Question about RCA Scenium HD50LPW52 Replacement Lamp
How do you change a RCA bulb on a Flat Screen Televison
  • 1,602 Answers
GO ONTO ASK.COM AND ASK THEM OR GO ONLINE TO THE ADDRESS BAR AND TYPE:
RCA SCENIUM HD50LPW52 SERVICE MANUAL
OR
HOW REPLACE A BULB FOR RCA SCIENIUM HD50LPW52
ENTER
ROD
Posted on Feb 17, 2009
My RCA 37 inch flat screen TV has horizontal lines going through the screen
This type of issue can only be fix by a professional tech specially if its a flat screen TV. the line across indicate that there is a problem with the projection of the unit.
Nov 22, 2017 | RCA Televison & Video
Ok i have a flat screen rca tv it turns on but the screen is black and i can hear everything as if i was watching it whats the problem
You didn't say if it was a LED or LCD set or the model number. Can you see a picture if you use the flashlight test?
Oct 15, 2017 | RCA Televison & Video
Rca tv comes on have sound but screen doesnt come on what should I check
First thing do a flashlight test to see if an image is present on the screen, this would mean the TV screen backlight bulb is burned out.
Feb 06, 2017 | RCA Televison & Video
My 46 RCA flat screen has standby light but goes out when tv is turned on and I have no picture or sound so I replaced power supply board and no change any advice would be great
If the image is present on the screen when a flashlight is shined from the back then the problem may be the Timing control board.
Feb 03, 2017 | RCA Televison & Video
My RCA flat screen model SLD55A55RQ flipps colors when you turn it on the sound works just see the colors. None of the answers are for a Rca model flat screen
T'Con board fault. Check and replace it. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jan 24, 2017 | RCA Class 1080p 120Hz Smart Back Lit LED...
I have a 2001 RCA Home Theater Projection TV Model p46924, Chassis # PTK195M34A. The screen all of a sudden started going dark and then just black. I have had it unplugged for about a month. Plugged it in...
Sounds like there is a hi voltage problem. Those 3 tubes are the most expensive parts to replace if you can find them. I. You can get an estimate for the repairs, but most likely they will approach the cost of a new flat screen smart TV.
Aug 06, 2017 | RCA P46924 46" Rear Projection Television
Rca remote control CRK76TA1 has problem w/ sending signal to tv. if i wiggle the eye, it will work for a while. now, no amount of wiggling will work. i have tried removing batteries and pushing every...
Remote is broken.Replace it.
https://www.Abctay.com is an online shop ,
We sell television and electrical accessories,all kinds of TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc.
Jul 06, 2017 | RCA Televison & Video
Is my bulb going bad!!!!
Without seeing your Tv it is hard to say what is really going on.
The cloudy picture sounds like one of your "bulbs" needs to have it's fluid changed, not "bulb" replacement.
Rain bowing normally means convergence adjustment or circuit repair is needed.
May 25, 2008 | RCA P52926 52" Rear Projection Television
Rca tv r61wh76yx51
Try River Valley Electronics. His store can be found on E-Bay
Apr 03, 2008 | RCA Scenium HDLP61W151 61 in. HD-Ready...
RCA Scenium HD50LPW52 Replacement Lamp Logo
1,043 people viewed this question
Top RCA Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a RCA Office Equipment and Supply Expert? Answer questions, earn points and help others
