play with other player. Do I have to return this recorder as it just a week away since i buy it
Make sure you Finalize the disc when you are done recording, otherwise it won't be read on other players or computers. To do this you go to Setup> Disc and choose Finalize. It takes a few minutes per disc, don't turn off the player while it it finalizing. In the same Setup menu you can choose an option to autofinalize the disc when you are done recording, so you do not have to to it manually each time.
Dec 07, 2008 | Toshiba D-KR10 Multi-Drive DVD Recorder
Philips DVDR615/69
Take, if good  batteris from the remote controller and recycel the unit, and by a better one. I have the  same problem, recordings will stay on the dvd only a short thime readable and later the disk is empty.
Sorry my english.
Sep 26, 2008 | Philips DVDR615 DVD Player
Invalid disc reading
reset to factory mode, should be in the instuction manual ,how to do it.
Mar 28, 2008 | Lite On LVC-9016G DVD Recorder/VCR
DVD player recorder won't read or play any disc
This just worked for me. Don't know how long it will last though. I found it on this webpage
http://forum.ecoustics.com/bbs/messages/15118/130292.html
To do a reset:
On the remote control press the SETUP button,
Press the right key on the remote 3 times,
The Preference page will show up,
Press the down arrow five time to highlight
"default", hit right arrow to highlight "reset"
Press enter to reset. Turn off/on machine, etc.
Sep 27, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
Insignia NS-DVDR1 DVD Recorder Logo
101 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
