Question about Microsoft Xbox 360 Controller
Xbox 360 controler disconnects while playing
I was playin cod 5 when my controler terned off so i turned it on again and this went on for a while please help
  • afly_513 May 11, 2010
    now I have a question. is it a wired or wireless controller because I may be able to help you.
  • 20 Answers
Check your batteries and if that doesent help try going on to setting and go to controller wireless setting or something related to that and look for hook up options and try messing around with the hook up options see where you get from there if nothing happens write back
Posted on Mar 03, 2009
I just bought this new game, COD;Black Ops, for my Xbox 360 Elite, put in n went straight to kill zombies, did 1 mission, and my console froze, I shut it off for a bit, took game out, restarted it, played...
this occur because your xbox might hav been lower verstion u try upgrading it and also check with memory status..is all where good only problem is with xbox means try this site
Dec 13, 2010 | Microsoft Xbox 360 Console
My xbox 360 carnt read my discs that well i carnt play 3 levels on my xbox for cod 5 but my friend can play all levels and runs alot faster
Could be a laser problem call microsoft and tell them the issue, They will most likely tell you to send it in to be fixed. If you do not have a warranty this can cost 90USD.
Jan 31, 2010 | Microsoft Xbox 360 Controller
Xbox 360 controller turns off at random, yet has new batteries
The battery indicator found when pressing your xbox logo button is temperamental. It might say 2 bars, or 3 or even full battery but this is not a good indicator of a full battery.
The problem IS low batteries(or more specifically - bad batteries) - when the batteries become low the vibration function can cause the controller to disconnect. This is happens because the vibration function uses extra battery power.
So basically... Every time your controller vibrates, it disconnects. This occurs when firing a weapon in most games, grenades in COD, landing heavy tricks in Skate 2, the list goes on, you'll find many complaints from people stating their controller disconnects specifically with these events.
The simple solution, turn off the vibration function when this occurs. It'll never happen to you again ^_^
Thumbs this up when it proves correct for you. I'd recommend a recharge while you play pack. ALWAYS by the official products too. They're much more reliable and aren't prone to this kind of behaviour.
Jun 26, 2009 | Microsoft Xbox 360 Controller
Xbox 360 Blurry/Fuzzy Screen
This means its most likely over heating and the GPU is on its way out...
you can try using a diffrent cable see if this helps.
if not contact microsoft as they now have 3 years warrenty on them :)
thanks
alex
Apr 06, 2009 | Microsoft Xbox 360 Console
My xbox 360 freezes when playing online
The G.P.U is starting to desolder from the
main board . The fix is an X clamp Mod
100% solid fix, no kiding.
more info
www.all-xboxrepair.com
Mar 17, 2009 | Microsoft Xbox 360 Halo 3 Special Edition...
My xbox 360 wont turn on
ok this is wat im doing with my xbox i plug it in and it wont tern on
how do i fix it
Feb 22, 2009 | Microsoft Xbox 360 Console
COD server disconnect with wireless adapter
Its to do with your router, every now and again your router settings will turn to strict, as you proberly not usings a xbox compatible router, dont worry not many people do, i dont neither.
All you have to do is just turn off the router for 30secs and turn it back on, this will allow you to play on live again.
Personally if you can, connect it to the routher via a ethernet cable, it provided a much faster connection.
Controler connects but disconnects later
COD 5 is a great game, but on to the problem...
...the controller connects and disconnects because of two main reasons:
1:The XBOX port has been worn or tampered with.
2:The controller plugin has small metal prongs, which can be bent and not connect propely or disconnect from movement of system or cord.
Hope this helps You! (need a new controller or try blowing into both ports)
Feb 17, 2009 | Microsoft Xbox 360 Controller
Help me please !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Sounds like an electrical short in xboxs usb port.
check the brick if it has a red light you need a new brick. if not, try unplug the controller from the console and remove the faceplate and try turn it on.
sorry if i cant be more help.
alex
Jul 10, 2008 | Microsoft Xbox 360 Console
3 flashing red lights
Have you tried unplug the system then turning it back on
if not you may need it repaired
https://service.xbox.com/servicehome.aspx
Dec 18, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Controller Logo
104 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
