Question about Maytag MEW6527DDS Electric Single Oven
Hotpoint EG900X rear round heating element
I have a hotpoint EG900X which has a setting to turn on the rear fan and the rear round heating element, but the rear round heating element no longer works. Is the problem with the element or the control knob . Any ideas ?. If the element is at fault how do i replace it ?
  • Maytag Master
  • 3,463 Answers
If the fan is working, but there is no heat from rear element, then the element needs replacing.
Remove inner rear cover of oven, you will see the element there, remove, and replace.
Please leave a rating for my suggested solution.
Thanks.
Posted on Feb 17, 2009
Hotpoint oven is not heating up
If it is a fan assisted oven and the fan is working o/k, then you need to replace the oven element.
This is located behind a removeable cover at the rear of the oven compartment.
Oct 15, 2010 | Hotpoint Ovens
Are the Fan assist elements on a Hotpoint EG900X oven replaced from inside the oven cavity or must you remove the entire back of the unit to replace it like you have to with the grilling element...
you can do it from inside providing you dont lose the wires when there disconnected. if you do the oven has to come out to reconnect them.
Jul 22, 2010 | Hotpoint Ovens
Hotpoint sy36x grill element works fine but when switched on to oven it doesnt heat up, fan working.
it seems to me that it is a fan oven and the top element won't heat up you need a new fan oven element. it is a round element that sits behind the back grill surrounding the fan...
regards
richard saupe
appliance repairman
Mar 14, 2010 | Hotpoint SY36 Style Line Stainless Steel...
Hotpoint ew92 oven failure, fan works no heat what to check?
It is probably thr oven element that has gone
This is located at the rear of the inner oven compartment behind a removeable cover.
Feb 28, 2010 | Hotpoint Ovens
The main oven of my DY46 Hotpoint is not heating up
It will be the element that has gone, and it is easy to replace.
Remove the cover at rear of oven compartment, and you will see the fan element, just undo fixing screw,and replace element.
Feb 22, 2010 | Hotpoint DY46 Style Line Stainless Steel...
My hotpoint ew73 fan oven won't heat up at all. It's just stopped working. the fan is working but oven staying cold.
You need to replace the oven element.
This is located at the rear of the oven compartment behind a removeable cover.
Please rate my solution.
Thankyou.
Jan 24, 2010 | Hotpoint Ovens
Hotpoint BD32 element not working, How can I check if it is a faulty element
Assuming you are talking about the fan oven element, you should be able to feel heat from it , if you are not sure it is working, then you need to remove the rear cover of oven to expose the fan and the element, run it for a couple of minutes, then feel if it is hot, if not, it needs to be replaced.
Hope this helps.
Nov 27, 2009 | Hotpoint Ovens
My hotpoint oven is not heating up but hobb and grill working fine is it the heating element?
If you have a HOTPOINTelectric Cooker or Fan Ovenwhich is not heating it could be one of the following problems.
1, If the fanmotor inthe back of the oven is going round and the temperature light is on (normallylittle red light), but there is no heat then you will probably need a new ovenelement, these are generally very easy to fit and readily available from ourwebsite these can be tested with a electric meter.
To gain access to the HOTPOINTelement youwill have to remove the back plate from inside the oven. Once removed you willsee the fan and element,if you look closely at the element you will probably see a small hole burnt in it where ithas blown. Sometimes however there is no evidence of a fault but the element is open circuitie: broken inside the element casing, either way it will need replacing. Someelements will are fixed from inside the oven and some are held in place by nutsfrom the rear of the machine.
2, If your HOTPOINTfan oven is getting warm buttakes a very long time to cook or is burning the food more on one side than theother, then you need to check if your oven fanmotor is working you will seethe blade turning fast if it is ok. if the element is heating but the fanmotor isnot blowing the heat into the oven then you need To replace the oven fanmotor is a little more expensive and a bit moreinvolved.
3. If you have theopposite problem ie: your oven is over heating and burning everything then youwill need to replace your HOTPOINToven thermostat
4, A quite commonand easily overlooked answer is if your HOTPOINToven is not working at all ie:no heat and no fan then the chances are that someone has put the oven timer intoAUTO mode, simply put oven back to MANUAL mode and all should be working again.
Nov 15, 2009 | Hotpoint SY36 Style Line Stainless Steel...
Oven not heating
Hello.
If the fan is working, but there is no heat, then it is the fan oven element that needs to be replaced.
It has nothing to do with timer on this occasion.
Remove panel at rear of oven compartment, there you will see the round element.
Undo fixing screws,and remove element, disconnect leads and fit onto new element, refit new elemrnt, replace cover, and job done!!!
Please leave a fixya rating for my solution.
Thankyou
Feb 04, 2009 | Hotpoint DY46 Style Line Stainless Steel...
Hotpoint ew83p oven has no heat
The oven fan element has failed, you need to fit a new one.
Remove inner rear panel of oven and you will see the round element at rear.Unscew screw(s) that secure element, disconnect leads, and fit new element.
Refit element cover.
Job done..
Make sure you have power off to oven before you start.
Plz rate my solution.
Thanks.
Jan 12, 2009 | Neff B1641 Single circotherm super...
Maytag MEW6527DDS Electric Single Oven Logo
569 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
