Question about Fujitsu (FMWKB4A) Keyboard
Connecting fujitsu fmwkb4a IR keyboard to fujitsu C-500 tablet PC
Lost owners manual for keyboard, C-500 manual dosen't cover keyboard. I need to press keys to connect to PC, can't remember which ones. Can you help?
Changing keyboard on Fujitsu T5010
Remove the square screw covers above the keyboard on either side of the swiveling screen hinge. Unscrew the 2 screws and use a small flat head screw driver to remove the plastic cover above the keyboard. Do this by inserting the screw driver underneath the plastic cover near to the f keys on the keyboard and gently pop the cover off. Carefully remove the ribbon from the motherboard, use a small screw driver to release the clip that holds the ribbon in place (ribbon located above f3,f4 keys). Slide the keyboard up and it should release if it doesn't then there may be some sticky tape holding the keyboard down, this is located behind the f2,f3,f4,f5 keys, carefully pull the keyboard away but hold the keyboard by the f keys so that you do not damage the keyboard by bending it. Reverse the procedure to fit new keyboard
May 28, 2010 | Fujitsu Siemens LifeBook T5010 Tablet PC
Need to replace lcd screen on a Fujitsu lt c500
Below is a link to tech support chat page for Fujitsu products. The Fujitsu site does offer a user manual, however, you need a service manual. Being a customer, you should be able to order a service manual for your notebook thru fujitsu. Here is the link for the chat page:
http://solutions.us.fujitsu.com/www/support.shtml?support/support_chat
Here is the link for the user manual:
http://support.fujitsupc.com/CS/Portal/supportsearch.do
This is a good place to start. I hope that you find this information helpful and will leave feedback to that effect if you do.
Thank You,
Brian
Jan 25, 2010 | Fujitsu Stylistic LT C-500 Tablet PC
Need owner's manual for Casio CTK-500 keyboard
I can help you with the manual. Here is a link:
CTK-500 Manual
I'll try to find an adapter. Are you in the US?
Use the Comment button to reply.
Thanks for using Fixya.
Jun 18, 2009 | Casio Portable Keyboard Touch Sensitive...
Keyboard Jiberish
It could also be the logic board. Usually, there are weep / drainage holes in the bottom of the laptop. See if there's any traces of moisture there, and you'll know if it got wet or not.
Sounds like it could have been wet. You could try replacing the keyboard.
May 19, 2009 | Fujitsu Siemens LIFEBOOK T4010D Tablet PC
Need to clean keyboard
hi yes you can clean the keyboard. i am placing three website links which clearly tells the steps to clean a keyboard
http://www.compukiss.com/care-maintenance/clean-the-keyboard.html
http://www.helpwithpcs.com/maintenance/cleaning-keyboard.htm
http://www.pcworld.com/article/112041/stepbystep_keep_a_clean_keyboard.html
here is another link which has a video about cleaning the keyboard.
http://www.ehow.com/video_2026_clean-computer-keyboard.html
Hope this website link be useful.
Apr 17, 2009 | Fujitsu Siemens LIFEBOOK T4010D Tablet PC
Does the Fujitsu 500 or 600 have electronic signature capablility
I don't see why, if the correct software is installed, it wouldn't be able to do it. Both devices have a passive digitizer, meaning that you "write" on the screen. Though you would need to insure that the software is windows 2000 compatible, or hire someone who has the experience with either device to install XP on it for you. Hope this answers your question! Good luck and Godspeed!
Jan 29, 2009 | Fujitsu Stylistic LT C-500 Tablet PC
Using wmc ir keyboard with tablet pc
Acer's IR ports works only for Remote control and certain compitable devices only. its not open port for all devices. It cant be used for other pheripherals as far as i know! If its bluetooth then it can work surely.
Nov 25, 2007 | Computers & Internet
Do I need a battery to run the PC Tablet?
THe manual for your specific model can be found here: http://support.fujitsu-siemens.com/Manuals/ShowDescription_KMT.asp?DokuID=202607 Documents for othe models and languages can be found here: http://support.fujitsu-siemens.com/com/support/manuals.html
Sep 24, 2006 | Fujitsu Siemens Stylistic ST5022D Tablet...
Fujitsu (FMWKB4A) Keyboard Logo
147 people viewed this question
Top Fujitsu Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Prashant  Sharma
Prashant Sharma
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
