Question about POSX POS-X XR-500 Printer
My posx xr 500 does not work with the usb to parallel cable
The parallel to parallel cable was also used but to no avail.The printer is not detected at startup and is not seen in control panel.
2 Suggested Answers
mrtimothyjoh
  • 29 Answers
SOURCE: Driver download
cut and paste the link below into your browser. Near end of page is driver and software download.
Don't forget to rate
http://www.posmicro.com/RECPRINTERS/POS-X/pos-x_xr200.htm
Posted on Oct 23, 2008
I have been trying to print with my posx printer and it doesnt work can you guys please help me out with that?
plug printer in go to devices printers you should see your printer on bottom have with yellow mark on it right click it then its goiung to ask you trouble soot it then its going to ask you fix then windows will do the rest.
Feb 04, 2011 | POSX POS-X XR-200 Matrix Printer
I am using window 7 program, bought a usb to parallelle for my epson lx 300 printer, the cable was installed and working, but it did not detect the printer,
Windows 7 removed all legacy support for hardware (including parallel port printers). The USB to parallel cable will not be able to accomplish what you are trying to do in this case.
Jan 12, 2011 | Computers & Internet
My printer is out ink how can I replace the ink
1. Make sure the printer is turned off and unplugged.
2. Remove the DIP switch cover on the bottom of the printer.
3. Set the switches using a pointed tool, such as tweezers or a small screwdriver.
4. Replace the DIP switch cover.
Dec 22, 2010 | POSX POS-X XR-500 Printer
Cable connectivity with my laptop through a "parallel to usb cable". My laptop has no parallel port but only usb ports.
make sure you follow this step :
1. install driver USB to Paralel port (LPT1) before the cable connected to PC
2. After the driver installed, install the cable - and it supposed to be detected
3. the last think u have to do is install the scanner/printer driver
if it is not work, i guess the problem is on the USB to paralel adapter, or the driver not installed correctly
Jun 01, 2009 | Acer ScanPrisa 640P Flatbed Scanner
Printer doesn't work when use usb parallel converter.
Forget about using parallel converter. Just use the USB cable it works best anyway.
Easiest way is this.
1: Turn printer on. (Green light. ready to print)
2: DISCONNECT the usb cable from the PC.
3 DELETE the Zebra LP2844 & Zdesigner drivers from the printers & Faxes folder. Just highlight them and hit the delet key. Don't worry Iknow what I'm doing.
4: Plug in your USB cable back into PC.
Just sit back and wait, your PC will automatically detect your printer and re-load your driver software.
Send me the cheque now!!
May 12, 2009 | Zebra LP 2844 Thermal Printer
How to get Panasonic KX-P2123 printer to work with USB port
Cables are available from a number of sources which will convert from a USB plug for your computer to a serial or parallel connector for your printer. (I don't remember for sure whether that Panasonic is serial or parallel. I think it's a parallel printer and uses a Centronics connector.) Do a search for "centronics to USB" or "serial to USB" and you will find links to a number of sources.
Mar 25, 2009 | Panasonic Computers & Internet
USB CABLE
the printer is designed to work with a parallel cabel connection. usb to parallel conversion cables may or may not work.
now for the second part is, about the driver (visit manufacturers website for updated drivers), usb driver behaves differently compared to parallel drivers as it expects a usb printer connected to a computer. try both drivers. remember, it may or may not work.
Dec 03, 2008 | Argox OS-203 Thermal Label Printer
Driver download
Oct 23, 2008 | POSX POS-X XR-200 Matrix Printer
Printer non compactability
i bought a hp psc 500 without an installing cd or connecting cable to a Laptop. what can i do
May 22, 2008 | HP PSC 500 All-In-One Printer
Initialization failed - Unable to acquire TWAIN-compliant device
I have seen your message stating that "Initialization failed - Unable to acquire TWAIN-compliant device" error is received when trying to connect USB-Parallel type to your Laptop.
Well,  Printer  Panasonic UF4100, recommends to use only " Printer/Scanner Interface as Bi-directional Parallel (IEEE1284) " means you need to use Parallel cable to connect Printer to the Computer/Notebook.  You may receive some communication error messages if you are using a  "PORT REPLICATOR CABLE"( USB TO PARALLEL connector).  The error message that you have received is related to the communication error. Futher, if you use same USB- Parallel cable for long time the Printer Hardware functionality might go bad, since Printer memory gets confused and will not read or detect the Cable , since it is not a cable to use  mentioned by Panasonic Manufacturer.
Let me tell you, general functionality of Printer like Printing would work even if you use USB-Parallel cable. But it is not a case with Scanner and Fax functionality.
Hence, I recommend you to use only Parallel cable to connect your Printer to the Laptops.
I hope that this will resolve the issue for you.
You can email me at thumuvikram@rediffmail.com if you need further assistance.
Bye.
Oct 17, 2007 | BafoTech BAFO BF-1284 Parallel Adapter
POSX POS-X XR-500 Printer Logo
64 people viewed this question
Top POSX Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a POSX Office Equipment and Supply Expert? Answer questions, earn points and help others
