Question about Proview PL913S 19" Flat Panel LCD Monitor
Need power cord proview pl913s - Proview PL913S 19" Flat Panel LCD Monitor
  • 558 Answers
Standard computer power cable three prong plug and molnex type socket you can find them at second hand stores and at computer stores, ebay may be best
Posted on Mar 23, 2009
    Genius:
  • 2,120 Answers
Check eBay
Posted on Feb 17, 2009
My monitor will not turn on. I verified that I do have power to the monitor but when I press the power button nothing happens. Also how do I open the monitor case after removing the screws on the back?
I would suggest you leave the idea of opening the monitor for now and do the following checks first:
- Check the power cord if it's properly connected and not loose.
- Use another power cord to make sure it's not the power cord that's faulty
Do not open the monitor, unless you know what you're doing, as this may only deepen the problem.
hope this helps.
May 06, 2011 | Proview PL913S 19" Flat Panel LCD Monitor
Hello, i need the inverter for this monitor proview pl913s silver 19 inc. flat panel lcd. product# pl913s The monitor turns on and shots off after a second. how can i resolve this thanks
Did you inspect the caps for domed tops in the power supply/inverter board yet? Worst case will be the lamps assembly.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Jan 14, 2011 | Proview PL913S 19" Flat Panel LCD Monitor
Does LCD monitor emit UV light?
The monitor use Fluorescent lamps (CCFL) to light up the screen, same kind as used for the home fluorescent lamps, no different, they are just smaller in size and lower wattages. Do you use fluorescent lamps in your house to be Green, if there are conflicting info then they would have banned fluorescent lamps a long time ago and will not be banning regular light bulbs in the future.
May 22, 2010 | Proview PL913S 19" Flat Panel LCD Monitor
Looking for circuit board for a 19in proview lcd monitor
Which pc board are you looking for? Most LCD monitor companies use third party PCB assemblies. Can you get the name and number as printed on the PCB?
http://s807.photobucket.com/home/budm/allalbums
Apr 18, 2010 | Proview PL913S 19" Flat Panel LCD Monitor
No power
If you are technically able, you could replace the power supply capacitors on the power supply circuit board in the monitor. This takes a little skill with a soldering iron and purchasing 105 degree capacitors of the right value. Do be cautious of the capacitor direction, and be careful of the 160 volt supply and the 1000v supply to the backlight. Don't void your OWN warranty.
Very cheap to do to see if the monitor can be saved.
Sep 28, 2009 | Proview PL913S 19" Flat Panel LCD Monitor
Power cord for the Proview Model 800
http://www.cablestogo.com/product_list.asp?cat_id=1024
http://cgi.ebay.com/AC-Adapter%2fAdaptor-Power-Cord-For-PROVIEW-LCD-Monitor_W0QQitemZ150338552665QQcmdZViewItem
Aug 26, 2009 | Proview Computers & Internet
Moniter clicking
check capacitors inside for damage is found replace them
Feb 13, 2009 | Proview PL913S 19" Flat Panel LCD Monitor
Cost to repair popped ic
Sounds like the vga on the board has gone wanky I would look for a replacement on ebay nothing really you can do with this besides replace the pcb board with the processor on it.
Aug 05, 2008 | Proview PL913S 19" Flat Panel LCD Monitor
Proview PL913S 19" Flat Panel LCD Monitor Logo
152 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Frank Russell
Frank Russell
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
