Washing machine after water load the drum
Beko wm5140s washing machine, it will load the water to the drum then nothing else happen and oyher programme don't work either ie drain or spin
  • 121 Answers
Must check water level device,if You do not know what is this or where is on machine then call a service.Maybe is hose is precipitate from device.
Posted on Feb 17, 2009
Which button is the fast wash button on beko washing machine model WM5140s
Hi balogun
I could not add this with the link button but hope this helps
Jun 06, 2016 | Beko Washing Machines
How hard is to replace a heater element on a BEKO wm5140s washing machine! cheers Brian
Fairly easy.disconnect mains drain any surplus water via drain bottom front of machine.access to the heating element is from below so tip machine from one side against wall at45degrees.... I normally use a towel on bottom edge to stop it sliding whilst I unscrew any bottom will see the heating element housed at the base of drum unit.disconnect wires and unbolt or unscrew element housing .youtube has tutorials on this but many machines are similar in thus respect.good luck
Jan 29, 2015 | Beko Washing Machines
Have Beko WME7247W Washing Machine problem. On full wash the mc loads water then stops. Timer does not progress. Water does not heat. Drum does not turn. On Spin and Drain cycle pump works but spin does...
I had a similar sort of problem, and finally called a Beko engineer out. The machine was pushed too far back and had either blocked the water pipe, or waste pipe.... can't remember which, but simply pulling the machine out by an inch cured the problem!
Mar 09, 2014 | Beko WME7247W Washing Machine
Water leaking from outer plastic drum on beko washing machine found 2 small hole what is the best thing to stop leak
A poxy plastic sealant but you may get lucky call around get a good used drum at a repair shop.
Mar 05, 2014 | Beko Washing Machines
Beko washing machine stuck midcylce full of water nothing happening?
Hi ghutton697,
I believe your drain motor is not draining the water. This has to happen before your unit will go to the spin cycle.
Please read the following tip, on how to clean the filter (It might just be an obstruction of some kind)
If this does not help, you might need to replace the drain pump - as it may have become defective.
Kind Regards
* I really hope this solution helped you, if it did please rate it.
Jul 14, 2011 | Asko 8005 Front Load Washing Machine
Washing Machines Logo
331 people viewed this question
Top Washing Machines Experts
