Question about GE Nautilus 24" Built-in Dishwasher
Buzzing Sequence Box, turns on and off, on and off, on and off.?
Dishwasher- GE 165D5315. The sequence swich box was buzzing, and when I turned on the washer it would just go on for a few seconds and then switch of, then on then off. I replaced the sequence switch box and that didn't help. ??
  • imm_sadiq Feb 20, 2009
    I have the same problem as wally_peter's having, I press the start button and it turns on for like 5secs and turned off by it self,can anybody help me?
rickzilla
  • 706 Answers
SOURCE: After a power outage, my
Unfortunately, if you lost power as a result of a lightning storm or a power surge, there is a good chance that your dishwasher was exposed to a power surge that may have damaged the control circuitry. During these types of events, there is no way of knowing which device was affected unless there are visible signs of carbon or a burnt smell on the ircuit boards... so it will be a hit or miss proposition to repair it. You may have no choice other than to have an appliance person come in and diagnose the problem. Assuming they have a full complemnent of hardware with them, they might try swapping out individual piece parts until the right one is found... Good luck...
Posted on Sep 18, 2008
SOURCE: Our Nautilus dishwasher won't turn on. I can hear
The same thing happens with my dishwasher. I have made it work by doing the following. When you start up the cycle, turn the dial to just a tick before "start." If you hear the buzzing, but no water is running, unlock and then lock the dishwasher door again. This usually gets it running. If it's still not running water, unlock, advance the dial a little bit, and lock again. This should work. You need to be around for the early parts of the dishwashing cycle because this machine tends to stop up and buzz without running water until it gets past "short wash." Every time this happens, do the same thing, unlock and lock, and advance the dial a little when necessary. Once you get past "short wash," it should complete the wash without intervention.
Posted on Mar 04, 2009
  • 197 Answers
SOURCE: My GE Monogram ZBD4500 dishwasher
I bloody lostt you! are you still there?
Posted on Aug 03, 2009
jan mczeal
  • 632 Answers
SOURCE: the pump motor seems to be jammed on my GE Model
Dishwasher motors are susceptible to getting stuck if not used regularly. Manually spin the motor to free it up. Dishwasher motors are not serviceable and must be replaced if found defective.But try to access the bushings/bearings and put a few drops of lubricant then spin it manually to free it up.
Posted on Aug 31, 2009
Testimonial: "I think that fixed my problem. Thanks!"
rylee_smith
  • 8619 Answers
SOURCE: what is the sequence to reset our kenmore 16052
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on May 26, 2010
Testimonial: "Thank you, worked like magic!"
Westinghouse tv power box making buzzing sound
Hi I'm Peter, There is a bad connection and most likely the buzzing sound is a relay going bad internally.
Apr 19, 2014 | Westinghouse Televison & Video
Acer computer won't boot has long buzzing noise
The long buzzing sound indicate the nature of the problem. Depending on the manufacture of your bios will determine the problem. With only one long beep you may have memory problem. The computer cannot initiate the boot sequence. Did you add any devices to the computer prior to your problem. if you did undo what you did. Make sure the computer is on, if nothing happens ( no lights, no sound, no fans etc.) the computer has a power failure. Make sure you listen to the beep if it is a numerous beep sequence note it down and check the web for computer beep during boot up.
Mar 25, 2012 | Computers & Internet
New ac seer 15 when ut turns on I have buzzing in electrical circuit box
The electrical box on the new a/c unit is what is buzzing? If so then thats the contatcor making that sound and is nothing to be too concerned about. If that buzzing is coming from your breaker box then turn off that breaker and call an electrician.
Jun 22, 2011 | American Standard Heating & Cooling
When you turn on iginition, buzzing comes from fuse box. When you turn the ignition, the engine does not turn. All fuses check ok. Atop the fuse box there are 4-5 harnesses going into the top of box. When...
check your computer under the hood and make sure none of those fuses are blown. Also, can the vehicle be jump started. I have a 2000 expedition that did that and a fuse was blown under the hood.
Oct 05, 2009 | 2003 Ford Expedition
1993 Mercury sable, black box near radiator buzzing....
well there are a lot of things but lets try make sure that box is grounded and try the reset either under dash or at back of car inside i think that is a relay you r talking about not sure need more info
Aug 09, 2009 | 1993 Mercury Sable
Loud Buzzing Sound from Dishwasher
have you ever seen green led "Clean" light flashing? before or about the same time the buzzing sound started? and if so that would indicate that the control senses a fault in the temperature rise during the heating cycle and that the electronic control could be reset by initiating a service diagnostic cycle.(which is what you were trying to do) pls reread your manual there are times during that sequence that some buttons have to be pushed at the same time and within a certain amount of time..possible that your machine also has a bad timer which would give you a buzzing noise..if thats the case I would recommend replacing the cpu or control board..or the machin all together..The Kenmore Ultra Wash Quiet Guard name is sears but whirpool has the contract to produce all "kenmore products.hope that helps.
Jul 30, 2009 | Dishwashers
Our Nautilus dishwasher won't turn on. I can hear a buzzing noise, but nothing is happening. Does anyone now what I should do?
Feb 22, 2009 | GE Nautilus 24" Built-in Dishwasher
Turn signal buzzing in off position but not on/hazards work with buzzing all the time
I sounds like you did a good job of isolating the source of the buzzing. I, too, was unable to locate that part number on the web. Changing the "convenience center" of course would be your best bet, but if you are unable to locate a replacement, you might want to try cleaning the plug that connects to the convenience center. It could be that it has oxidized pins that are creating an incomplete connection causing the flasher to buzz.
Best of luck to you.
Mike
Jan 25, 2009 | 1997 Oldsmobile Achieva
92 Accord Buzzing Sound below Glove Box
well that's where your ac blower motor is. you may have something wedged in it smacking the blades on the wheel or the bearings in the blower motor could be going out but that would making more of a hum or a grinding noise.
Aug 20, 2008 | 1992 Honda Accord
GE Nautilus 24" Built-in Dishwasher Logo
70 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
