Roxio easy VHS to DVD crashes and audio is not recognized
  • 11 more comments
  • eugenehanks Feb 17, 2009
    Already reloaded with clean install twice still no change
    did that already with no change in fact I tried Roxios online support and did everything they said until I agave up on them
    My computer is OK. This is new software that I just purchased from Costco The Roxio software has not worked ever from the getgo
    THIS IS A PROBLEM YOU WILL NEED TO READ AND CONSIDER CAREFULLY PLEASE----THIS IS WHAT I HAVE DONE SO FAR
    ---Updated to the latest version of Direct X
    ---Update video drivers
    ---Created a new user account with full admin rights in the control panel and rebooted the computer and logged in under the new user account and reinstalled.
    HERE IS A COPY OF MY "dxdiag".
    System Information
    Time of this report: 2/17/2009, 11:44:15
    Machine name: EUGENE-PC
    Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 3 (2600.xpsp_sp3_gdr.080814-1236)
    Language: English (Regional Setting: English)
    System Manufacturer: NVIDIA
    System Model: AWRDACPI
    BIOS: )Phoenix - Award WorkstationBIOS v6.00PG
    Processor: AMD Athlon(tm) 64 X2 Dual Core Processor 3800+, MMX, 3DNow (2 CPUs), ~2.0GHz
    Memory: 1024MB RAM
    Page File: 447MB used, 4318MB available
    Windows Dir: C:\WINDOWS
    DirectX Version: DirectX 9.0c (4.09.0000.0904)
    DX Setup Parameters: Not found
    DxDiag Version: 5.03.2600.5512 32bit Unicode
    DxDiag Notes
    DirectX Files Tab: No problems found.
    Display Tab 1: No problems found.
    Sound Tab 1: No problems found.
    Music Tab: No problems found.
    Input Tab: No problems found.
    Network Tab: No problems found.
    DirectX Debug Levels
    Direct3D: 0/4 (n/a)
    DirectDraw: 0/4 (retail)
    DirectInput: 0/5 (n/a)
    DirectMusic: 0/5 (n/a)
    DirectPlay: 0/9 (retail)
    DirectSound: 0/5 (retail)
    DirectShow: 0/6 (retail)
    Display Devices
    Card name: RADEON 8500 SERIES
    Manufacturer: ATI Technologies Inc.
    Chip type: RADEON 8500 AIW AGP (0x4242)
    DAC type: Internal DAC(400MHz)
    Device Key: Enum\PCI\VEN_1002&DEV_4242&SUBSYS_02AA1002&REV_00
    Display Memory: 64.0 MB
    Current Mode: 1152 x 864 (32 bit) (60Hz)
    Monitor: SyncMaster 225BW(Analog)
    Monitor Max Res: 1680,1050
    Driver Name: ati2dvag.dll
    Driver Version: 6.14.0010.6614 (English)
    DDI Version: 9 (or higher)
    Driver Attributes: Final Retail
    Driver Date/Size: 5/3/2006 08:51:00, 258048 bytes
    WHQL Logo'd: Yes
    WHQL Date Stamp: n/a
    VDD: n/a
    Mini VDD: ati2mtag.sys
    Mini VDD Date: 5/3/2006 08:50:42, 1540608 bytes
    Device Identifier: {D7B71EE2-0102-11CF-646A-A022A1C2CB35}
    Vendor ID: 0x1002
    Device ID: 0x4242
    SubSys ID: 0x02AA1002
    Revision ID: 0x0000
    Revision ID: 0x0000
    Video Accel:
    Deinterlace Caps: n/a
    Registry: OK
    DDraw Status: Enabled
    D3D Status: Enabled
    AGP Status: Not Available
    DDraw Test Result: Not run
    D3D7 Test Result: Not run
    D3D8 Test Result: Not run
    D3D9 Test Result: Not run
    Sound Devices
    Description: Realtek AC97 Audio
    Default Sound Playback: Yes
    Default Voice Playback: Yes
    Hardware ID: PCI\VEN_10DE&DEV_0059&SUBSYS_82041565&REV_A2
    Manufacturer ID: 1
    Product ID: 100
    Type: WDM
    Driver Name: ALCXWDM.SYS
    Driver Version: 5.10.0000.6300 (English)
    WHQL Logo'd: Yes
    Date and Size: 9/24/2008 09:40:22, 4122368 bytes
    Other Files:
    Driver Provider: Realtek Semiconductor Corp.
    HW Accel Level: Full
    Cap Flags: 0xF5F
    Min/Max Sample Rate: 8000, 192000
    Static/Strm HW Mix Bufs: 26, 25
    Static/Strm HW 3D Bufs: 26, 25
    HW Memory: 0
    Voice Management: No
    EAX(tm) 2.0 Listen/Src: Yes, Yes
    I3DL2(tm) Listen/Src: Yes, Yes
    Sensaura(tm) ZoomFX(tm): No
    Registry: OK
    Sound Test Result: Not run
    Sound Capture Devices
    Description: USB 2861 Device
    Default Sound Capture: Yes
    Default Voice Capture: Yes
    Driver Name: usbaudio.sys
    Driver Version: 5.01.2600.5512 (English)
    Date and Size: 4/13/2008 11:45:12, 60032 bytes
    Cap Flags: 0x41
    Format Flags: 0xCCC
    Default Sound Capture: No
    Default Voice Capture: No
    Cap Flags: 0x41
    Format Flags: 0xFFF
    DirectMusic
    DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
    DLS Version: 1.00.0016.0002
    Acceleration: n/a
    Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
    Realtek AC97 Audio, Software (Kernel Mode), Output, DLS, Internal
    Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
    Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
    Registry: OK
    DirectInput Devices
    Device Name: Mouse
    Attached: 1
    Controller ID: n/a
    Vendor/Product ID: n/a
    FF Driver: n/a
    Device Name: Keyboard
    Attached: 1
    Controller ID: n/a
    FF Driver: n/a
    Device Name: Microsoft Wireless Optical Mouse® 1.0A
    Attached: 1
    Controller ID: 0x0
    Vendor/Product ID: 0x045E, 0x006A
    FF Driver: n/a
    Poll w/ Interrupt: No
    Registry: OK
    USB Devices
    + USB Root Hub
    | Vendor/Product ID: 0x10DE, 0x005A
    | Matching Device ID: usb\root_hub
    | Service: usbhub
    | Driver: usbhub.sys, 4/13/2008 10:45:38, 59520 bytes
    | Driver: usbd.sys, 7/27/2007 04:00:00, 4736 bytes
    +-+ USB Human Interface Device
    | | Matching Device ID: usb\class_03&subclass_01
    | | Service: HidUsb
    | | Driver: hidusb.sys, 4/13/2008 10:45:28, 10368 bytes
    | | Driver: hidclass.sys, 4/13/2008 10:45:26, 36864 bytes
    | | Driver: hidparse.sys, 4/13/2008 10:45:22, 24960 bytes
    | | Driver: hid.dll, 4/13/2008 16:11:54, 20992 bytes
    | +-+ HID-compliant consumer control device
    | | | Matching Device ID: hid_device_up:000c_u:0001
    | | | Driver: hidserv.dll, 4/13/2008 16:11:54, 21504 bytes
    | +-+ Microsoft USB Wireless Optical Mouse (IntelliPoint)
    | | | Matching Device ID: hid\vid_045e&pid_006a&col01
    | | | Upper Filters: Point32
    | | | Service: mouhid
    | | | Driver: mouhid.sys, 8/17/2001 12:48:00, 12160 bytes
    | | | Driver: mouclass.sys, 4/13/2008 10:39:48, 23040 bytes
    | | | Driver: point32.sys, 12/1/2005 14:57:58, 21760 bytes
    | | | Driver: ipcoin7.dll, 12/4/2005 15:38:16, 133904 bytes
    Gameport Devices
    PS/2 Devices
    + Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
    | Matching Device ID: *pnp0303
    | Service: i8042prt
    | Driver: i8042prt.sys, 4/13/2008 11:18:00, 52480 bytes
    | Driver: kbdclass.sys, 4/13/2008 10:39:48, 24576 bytes
    + Terminal Server Keyboard Driver
    | Matching Device ID: root\rdp_kbd
    | Upper Filters: kbdclass
    | Service: TermDD
    | Driver: termdd.sys, 4/13/2008 16:13:20, 40840 bytes
    + Terminal Server Mouse Driver
    | Matching Device ID: root\rdp_mou
    | Upper Filters: mouclass
    | Service: TermDD
    DirectPlay Service Providers
    DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
    DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
    DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
    DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.5512)
    Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.5512)
    IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.5512)
    Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.5512)
    Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.5512)
    DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
    DirectPlay Test Result: Not run
    Registry: OK
    DirectPlay Adapters
    DirectPlay8 Serial Service Provider: COM1
    DirectPlay8 TCP/IP Service Provider: Local Area Connection - IPv4 -
    DirectPlay Voice Codecs
    Voxware VR12 1.4kbit/s
    Voxware SC06 6.4kbit/s
    Voxware SC03 3.2kbit/s
    MS-PCM 64 kbit/s
    MS-ADPCM 32.8 kbit/s
    Microsoft GSM 6.10 13 kbit/s
    TrueSpeech(TM) 8.6 kbit/s
    DirectPlay Lobbyable Apps
    Disk & DVD/CD-ROM Drives
    Drive: C:
    Free Space: 175.3 GB
    Total Space: 305.2 GB
    File System: NTFS
    Model: WDC WD3200JB-00KFA0
    Drive: E:
    Free Space: 23.6 GB
    Total Space: 38.2 GB
    File System: NTFS
    Model: MAXTOR 6L040J2
    Drive: D:
    Model: SONY DVD RW AW-Q170A
    Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.5512 (English), 4/13/2008 10:40:46, 62976 bytes
    System Devices
    Name: nForce HyperTransport Bridge
    Device ID: PCI\VEN_10DE&DEV_005E&SUBSYS_34021565&REV_A3\3&2411E6FE&0&00
    Driver: n/a
    Name: nForce4 PCI-Express Root Port
    Device ID: PCI\VEN_10DE&DEV_005D&SUBSYS_00000000&REV_A3\3&2411E6FE&0&70
    Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.5512 (English), 4/13/2008 10:36:44, 68224 bytes
    Device ID: PCI\VEN_10DE&DEV_005D&SUBSYS_00000000&REV_A3\3&2411E6FE&0&68
    Device ID: PCI\VEN_10DE&DEV_005D&SUBSYS_00000000&REV_A3\3&2411E6FE&0&60
    Device ID: PCI\VEN_10DE&DEV_005D&SUBSYS_00000000&REV_A3\3&2411E6FE&0&58
    Name: PCI standard PCI-to-PCI bridge
    Device ID: PCI\VEN_10DE&DEV_005C&SUBSYS_00000000&REV_A2\3&2411E6FE&0&48
    Name: Standard Enhanced PCI to USB Host Controller
    Device ID: PCI\VEN_10DE&DEV_005B&SUBSYS_34021565&REV_A3\3&2411E6FE&0&11
    Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.5512 (English), 4/13/2008 10:45:36, 30208 bytes
    Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.5512 (English), 4/13/2008 10:45:36, 143872 bytes
    Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.5512 (English), 4/13/2008 16:12:08, 74240 bytes
    Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.5512 (English), 4/13/2008 10:45:38, 59520 bytes
    Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.5512 (English), 4/13/2008 16:11:54, 7168 bytes
    Name: Standard OpenHCD USB Host Controller
    Device ID: PCI\VEN_10DE&DEV_005A&SUBSYS_34021565&REV_A2\3&2411E6FE&0&10
    Driver: C:\WINDOWS\system32\drivers\usbohci.sys, 5.01.2600.5512 (English), 4/13/2008 10:45:36, 17152 bytes
    Name: Realtek AC'97 Audio
    Device ID: PCI\VEN_10DE&DEV_0059&SUBSYS_82041565&REV_A2\3&2411E6FE&0&20
    Driver: C:\WINDOWS\system32\ksuser.dll, 5.03.2600.5512 (English), 4/13/2008 17:11:56, 4096 bytes
    Driver: C:\WINDOWS\system32\ksproxy.ax, 5.03.2600.5512 (English), 4/13/2008 17:12:42, 129536 bytes
    Driver: C:\WINDOWS\system32\drivers\ks.sys, 5.03.2600.5512 (English), 4/13/2008 12:16:36, 141056 bytes
    Driver: C:\WINDOWS\system32\drivers\drmk.sys, 5.01.2600.5512 (English), 4/13/2008 10:45:14, 60160 bytes
    Driver: C:\WINDOWS\system32\drivers\portcls.sys, 5.01.2600.5512 (English), 4/13/2008 11:19:42, 146048 bytes
    Driver: C:\WINDOWS\system32\drivers\stream.sys, 5.03.2600.5512 (English), 4/13/2008 10:45:16, 49408 bytes
    Driver: C:\WINDOWS\system32\wdmaud.drv, 5.01.2600.5512 (English), 4/13/2008 16:12:46, 23552 bytes
    Driver: C:\WINDOWS\system32\drivers\ALCXWDM.SYS, 5.10.0000.6300 (English), 9/24/2008 09:40:22, 4122368 bytes
    Driver: C:\WINDOWS\SOUNDMAN.EXE, 5.01.0000.0059 (English), 4/16/2007 14:28:22, 577536 bytes
    Driver: C:\WINDOWS\system32\ALSNDMGR.CPL, 2.02.0000.0073 (English), 11/17/2006 04:40:46, 18804736 bytes
    Driver: C:\WINDOWS\system32\ALSNDMGR.WAV, 2/5/2002 12:54:58, 141016 bytes
    Driver: C:\WINDOWS\system32\RTLCPL.EXE, 1.00.0001.0066 (English), 12/8/2006 14:20:14, 10528768 bytes
    Driver: C:\WINDOWS\system32\RTLCPAPI.dll, 1.00.0001.0004 (English), 10/18/2006 01:53:26, 147456 bytes
    Driver: C:\WINDOWS\Alcrmv.exe, 2.00.0000.0004 (English), 7/31/2006 10:27:30, 217088 bytes
    Name: NVIDIA Network Bus Enumerator
    Device ID: PCI\VEN_10DE&DEV_0057&SUBSYS_25011565&REV_A3\3&2411E6FE&0&50
    Driver: C:\WINDOWS\system32\DRIVERS\nvnetbus.sys, 1.00.0000.5025 (English), 4/14/2006 19:09:06, 13056 bytes
    Driver: C:\WINDOWS\system32\DRIVERS\nvnrm.sys, 1.00.0003.5025 (English), 4/14/2006 19:08:46, 305152 bytes
    Driver: C:\WINDOWS\system32\DRIVERS\nvsnpu.sys, 1.00.0000.5025 (English), 4/14/2006 19:08:32, 222720 bytes
    Driver: C:\WINDOWS\system32\bdco1.dll, 1.00.0000.0000 (English), 4/14/2006 19:07:28, 9728 bytes
    Driver: C:\WINDOWS\system32\bdco1ins.dll, 1.00.0000.0000 (English), 4/14/2006 19:07:28, 9728 bytes
    Driver: C:\WINDOWS\system32\nvconrm.dll, 1.00.0000.0035 (English), 3/14/2006 20:45:22, 35840 bytes
    Name: NVIDIA nForce Serial ATA Controller
    Device ID: PCI\VEN_10DE&DEV_0055&SUBSYS_54011565&REV_F3\3&2411E6FE&0&40
    Driver: C:\WINDOWS\system32\DRIVERS\nvgts.sys, 10.03.0000.0042 (English), 8/18/2008 17:54:00, 145952 bytes
    Driver: C:\WINDOWS\system32\nvraidco.dll, 10.03.0000.0042 (English), 8/18/2008 17:54:00, 372256 bytes
    Driver: C:\WINDOWS\system32\nvraiins.dll, 10.03.0000.0042 (English), 8/18/2008 17:54:00, 372256 bytes
    Driver: C:\WINDOWS\system32\NvRCoAr.dll, 10.03.0000.0042 (Arabic), 8/18/2008 17:54:00, 15904 bytes
    Driver: C:\WINDOWS\system32\NvRCoCs.dll, 10.03.0000.0042 (Czech), 8/18/2008 17:54:00, 15904 bytes
    Driver: C:\WINDOWS\system32\NvRCoDa.dll, 10.03.0000.0042 (Danish), 8/18/2008 17:54:00, 16416 bytes
    Driver: C:\WINDOWS\system32\NvRCoDe.dll, 10.03.0000.0042 (German), 8/18/2008 17:54:00, 16416 bytes
    Driver: C:\WINDOWS\system32\NvRCoEl.dll, 10.03.0000.0042 (Greek), 8/18/2008 17:54:00, 16928 bytes
    Driver: C:\WINDOWS\system32\NvRCoEng.dll, 10.03.0000.0042 (English), 8/18/2008 17:54:00, 15904 bytes
    Driver: C:\WINDOWS\system32\NvRCoENU.dll, 10.03.0000.0042 (English), 8/18/2008 17:54:00, 15904 bytes
    Driver: C:\WINDOWS\system32\NvRCoEs.dll, 10.03.0000.0042 (Spanish), 8/18/2008 17:54:00, 16928 bytes
    Driver: C:\WINDOWS\system32\NvRCoEsm.dll, 10.03.0000.0042 (Spanish), 8/18/2008 17:54:00, 16928 bytes
    Driver: C:\WINDOWS\system32\NvRCoFi.dll, 10.03.0000.0042 (Finnish), 8/18/2008 17:54:00, 16416 bytes
    Driver: C:\WINDOWS\system32\NvRCoFr.dll, 10.03.0000.0042 (French), 8/18/2008 17:54:00, 16928 bytes
    Driver: C:\WINDOWS\system32\NvRCoHe.dll, 10.03.0000.0042 (Hebrew), 8/18/2008 17:54:00, 15392 bytes
    Driver: C:\WINDOWS\system32\NvRCoHu.dll, 10.03.0000.0042 (Hungarian), 8/18/2008 17:54:00, 16416 bytes
    Driver: C:\WINDOWS\system32\NvRCoIt.dll, 10.03.0000.0042 (Italian), 8/18/2008 17:54:00, 16928 bytes
    Driver: C:\WINDOWS\system32\NvRCoJa.dll, 10.03.0000.0042 (Japanese), 8/18/2008 17:54:00, 14880 bytes
    Driver: C:\WINDOWS\system32\NvRCoKo.dll, 10.03.0000.0042 (Korean), 8/18/2008 17:54:00, 14368 bytes
    Driver: C:\WINDOWS\system32\NvRCoNl.dll, 10.03.0000.0042 (Dutch), 8/18/2008 17:54:00, 16416 bytes
    Driver: C:\WINDOWS\system32\NvRCoNo.dll, 10.03.0000.0042 (Norwegian (Bokm?l)), 8/18/2008 17:54:00, 16416 bytes
    Driver: C:\WINDOWS\system32\NvRCoPl.dll, 10.03.0000.0042 (Polish), 8/18/2008 17:54:00, 16416 bytes
    Driver: C:\WINDOWS\system32\NvRCoPt.dll, 10.03.0000.0042 (Portuguese), 8/18/2008 17:54:00, 16928 bytes
    Driver: C:\WINDOWS\system32\NvRCoPtb.dll, 10.03.0000.0042 (Portuguese), 8/18/2008 17:54:00, 16928 bytes
    Driver: C:\WINDOWS\system32\NvRCoRu.dll, 10.03.0000.0042 (Russian), 8/18/2008 17:54:00, 16416 bytes
    Driver: C:\WINDOWS\system32\NvRCoSk.dll, 10.03.0000.0042 (Slovak), 8/18/2008 17:54:00, 16416 bytes
    Driver: C:\WINDOWS\system32\NvRCoSl.dll, 10.03.0000.0042 (Slovenian), 8/18/2008 17:54:00, 16416 bytes
    Driver: C:\WINDOWS\system32\NvRCoSv.dll, 10.03.0000.0042 (Swedish), 8/18/2008 17:54:00, 16416 bytes
    Driver: C:\WINDOWS\system32\NvRCoTh.dll, 10.03.0000.0042 (Thai), 8/18/2008 17:54:00, 15904 bytes
    Driver: C:\WINDOWS\system32\NvRCoTr.dll, 10.03.0000.0042 (Turkish), 8/18/2008 17:54:00, 16416 bytes
    Driver: C:\WINDOWS\system32\NvRCoZhc.dll, 10.03.0000.0042 (Chinese), 8/18/2008 17:54:00, 13856 bytes
    Driver: C:\WINDOWS\system32\NvRCoZht.dll, 10.03.0000.0042 (Chinese), 8/18/2008 17:54:00, 13856 bytes
    Device ID: PCI\VEN_10DE&DEV_0054&SUBSYS_54011565&REV_F3\3&2411E6FE&0&38
    Name: NVIDIA CK804 Parallel ATA Controller (v2.7)
    Device ID: PCI\VEN_10DE&DEV_0053&SUBSYS_34021565&REV_F2\3&2411E6FE&0&30
    Driver: C:\WINDOWS\system32\DRIVERS\nvatabus.sys, 5.10.2600.0464 (English), 9/1/2004 22:24:38, 82816 bytes
    Driver: C:\WINDOWS\system32\idecoi.dll, 1.00.0000.0001 (English), 4/24/2006 16:52:30, 289792 bytes
    Name: NVIDIA nForce PCI System Management
    Device ID: PCI\VEN_10DE&DEV_0052&SUBSYS_34021565&REV_A2\3&2411E6FE&0&09
    Driver: C:\WINDOWS\system32\NVCOSMB.DLL, 1.03.0004.0028 (English), 8/20/2008 17:35:00, 122880 bytes
    Driver: C:\WINDOWS\system32\nvusmb.exe, 1.03.0016.0001 (English), 8/20/2008 17:35:00, 453152 bytes
    Driver: C:\WINDOWS\system32\nvsmb.nvu, 8/19/2008 10:41:00, 2344 bytes
    Name: PCI standard ISA bridge
    Device ID: PCI\VEN_10DE&DEV_0050&SUBSYS_00000000&REV_A3\3&2411E6FE&0&08
    Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.5512 (English), 4/13/2008 10:36:42, 37248 bytes
    Name: PCI standard host CPU bridge
    Device ID: PCI\VEN_1022&DEV_1103&SUBSYS_00000000&REV_00\3&2411E6FE&0&C3
    Driver: n/a
    Device ID: PCI\VEN_1022&DEV_1102&SUBSYS_00000000&REV_00\3&2411E6FE&0&C2
    Driver: n/a
    Device ID: PCI\VEN_1022&DEV_1101&SUBSYS_00000000&REV_00\3&2411E6FE&0&C1
    Driver: n/a
    Device ID: PCI\VEN_1022&DEV_1100&SUBSYS_00000000&REV_00\3&2411E6FE&0&C0
    Driver: n/a
    Name: RADEON 8500 SERIES
    Device ID: PCI\VEN_1002&DEV_4242&SUBSYS_02AA1002&REV_00\4&13699180&0&0048
    Driver: C:\WINDOWS\system32\DRIVERS\ati2mtag.sys, 6.14.0010.6614 (English), 5/3/2006 08:50:42, 1540608 bytes
    Driver: C:\WINDOWS\system32\DRIVERS\ati2erec.dll, 1.00.0000.0005 (English), 5/3/2006 08:10:34, 40960 bytes
    Driver: C:\WINDOWS\system32\DRIVERS\ativvpxx.vp, 5/3/2006 09:09:32, 28080 bytes
    Driver: C:\WINDOWS\system32\DRIVERS\ativckxx.vp, 10/14/2005 06:10:12, 58560 bytes
    Driver: C:\WINDOWS\system32\DRIVERS\ativcaxx.vp, 2/8/2006 12:44:04, 929 bytes
    Driver: C:\WINDOWS\system32\DRIVERS\ativcaxx.cpa, 2/8/2006 12:44:04, 1114674 bytes
    Driver: C:\WINDOWS\system32\ati2dvag.dll, 6.14.0010.6614 (English), 5/3/2006 08:51:00, 258048 bytes
    Driver: C:\WINDOWS\system32\ati2cqag.dll, 6.14.0010.0313 (English), 5/3/2006 08:09:20, 282624 bytes
    Driver: C:\WINDOWS\system32\Ati2mdxx.exe, 6.14.0010.2495 (English), 5/3/2006 08:45:14, 26112 bytes
    Driver: C:\WINDOWS\system32\ati3duag.dll, 6.14.0010.0399 (English), 5/3/2006 08:35:25, 2693280 bytes
    Driver: C:\WINDOWS\system32\ativvaxx.dll, 6.14.0001.0099 (English), 5/3/2006 08:29:12, 1408000 bytes
    Driver: C:\WINDOWS\system32\atiicdxx.dat, 4/28/2006 12:05:14, 127614 bytes
    Driver: C:\WINDOWS\system32\ATIDDC.DLL, 6.14.0010.0008 (English), 5/3/2006 08:43:14, 53248 bytes
    Driver: C:\WINDOWS\system32\atitvo32.dll, 6.14.0010.4200 (English), 5/3/2006 08:15:10, 17408 bytes
    Driver: C:\WINDOWS\system32\ativcoxx.dll, 6.13.0010.0005 (English), 5/23/2002 13:18:31, 24064 bytes
    Driver: C:\WINDOWS\system32\ati2evxx.exe, 6.14.0010.4132 (English), 5/3/2006 08:43:46, 413696 bytes
    Driver: C:\WINDOWS\system32\ati2evxx.dll, 6.14.0010.4132 (English), 5/3/2006 08:44:54, 61440 bytes
    Driver: C:\WINDOWS\system32\atipdlxx.dll, 6.14.0010.2498 (English), 5/3/2006 08:45:35, 114688 bytes
    Driver: C:\WINDOWS\system32\Oemdspif.dll, 6.14.0001.0016 (English), 5/3/2006 08:45:22, 77824 bytes
    Driver: C:\WINDOWS\system32\ati2edxx.dll, 6.14.0010.2500 (English), 5/3/2006 08:45:06, 41984 bytes
    Driver: C:\WINDOWS\system32\atikvmag.dll, 6.14.0010.0035 (English), 5/3/2006 08:15:58, 151552 bytes
    Driver: C:\WINDOWS\system32\ATIDEMGR.dll, 1.02.2314.20173 (English), 5/3/2006 08:12:26, 286720 bytes
    Driver: C:\WINDOWS\system32\atifglpf.xml, 1/25/2006 16:48:02, 6005 bytes
    Driver: C:\WINDOWS\system32\atioglxx.dll, 6.14.0010.5819 (English), 5/3/2006 08:18:04, 5033984 bytes
    Driver: C:\WINDOWS\system32\atioglx1.dll, 6.14.0010.1072 (English), 5/3/2006 08:21:20, 6684672 bytes
    Driver: C:\WINDOWS\system32\atiiiexx.dll, 6.14.0010.4004 (English), 5/3/2006 08:54:10, 307200 bytes
    DirectX Components
    ddraw.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:11:51 279552 bytes
    ddrawex.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:11:51 27136 bytes
    dxapi.sys: 5.01.2600.0000 English Final Retail 7/27/2007 04:00:00 10496 bytes
    d3d8.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:11:51 1179648 bytes
    d3d8thk.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:11:51 8192 bytes
    d3d9.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:11:51 1689088 bytes
    d3dim.dll: 5.01.2600.0000 English Final Retail 7/27/2007 04:00:00 436224 bytes
    d3dim700.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:11:51 824320 bytes
    d3dramp.dll: 5.01.2600.0000 English Final Retail 7/27/2007 04:00:00 590336 bytes
    d3drm.dll: 5.01.2600.0000 English Final Retail 7/27/2007 04:00:00 350208 bytes
    d3dxof.dll: 5.01.2600.0000 English Final Retail 7/27/2007 04:00:00 47616 bytes
    d3dpmesh.dll: 5.01.2600.0000 English Final Retail 7/27/2007 04:00:00 34816 bytes
    dplay.dll: 5.00.2134.0001 English Final Retail 7/27/2007 04:00:00 33040 bytes
    dplayx.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:11:52 229888 bytes
    dpmodemx.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:11:52 23552 bytes
    dpwsock.dll: 5.00.2134.0001 English Final Retail 7/27/2007 04:00:00 42768 bytes
    dpwsockx.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:11:52 57344 bytes
    dplaysvr.exe: 5.03.2600.5512 English Final Retail 4/13/2008 16:12:17 29696 bytes
    dpnsvr.exe: 5.03.2600.5512 English Final Retail 4/13/2008 16:12:17 17920 bytes
    dpnet.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:11:52 375296 bytes
    dpnlobby.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:09:20 3072 bytes
    dpnaddr.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:09:19 3072 bytes
    dpvoice.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:11:52 212480 bytes
    dpvsetup.exe: 5.03.2600.5512 English Final Retail 4/13/2008 16:12:18 83456 bytes
    dpvvox.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:11:52 116736 bytes
    dpvacm.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:11:52 21504 bytes
    dpnhpast.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:11:52 35328 bytes
    dpnhupnp.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:11:52 60928 bytes
    dpserial.dll: 5.00.2134.0001 English Final Retail 7/27/2007 04:00:00 53520 bytes
    dinput.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:11:52 158720 bytes
    dinput8.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:11:52 181760 bytes
    dimap.dll: 5.01.2600.0000 English Final Retail 7/27/2007 04:00:00 44032 bytes
    diactfrm.dll: 5.01.2600.0000 English Final Retail 7/27/2007 04:00:00 394240 bytes
    joy.cpl: 5.03.2600.5512 English Final Retail 4/13/2008 16:12:41 68608 bytes
    gcdef.dll: 5.01.2600.0000 English Final Retail 7/27/2007 04:00:00 76800 bytes
    pid.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:12:02 35328 bytes
    dsound.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:11:52 367616 bytes
    dsound3d.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:11:52 1293824 bytes
    dswave.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:11:52 19456 bytes
    dsdmo.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:11:52 181248 bytes
    dsdmoprp.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:11:52 71680 bytes
    dmusic.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:11:52 104448 bytes
    dmband.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:11:52 28672 bytes
    dmcompos.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:11:52 61440 bytes
    dmime.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:11:52 181248 bytes
    dmloader.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:11:52 35840 bytes
    dmstyle.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:11:52 105984 bytes
    dmsynth.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:11:52 103424 bytes
    dmscript.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:11:52 82432 bytes
    system.dll: 1.01.4322.2407 English Final Retail 5/14/2008 18:02:26 1232896 bytes
    Microsoft.DirectX.Direct3D.dll: 9.05.0132.0000 English Final Retail 2/9/2009 11:46:13 473600 bytes
    Microsoft.DirectX.Direct3DX.dll: 5.04.0000.3900 English Final Retail 2/9/2009 11:46:09 2676224 bytes
    Microsoft.DirectX.Direct3DX.dll: 9.04.0091.0000 English Final Retail 2/9/2009 11:46:10 2846720 bytes
    Microsoft.DirectX.Direct3DX.dll: 9.05.0132.0000 English Final Retail 2/9/2009 11:46:10 563712 bytes
    Microsoft.DirectX.Direct3DX.dll: 9.06.0168.0000 English Final Retail 2/9/2009 11:46:11 567296 bytes
    Microsoft.DirectX.Direct3DX.dll: 9.07.0239.0000 English Final Retail 2/9/2009 11:46:11 576000 bytes
    Microsoft.DirectX.Direct3DX.dll: 9.08.0299.0000 English Final Retail 2/9/2009 11:46:11 577024 bytes
    Microsoft.DirectX.Direct3DX.dll: 9.09.0376.0000 English Final Retail 2/9/2009 11:46:11 577536 bytes
    Microsoft.DirectX.Direct3DX.dll: 9.10.0455.0000 English Final Retail 2/9/2009 11:46:12 577536 bytes
    Microsoft.DirectX.Direct3DX.dll: 9.11.0519.0000 English Final Retail 2/9/2009 11:46:12 578560 bytes
    Microsoft.DirectX.Direct3DX.dll: 9.12.0589.0000 English Final Retail 2/9/2009 11:46:13 578560 bytes
    Microsoft.DirectX.DirectDraw.dll: 5.04.0000.2904 English Final Retail 2/9/2009 11:46:14 145920 bytes
    Microsoft.DirectX.DirectInput.dll: 5.04.0000.2904 English Final Retail 2/9/2009 11:46:14 159232 bytes
    Microsoft.DirectX.DirectPlay.dll: 5.04.0000.2904 English Final Retail 2/9/2009 11:46:14 364544 bytes
    Microsoft.DirectX.DirectSound.dll: 5.04.0000.2904 English Final Retail 2/9/2009 11:46:14 178176 bytes
    Microsoft.DirectX.AudioVideoPlayback.dll: 5.04.0000.2904 English Final Retail 2/9/2009 11:46:13 53248 bytes
    Microsoft.DirectX.Diagnostics.dll: 5.04.0000.2904 English Final Retail 2/9/2009 11:46:13 12800 bytes
    Microsoft.DirectX.dll: 5.04.0000.2904 English Final Retail 2/9/2009 11:46:12 223232 bytes
    dx7vb.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:11:52 619008 bytes
    dx8vb.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:11:52 1227264 bytes
    dxdiagn.dll: 5.03.2600.5512 English Final Retail 4/13/2008 16:11:52 2113536 bytes
    mfc40.dll: 4.01.0000.6140 English Final Retail 7/27/2007 04:00:00 924432 bytes
    mfc42.dll: 6.02.4131.0000 English Final Retail 4/13/2008 16:11:56 1028096 bytes
    wsock32.dll: 5.01.2600.5512 English Final Retail 4/13/2008 16:12:10 22528 bytes
    amstream.dll: 6.05.2600.5512 English Final Retail 4/13/2008 16:11:49 70656 bytes
    devenum.dll: 6.05.2600.5512 English Final Retail 4/13/2008 16:11:51 59904 bytes
    dxmasf.dll: 6.04.0009.1133 English Final Retail 4/13/2008 16:11:52 498742 bytes
    mciqtz32.dll: 6.05.2600.5512 English Final Retail 4/13/2008 16:11:56 35328 bytes
    mpg2splt.ax: 6.05.2600.5512 English Final Retail 4/1
    I am only using XP
    There is NO error message on the screen
    Already updated drivers and installed service pack
    I am using XP pro
    Here is what happens when I launch the program:
    I first click on "capture video" then I click on usb 2861 device with s-video input
    I get a picture but NO sound
    When I go to "x" out of the "Roxio import video" window it freezes up and the only thing I can do to unfreeze it is to reboot by shutting off power
    I have had seven tickets with Roxio and they have not helped
    Done everything guru said with no change
    My computer is working fine for all other programs --it is ONLY the Roxio easy VHS to DVD that does not work so I don't think I need to "system restore'
    I guess nobody can solve my problem
  • eugenehanks Feb 18, 2009
    I meet all the system requirements
    Still does not work
  • 126 Answers
Maybe software has been corrupted or you are using wrong format or wrong method to convert files
pls rate me
thankyou
Posted on Feb 18, 2009
  • vishal garg
    vishal garg Feb 19, 2009
    hey buddy,
    you are wasting your time here. You will find nothing here if it was that you can find
    answer here till now should have got the answer
    stop wasting time and go to audi with your cars papers and manual & spend money thats you can do
    stop wasting time buddy
    regards
  • vishal garg
    ofh sorry abt that line of audi actually i was giving advice to someone else but still dont waste time here i am telling you as a buddy
  • 1,800 Answers
Try to update ur sound card driver also check if ur system is messing some DLL files
Posted on Feb 17, 2009
    Master:
  • 474 Answers
What I have seen with alot of DVD programs on systems that have problems such as the ones you describe is due to that the Graphics processor allthough fast enough, doesnt have enough dedicated memory to buffer the DVD, so it has to read directly from the DVD while playing, this causes lag and choppiness and often crashing, especially with other programs open.
If you can, try a test out.
Download a movie or video from the internet or wherever, burn it onto a DVD and then also leave the original video file on the computer.
Play the DVD first, does it still do it? Probably.
Play the video file directly off your Hard drive, does it play fine?
If it does then what I mentioned above is correct and you would benefit from a better graphics card, especially since you have a good processor.
Another Gig of RAM would improve things, having 1 gig was alot 7 or 8 years ago, now its like the minimum. Windows will easily use 756MB or RAM just to operate normally.
When you upgrade, its best to upgrade everything or else the data bottlenecks like a congested 4 lane highway that suddenly drops to a 2 lane.
Let me know and good luck
  • 217 Answers
Kindly ensure the system meets the requirements:
Note:this is the basic requirement:
http://www.roxio.com/enu/products/easy-vhs-to-dvd/standard/requirements.html
If it does and the software is installed properly please check fro updates if any.and update the software coz the audio may not be recognized otherwise
  • Saroj Sharma
    Saroj Sharma Feb 18, 2009
    1. Launch Roxio Easy VHS to DVD.
    2. Go to Help -> Check for Updates
  • Saroj Sharma
    If you could also update the audio drivers on your system coz with time there could be issues with some dll files.
  • 6,784 Answers
Hi there, i found your main problem. You will have to install more mem. The mem you currently have installed isn't enough to maintain stability of your OS while roxio is enabled. Your current mem is (Memory: 1024MB RAM). This is not enough available memory for this specific roxio product and, when it dose crank up, you Xp stability will take a massive hit, therefore, causing a major crash or disorientation of system files. I recommend at least 3 gigs of mem if possible to combat and defeat this issue you are experiencing.
  • Michael Masters
    Michael Masters Feb 17, 2009
    You can actually free up some mem by going into the Windows task manager and, remove/disable unnecessary background software that may be running. this may help but, i suggest you upgrade to at least 3 gigs of mem to increase your stability during capture via/ roxio.
  • Michael Masters
    Memory: 1024MB RAM, that is your current memory read out. Windows Xp uses approximately 550mb of what you currently have on your CPU. This leaves you with 474mb available to run roxio. this is your issue. roxio need at least 512mb to run without crashing your entire system. This leads me to believe that you need more memory in order to use roxio software. A simple memory upgrade to about 3 gigs will completely dissolve this issue you are having. Once roxio starts, it sucks all memory that is available from windows itsefl, causing the crash.
    Sergeant:
  • 326 Answers
Http://forums.support.roxio.com/index.php?showtopic=48357
click the link and read the instruction as a client having the same problem like you at last solved his problem.by removing and re switching his usb connection .read full instructions and follow it carefully.
    Sergeant:
  • 250 Answers
Try doing system restore . this is the instruction to do system restore To use System Restore to restore Windows XP to a previous state, follow these steps:
  1. Log on to Windows as Administrator.
  2. Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore. System Restore starts.
  3. On the Welcome to System Restore page, click Restore my computer to an earlier time (if it is not already selected), and then click Next.
  4. On the Select a Restore Point page, click the most recent system restore point in theOn this list, click a restore point list, and then click Next.
    Note A System Restore message may appear that lists configuration changes that System Restore will make. Click OK.
  5. On the Confirm Restore Point Selection page, click Next. System Restore restores the previous Windows XP configuration, and then restarts the computer.
  6. Log on to the computer as Administrator. The System Restore Restoration Completepage is displayed.
  7. Click OK.
If you successfully restored your computer to a previous state, and the computer is performing as it should be, you are finished.
If the restore process completed successfully but the computer is still not performing as you want, go to the "How to undo a system restoration after you perform a System Restore" section. If you received an error message and the restore process did not finish, or if you cannot run System Restore, go to the "Next Steps" section.
How to undo a system restoration after you perform a System RestoreYou may have unintentionally restored Windows XP to a previous configuration that you do not want. To undo the restoration, follow these steps:
  3. On the Welcome to System Restore page, click Undo my last restoration, and then click Next.
  4. On the Confirm Restoration Undo page, click Next. System Restore restores the original Windows XP configuration, and then restarts the computer.
  5. Log on to the computer as Administrator. The System Restore Undo Complete page appears.
  6. Click OK. You can now run System Restore again from a different restore point.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
I suspect that you have tried most of the possible options. Here are a couple more to consider and do bear with me and try:
  • in your CMOS/BIOS, ensure that all are set to default;
  • increase size of Recycle Bin;
  • verify size of Swap File is at least double your on-board memory;
  • disable Power Management of all USB hubs;
  • perform a Disk Cleanup;
  • perform chkdsk /f;
  • defrag your hard drive;
  • temporarily disable your antivirus when performing the capture.
Would appreciate a postback/update on any developments. Good luck and thank you for using FixYa.
    President:
  • 2,110 Answers
  • 139 Answers
Your operating system which software are you using
  • Chetan Gupta Feb 17, 2009
    your operating system which software are you using
  • 15,935 Answers
Please be sure you OS is XP or Vista - and that the software will run on one or the other.
It will not work on both.
Thanks for using FixYa - a FixYa rating is appreciated!!
  • 679 Answers
Please explain some more about the problem??
  • rockfixya
    rockfixya Feb 17, 2009
    Ok......
    Tell me which operating System you are using,??
  • rockfixya
    It's Better to restore your operating System, instead of restoring it.
  • 544 Answers
Thank you for using Fixya.com.
try first to uninstall the program after thar re install.but make sure that the Ratio Disc is inserted.That's where the msi file will be.
If you downloaded the file you can always take the file and extract it to a folder,say on your desktop.That way when the repair looks for the msi file all you have to do is point it at the folder on your desktop.
check if there's somethng change and if it is working again properly.
if it is stll not working maybe your Ratio is already damage and hit some sensitive parts of the unit.
if you try this and still not working. we will go to the last option that is go to the repair shop and ask if they can still fix it..or buy a new one much better.
Hope i answer your question and give you a solution.
thanks,
  • 19,396 Answers
Do a system restore to a date before you started having the problem with Roxio, and eventually reinstall Roxio afterward.
    Brigadier General:
  • 8,619 Answers
Hi!
Try switching it off for 5 min.s. Is it showing any error?
    Brigadier General:
  • 3,614 Answers
Try re installing again the roxio software
  • micromaster
    micromaster Feb 17, 2009
    is there any error message appear on the screen?
    Top Expert:
  • Computers & ... Master
  • 77,194 Answers
Have u gone to the Roxio web site and clicked tech support and look for XP problems like u have, I have had great luck with this feature, u can also email them, they are free to use.
Bonjour, J'ai installer Roxio mais ne peut l'utilisé ! certicate_file_missing_or_corrupted Avez vous une solution ? adumas@primus.ca
I will be providing you a link which has a troubleshooting steps to resolve this issue. Make sure to follow the step carefully.
http://kb.roxio.com/search.aspx?URL=/content/000244CR&PARAMS=set-locale=en
The steps provided applies to Roxio Easy VHS to DVD software.
Cheers . . .
Nov 19, 2010 | Roxio Easy VHS to DVD for PC
Roxio Easy VHS to DVD will not install
Probably your version does not support your OS. Get the lates version from Roxio.
Jul 14, 2010 | Roxio Easy VHS to DVD for PC
Roxio 9 compatibility with windows 7
Roxio 9, Roxio Creator 9 and Roxio Creator 10 are different animals. Roxio 9 is 3 years old +. It likely will not handle 64bit or Windows 7.
Roxio Creater 9 is not listed as compatible with Windows 7
The following are from the Roxio site:
The following products have been designed to be Window 7 compatible (as of January 2010):
  • Roxio Creator 2010
  • Roxio Creator 2010 Plus
  • Roxio Creator 2010 Special Edition
  • Roxio Creator 2010 PRO
  • Roxio Easy LP to MP3
  • Roxio Burn
  • Roxio CinePlayer BD
The following products have been UPDATED to be Windows 7 compatible (as of January 2010):
  • Roxio Easy VHS to DVD
  • Roxio MyDVD 10 Premier
  • Roxio My DVD Video Lab 10
  • Roxio RecordNow Music Lab 10 Premier
  • Roxio Easy DVD Copy 4 Premier
  • Roxio Easy CD & DVD Burning
  • Roxio BackOnTrack 3 Suite
  • Roxio CinePlayer
Apr 04, 2010 | Roxio Easy Media Creator 9 Suite (227100)...
Computer does not recognize the usb. Installed software, started to capture video, then it quit and hasn't worked since Roxio Easy VHS to DVD for Mac
I am not sure what your program has to do with your USB drive. what system are you running?. You may need to uninstall the USB port in device manager and restart your pc and let windows detect it.
Nov 03, 2009 | Roxio Easy Media Creator 7
I can't install roxio easy vhs to dvd
Check out this knowledgebase article:
http://kb.roxio.com/search.aspx?URL=/content/kb/Creator/000214CR&PARAMS
May 13, 2009 | Roxio Easy VHS to DVD for PC
Roxio Cine Player Decoder Pack instalation package
Remove any older versions of Roxio or Sonic from the computer and do a clean install (uninstall then reinstall).
Mar 30, 2009 | Roxio Easy VHS to DVD for PC
Roxio Easy VHS to DVD install causes PC to hang up.
Do you have any other conflicting software or any other Roxio software? Any other Roxio or Sonic software will cause errors with Easy VHS to DVD.
It's also recommended to download the Service Pack from the Roxio.com site.
Mar 28, 2009 | Roxio Easy VHS to DVD for PC
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
