Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Water will not drain from my Cabrio
When my Cabrio washing machine gets down to 13 minutes and it is draining the water, it doesn't drain the water or move on to the rinse cycle. My friend has had her "board" replaced three times on the same model also. Is this the board or another issue with this machine?
  • Anonymous Mar 13, 2014
    I have a cabrio model wtw6400swo I set it to wash in colors when it reaches 33 minutes water runs and does not stop i
  • 121 Answers
Check pump filter.
Posted on Feb 17, 2009
    Problem Solver:
  • 6 Answers
The Board is a computer, if the drain pump is clear then the board is bad, Get a surge protector to stop this from happening again after you replace the main board.
Posted on Nov 24, 2012
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
Cabrio washer stops spinning and doesn't restart
it sounds like the water pump is not emptying properly, blow down the water outlet pipe to see if is clear if not go to the water pump and clean it out there is probably a button , paper clip or other debris preventing it from doing its job eric
Dec 25, 2017 | Whirlpool Cabrio WTW6600SBT Top Load...
How do I manually drain Cabrio auto washer when the computer board is fried?
You can either dip it out or if you have a wet/dry vacuum, that will work. after you get it down to the bottom of the tub you should be able to lower the hose going to the drain and get it down even further. Hope this helps.
Feb 04, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Lo error code in cabrio
There is no "Lo" code I can see in the service manual, but there is an "oL" code which flashes when the machine/motor control detects a load size that exceeds the washer's capacity. Open the door lid to clear the display, and remove excess laundry, then close the lid and restart the cycle.
There is an "Ld" which related to a Long Drain when the water level doesn't change after the drain pump is on. Need to check to see if the drain hose or the drain pump is clogged.
Jan 30, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
What can I do to get my WP Cabrio washer to drain & spin?
Your drain hose has to be higher than the water level in the tub, almost up to the top of the tub
Dec 30, 2011 | Whirlpool Cabrio WTW6600SBK
Whirlpool cabrio .....
I imagine it it has detected suds and is doing mini loads to correct the problem. I have a manual HERE
Feb 12, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpoll cabrio wsaher won't drain
If this a electrical pump chk. to see if there is an in line fuse if not then take the hose loose to see if the impeller has any thing hung in it or it could be a bad spot on your timer
Aug 17, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
What causes Cabrio washer to get unbalanced in spin cycle?
Try making sure that your draining hose isnt jammed all the way down the hole. When you installed it the u shaped accessory was needed for the draining hose. Try pulling the draining hose out...curve the front and zip tying it to your cold water valve. This will allow it to drain properly and not get water push back into the drum causing it to be unlevel
Aug 02, 2009 | Whirlpool WTW6200S Top Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
635 people viewed this question
Dan Webster
Dan Webster
Sal De
