Question about Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1
I have a Hayward 11 KW spa heater that was not heating up. The indicator light would come on but no heat. i replaced both 5500 elements and now the light wont come on and still no heat. I pressed the reset button but still no heat. What have I missed. Thank you. Mark O'C
  • moconno Feb 17, 2009
    That is a C-Spa-XI electric spa heater not gas.
  • 22 Answers
Check the power to the relay and pressure switch just remember the problem lies where the power dies.
Posted on Feb 18, 2009
No Heat
The acid test would be to "jump it" and see if the heater functions normally. That's where you bypass the limit, taking it out of the loop. If you determine that the limit is the problem replace it, do not use the heater with the limit jumped.
Otherwise it may be the heating element itself. They do go out after a while.
Dec 14, 2013 | Raypak Spapak Electric Spa Heater -...
When first installed, the connection was not done properly causing the wire to burnt and shorten the circuit. it was all corrected, but now it does not heat the water, elements seems to be ok. could you...
Start with your breaker. Be sure to shut it completely off before turning it back on. Then start checking the power all the way through the circuit. The 220v will follow through the main contractor to the element. If you have good power there make sure the high limit is reset by pushing the button in. This is a square disc on top of the heat cell and probably has a rubber disc that corresponds with it on the face plate on the outside of the heater.
Then check the 110v that comes off the side of the main contractor and runs through the switch, the thermostat and any other components. If the power stops at any of these, then that is your problem. If no problems in this circuit then pull your element and check it again.
Dec 24, 2010 | Hayward 11 Kw 240v 37k Btu Spa Heater
Just replaced the heating element on my Raypak 1102-2 Turned the unit on & the on light didn't come on. Did i replace the element for nothing? What could the problem be THANK YOU
Check your high limit. This is the reset switch behind the rubber button on the face of the heater. It probally tripped during the process and didn't get reset.
May 12, 2010 | Raypak Spapak Electric Spa Heater -...
Hayward H Series Pool & Spa Heater 400k Btu Propane Gas Milivolt Ignition H400p1 Logo
257 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
Craig Butler
Craig Butler
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
