Question about Microsoft Xbox 360 Controller
Controler connects but disconnects later
I was playin cod 5 and my controler disconnected so i reconnected it but it just did it again
  • Anonymous Feb 19, 2009
    jordan it isnt the solution, i have the same problem and it only goes on CoD 5
    Problem Solver:
  • 8 Answers
COD 5 is a great game, but on to the problem...
...the controller connects and disconnects because of two main reasons:
1:The XBOX port has been worn or tampered with.
2:The controller plugin has small metal prongs, which can be bent and not connect propely or disconnect from movement of system or cord.
Hope this helps You! (need a new controller or try blowing into both ports)
Posted on Feb 18, 2009
Cod F-06
F-06 Drive motor Tachometer error
Possible causes/procedure:
1. Verify the shipping system including shipping bolts, spacers
and cables are removed.
2. Unplug washer or disconnect power.
3. Check wire harness connections between the drive motor and
the Motor Control Unit (MCU), and between the MCU and the
Central Control Unit (CCU).
4. Plug in washer or reconnect power.
5. Check the MCU by looking for operations of the drive motor.
6. Check the drive motor for powered rotations.
View the entire tech sheet here
Sep 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Computer says printer is busy - try later I can't see why it's busy.
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
Aug 21, 2011 | Lexmark X1270 All-In-One InkJet Printer
Sony Walkman NWZ-E438F connects & disconnects itself from USB
I suggest that you uninstall and reinstall the USB Driver to resolve the issue.
Follow these steps to uninstall the driver and confirm the player is recognized properly.
IMPORTANT:
  • This procedure must be performed while logged in as Administrator or to an account with Administrator rights.
  • If you are using the Windows® XP operating system, you must have Service Pack 2 or later installed.
  1. Click Start and then click Control Panel .
  2. In the Control Panel window, click Performance and Maintenance .
  3. In the Performance and Maintenance window, click System .
  4. In the System Properties window, click the Hardware tab.
  5. On the Hardware tab, under Device Manager , click the Device Manager button.
  6. In the Device Manager window, click the plus (+) sign in front of Disk drives .
  7. Click to select the Sony USB device .
  8. From the menu, click Action and then click Uninstall .
  9. In the Confirm Device Removal box, click OK .
  10. Disconnect the portable player from the computer.
  11. In the System Settings Change box, click Yes.
After that, restart the computer and reconnect the Player to resolve the issue. USB Drivers are generic to the Operating System and will reinstall automatically after restarting the computer. I hope it works.
Sep 22, 2009 | Sony Walkman NWZ-A826 Digital Media Player
Wireless controllers for xbox 360 disconnect at random times
It sounds like there is a probem with the RF Board (google search it). Problems occur with this from time to time when a sytem is disassembled and reassembled.
Jul 18, 2009 | Microsoft Xbox 360 Controller
Works for approx 30 secs then it cuts off with a error Code F7 message.
Assuming yours is a model KHMS2050SSS0, here is what the technical sheet says about the F7 error code:
1. Unplug microwave oven or disconnect power.
2. After 40 seconds, check to see whether this solves the problem.
3. Unplug microwave oven or disconnect power.
4. Check cooling fan operation
5. Check the magnetron.
6. Check P65 connection on the relay control board.
7. Check the P56/P66 connection between relay board and relay control board.
8. Check wiring to the 1200W inverter and control system. See “Checking Inverters.”
9. Check operation of all interlock switches.
10. Replace all parts and panels before operating.
11. Plug in microwave oven or reconnect power.
12. Check voltage at 4903-1 on relay board. If it is 120, unplug microwave oven or disconnect power.
13. Replace inverter.
14. Replace all parts and panels before operating.
15. Plug in microwave oven or reconnect power.
16. If problem persists, unplug microwave oven or disconnect power.
17. Replace relay control board.
18. Replace all parts and panels before operating.
19. Plug in microwave oven or reconnect power.
20. If problem persists, unplug microwave oven or disconnect power.
21. Check for reversed plug connection on controls or loose wiring.
22. Replace all parts and panels before operating.
23. Plug in microwave oven or reconnect power.
(This troubleshooting guide presumes one does not know how to test electronic components. That's why they say to replace and part and check it again.)
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
If yours is a different model number, please reply back.
May 26, 2009 | KitchenAid KHMS2050SSS Microwave Oven
COD server disconnect with wireless adapter
Its to do with your router, every now and again your router settings will turn to strict, as you proberly not usings a xbox compatible router, dont worry not many people do, i dont neither.
All you have to do is just turn off the router for 30secs and turn it back on, this will allow you to play on live again.
Personally if you can, connect it to the routher via a ethernet cable, it provided a much faster connection.
Feb 22, 2009 | Microsoft Xbox 360 Console
Xbox 360 controler disconnects while playing
check your batteries and if that doesent help try going on to setting and go to controller wireless setting or something related to that and look for hook up options and try messing around with the hook up options see where you get from there if nothing happens write back
Feb 17, 2009 | Microsoft Xbox 360 Controller
Staying connected to Live
it a problem with your internet provider i had the same prolem all i did was call them and tell them your being disconnected and the hsould be able to start you up again also tell them if you have a rrouter connnected as well
Oct 20, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Controller Logo
336 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
