Whirlpool LER 7646 electric dryer. Suddenly quit running. Heating element comes on, but no fan and the drum will not turn. Don't know what is wrong
SOURCE: whirlpool Cabrio electric dryer
ctwoods, this sounds like the heating element has shorted to the heater can. What that is doing is leaving the element at 1/2 power on all the time. If this happened, then the heat kept going up until it blew the thermal fuse which caused the motor not to run. So check the heater and any fuses in the dryer. You can go to Service Matters for Whirlpool Service Manuals on this model.
SOURCE: Newer Whirlpool Dryer Heat Element keeps breaking
SOURCE: Whirlpool Electric Dryer, model LER7648KQ1. The
Check your previous post. I left additional info for you.
SOURCE: LER4634EQ2 whirlpool electric dryer. heating
I know this might sound stupid but try this. Find your fuse box, locate the breaker that runs your dryer. Flip it off and then back on. If i'm correct, it will work. Everything on your dryer works off of one leg of the 220v. The other leg goes to the other side of the element. If you have a meter. check for 220v at the plug. Everything you listed is what makes the dryer heat other than the thermostats. Check the cycling thermostats like you did the other pieces. They look like the thermal cut off. They have two wires and they are round.
