Question about Whirlpool LER7646E Dryer
DRYER WILL NOT WORK
My Whirlpool dryer has stopped working. It will not turn on at all. The model # is LET7646EQ2
  • 188 Answers
First check the electrical panel to your house. If it's a fuse panel check the fuses. If it's a breaker panel, reset it by flicking it off, then back on (do this even if it looks like it's already on).
If the dryer still doesn't work...
1) Check the door switch by pressing it in and listening for a clicking sound as you do so. If the door switch actuator spring is broken or if there is no click, replace the door switch assembly. This is done by removing the 2 screws under the lint trap screen and lifting the cabinet top. From there you can access the door switch. REMEMBER TO UNPLUG THE DRYER! You can also use a jumper wire on the door switch to verify it's function (unplug the door switch and connect a jumper wire to the 2 wires going to the console.
2) Check for a broken belt by lifting the cabinet top and visually inspecting the belt or by manually turning the drum from the inside (you should feel resistance or hear the motor turning).
3) Unplug the dryer and remove the back panel. On the heater housing remove the wires from the thermal cut-off and high limit thermostat and check the resistance with an ohm meter. If either of them are open (no reading) replace both (they come as a kit).
3) If everything checks out so far it may be the timer.
Posted on Feb 17, 2009
Whirlpool Dryer Motor 3395652
What is the complete model number of your unit?
Dec 03, 2012 | Kenmore 3976707 3395652 Whirlpool Dryer...
Our dryer stopped working last week. We were drying a load and when we returned the dryer was very hot on the outside (more than normal) and the button to turn it on no longer worked. There is power to...
There is a in line thermal fuse that is in the machine near the heating element that has probably burned out from overheating replace the thermal fuse and check your vent pipe for clogs and or kinks that cause the machine to overheat.
Mar 08, 2010 | Whirlpool WED5500S Electric Dryer
My whirlpool dryer stopped working today and will not put out any heat, do you know what might be the cause? Model # leq9858pwo
Short answer if the dryer drum still runs, but there is no heat: 90% it's one or both of the heating coils. 10% it's the control switch or relay.
If the dryer will still start and the drum will still turn, find instructions for how to test the heating coils. The test for the coils must be done with the dryer UNPLUGGED! It will involve taking a panel off the dryer.
Nov 24, 2009 | Whirlpool Dryers
Dryer Not Tumbling
Sounds like belt problems.
Jan 20, 2009 | Whirlpool LER5636P Electric Dryer
WHIRLPOOL DRYER GGW9200LW1 My whirlpool GGW0200LW1 dryer stopped
Reach inside and try to turn the drum by hand, it should have some resistance, if it spins free, you may have a broken belt or it fell off. There is a switch on many dryer that is attatched to the motor. If the belt breaks it triggers the switch which disables the motor and heater on the dryer. Also double check that model #, Im not finding anything under that #. thanks Dave www.washermd.com
Dec 13, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool Electric Dryer stop working
could be a bad motor , or the starter on the motor.?? if you can hear the motor running then go for a new belt..
Jun 13, 2008 | Dryers
Dryers Logo
171 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De GO PATS
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
