Question about Kirby G4 Bagged Upright Vacuum
Hoover shapmpooer will not dispence the water
Help
  • charangell1 Feb 28, 2009
    I checked the other problems and it seems that I have it all assembled correctly. The small screen is attached to the small round hole on the tank. I get no water and no suds. Brush rotates fine. Help!
  • charangell1 May 11, 2010
    RockyNR1 - thanks for the tip, I did not notice the "white straw" in the tank. How do I find out if it is clogged? Can I take the top off the tank to get to the straw (I tried to pull it off and couldn't). If I turn the tank upside down and pour water into the tank's little round hole that has the white straw, water goes into the tank directly from the hole without going through the straw - is this supposed to happen?
    Changing topics now to the sponge - I had cleaned this before using the shampooer. After using the shampooer this had some gunk on it, so I presume that it has some suction. The sudser valve opens/closes properly and I can pour water through the 2 little holes from under the sponge and it goes into the tank so I think that part is okay.
    The small screen is sitting in the tube that attaches to the tank (I did have it attached to the small tube on the tank when I started shampooing) and tray; I can pour water through the tube okay.
    Also, my Kirby shampoo is older (years old) - but if I shake the bottle, I get lots of bubbles - should I try new shampoo?
    My sister had used the shampooer years ago so it did work at one time. This is a 12 (?) year old G4 that I use as a vacuum and it still vacuums fine.
    Sorry if too many details, but this is really bugging me... :-)
  • Kirby Expert
  • 324 Answers
Check for clogs in valve (under the sponge on the water tank.
Make sure the sponge is clean
See if the screen is not clogged.
See if the supply tube (white straw inside water tank is not clogged)
Posted on Feb 28, 2009
Bissel powerwash 1690 does not dispence water
Hey George, not having spray when you're ready to clean can be frustrating.
Here's a quick link to troubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1052&cid=ccsocial
Jan 21, 2013 | Bissell Carpet Cleaner Powerbrush Deep...
Water will not dispence while cleanning
Before using tool
It may be necessary to remove air from
the system ("prime the pump") so the
clean solution will flow to the tool. Follow
these steps:
1. Attach tool to hose and turn the carpet
cleaner ON.
2. Put the tool on a hard surface or
against your hand to block off the suction.
3. Wait a few seconds (can take up to
15 seconds). Then squeeze the trigger
and begin cleaning
.http://hoover.com/file/604/
Sep 18, 2012 | Hoover SteamVac F5914-900 SpinScrub...
Steamvac will not stop dispensing cleaner. Once I pull the trigger it starts to dispence liquid and will not stop even when I release the trigger.
This sounds like a faulty solenoid that may be intermittantly working. I would take it to a repair shop for evalualtion
Sep 23, 2009 | Hoover F7431-900 SteamVac Vacuum
Hoover steam cleaner wont pickup water
in the front on top the cover that curves down to the floor is where the suction is .it should be plastic you can see into.its probably clogged with hair and dirt.you need tro take that top off and it comes apart in two sections .the middle seperates from the outer part.once apart you can clean it with soap and water.after you get that off you will see on your left side a long square port that needs to be cleaned also.please leave feedback.i hope i was of some help to.pete
Apr 30, 2009 | Hoover SteamVac F5914-900 SpinScrub...
It won't dispence any fluid
make sure the tank is properly seated.on the tank there should be a filter or a tube make sure they are not clogged
Apr 07, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Pck up
Makw sure the recovery tank lid is secured down all of the way around, sometimes it doesn't catch and will **** up. Also check the filter on th inside of the recovery tank lid, it needs to be at least a 1/4 in. gap from the top. If it is pushed up all of the way, then it won't allow suction.
Aug 05, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Dispenses Water Only
try replacing the air filter and the water heater.
Jul 28, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Need help!!!!!
Need help!!!!!
Hoover F7425-900 SteamVac V2 Widepath Upright
I read the manual and tried my new Hoover, the brushes spin, but the waters not going to the bottom tank, what does that mean and what can i do?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
You could have a bad water release valve on your water tank of which holds the water, the trigger assm might not be connected, bent or broken. Check the trouble shooting owners manual --- also there are hoses that could be crimped or bent, or clogged or not connected, but it is my guess it is the water release valve. Try to back track the water from the holding tank and test all the valves on the system and you might find the problem by the process of elimination. Feel free to contact you local vacuum cleaner dealer in the yellow pages or contact the Hoover Co @ the information listed below:
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Don – The Vac Man
Apr 22, 2008 | Hoover F7425-900 SteamVac V2 Widepath...
Cleaner won't dispence cleaning solution
I have the same problem and each time I have to get the thing sent to Sydney to get the hose cleared out. Costing me $60 to $80 a pop.
Mar 10, 2008 | Pullman Holt Vacuums
Kirby G4 Bagged Upright Vacuum Logo
52 people viewed this question
Top Kirby Vacuums Experts
Mike Cairns
Mike Cairns
Roger Potts
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
