Question about RCA F25216BC 25" TV
25in RCA F25216BC Jan/99 won't turn on/ no power
I was given this TV today by a neighbor and it won't power up or do anything. I'm very familiar with building pc's and replacing parts and troubleshooting them but have never opened a tv set before to repair one. I enjoy tinkering and I thought I would try to fix this one just for fun. Does anyone have a suggestion for me as where I can start? Replace powersupply? Or am I wasting my time with a 10 yr old tv and should just toss it to the curb? Thanks!
cmgillespi@aol.com
  • cmgillespi Feb 24, 2009
    Thanks Clarko2002! I took off the back of the tv and just as you suggested, the fuse was blown! What an easy fix! It was loaded with dustbunnies as well but a couple of quick shots of air from my air compressor got it clean as new. Should help it run alot cooler as well. I wonder how many tv's get junked by people when it was something as simple a a 20 cent fuse! Also makes me wonder how many people get ripped off at repair shops with huge bills when it was something so simple! Going to put it in my boy's bedroom; a big upgrade from his 19 inch.
  • 360 Answers
First step, remove the back and check the fuse.
let me know from there
clarkco
Posted on Feb 17, 2009
Rca F35720SB makes popping noise then shuts off
It may be arching from the flyback. If you are familiar with tv's remove the plastic case plug it in and turn it on and see if you can see anything visual happening. Make sure not to touch anything and keep a safe distance when inspecting.
Oct 30, 2012 | RCA 27F634T TV
I have a RCA F25216BC TV that will not turn on..the fuse isn't blown and I need a schematic
Send your email address to me by Fixya, and get a copy of the schematic by return mail.
Sep 22, 2012 | RCA F25216BC 25" TV
TV worked fine for 12 years till this evening. When I push the power button there is an electronic clicking sound inside but the set will not turn on. The speaker still makes the quiet popping sound it...
The tv has a high voltage problem, sets that last ten years or more have come to the point where a new tv should be considered, because even if you fix it there is good chance something else will go wrong, remember the parts are twelve years old.
Jan 05, 2011 | RCA F25216BC 25" TV
I am trying to connect a DVD player to a RCA F25216BC 25" TV - the TV only has an F type Coax connector and does not have a CH 3 or 4 switch - I put the input from the wall to the DVD player and out to the...
Your TV must be equipped with AV inputs (RCA jacks - yellow, white, red)
in order to connect this unit. If your TV does not have AV inputs, you will need a RF Modulator to connect the DVD recorder to your TV's
antenna/cable input. RF Modulators are available at
major electronics retailers such as Radio Shack or Wal-Mart and allow the 3 RCA outs from the recorder to connect to the RF modulator RCA inputs and then you can connect a coaxial cable from the modulator to the TV RF input and select channel 3 or 4 on the TV. The DVD recorder will not pass thru signals to the TV using coaxial cable as far as DVD are concerned.
Aug 22, 2010 | RCA F25216BC 25" TV
RCA TV service # 24V414T Turns on buy itself,
ive seen this before. possible remote control interferance from nearby neighbor
Nov 13, 2009 | RCA Televison & Video
F25216bc RCA 25 inch TV. Color is distorted with a heavy red tint
You either have a bad CRT or a Shorted Red Output IC/Transistor. One other possibility is if
someone turned the Screen Control down if it is accessible from the back of the set.
Hope this helps,
Skyassc
Jun 22, 2009 | RCA F25216BC 25" TV
Manual menu button not working after adding channel-no RCA remote only disconnected DirecTV remote
Normally if you unplug the tv for 10 min everything resets, if not look behind for a reset button
May 13, 2009 | RCA F25216BC 25" TV
No video audio connecters
If you have a VCR with RCA inputs and coax (cable) output to TV, try plugging the DVD players RCA outputs (L/R audio, composite video) to VCR RCA inputs. Then select the DVD input on the VCR and it shoud play just as a the VCR does. If you don't have a VCR, an RF modulator might be needed, but a VCR would probably be cheaper.
Jan 24, 2009 | GE 25GT240 25" TV
TV won't turn on.
The horizontal (line) deflection circuit appears to be at fault. This circuit is responsible for the generation of high voltage (tension) that also drives many of the secondary circuits such as the vertical drive, tuner and sound stages. While the main power supply itself is running, a failed secondary stage will give the symptom that you've mentioned. Replacing the line-output transistor is likely to solve the problem. However, this advice is given with the understanding that you are familiar with TV repair. Otherwise please refer servicing to a qualified tech.
Jan 09, 2008 | RCA TruFlat 27F520T 27" TV
RCA F25432 25in
If you ONLY have an Antenna or Cable input, you are going to need a Video & Audio to RF converter.. This connects to ya DVD Video & Sound OUT, and then connects to ya sets Antenna IN. This device converts ya Video & Audio signal to Radio Frequency Signal that can be "Received" by ya set. (Basically a low power TV transmitter) This is the only way I know of, if ya haven't got any other Inputs into a set.
Aug 15, 2007 | RCA F25432 25" TV
Televison & Video Logo
103 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
