Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Green light flashing-tv will not reset-no picture no sound
We have a 52 inch tv that will not start. The service dept where we purchased it said the flashing green light was due to a bad lamp. We replaced the lamp and the tv still flashes the green light and still not picture or sound. Do you have any suggestions??? Thank you.
  • 1 more comment
  • gerty33 Feb 18, 2009
    I have a WD-52525 with a quickly flashing green light (~3Hz) whenever we plug it in or hit the reset button. It will only respond to those two things. (oh, and opening the lamp cover - lamp light blinks instead, but that's hardwired)
    Best Buy guy came to look at this exact problem months ago (back when it was still under warrantee) and it cleared up after leaving it in this state for 18 hours (to wait for him to get there) and then unplugging for a few seconds and plugging back in. We chalked it up as intermittent and he left. This time waiting has not worked.
    If I were to guess it would be some kind of worn out circuit on a board somewhere making it think it needs to self-test until kingdom come. Next step is to take it apart and vacuum out all of the dust. That is, unless someone else can come to the rescue. DVR is filling up quick! Help!!
  • snyd37 Feb 19, 2009
    I have a green light blinking under the word timer. No sound or picture. The repair man said it was the main chip board but mitsubishi dosent sell a main chip board. If you have had same problem please let me know what board to buy. Thanks
  • gdpott27 Feb 19, 2009
    I have the same problem and had a technician tell me it was the circuit board. Apparently, when there is a power outage the system tries to reset and the components in the circuit board go bad. This has happened before but the reset button worked. Now he said the TV is worthless unless I send this part to Mitsubishi. This is about a $800 and 6 weeks fix. Also, I was told Mitsubshi is aware of this problem and really don't care. Their customer service is horrible. What I did was claimed it under my homeowner insurance and got replacement cost. It wasn't what I paid for the TV but it helped in buying a new one. If anyone else has any suggestions, please let me know.
  • Mitsubishi Master
  • 19,396 Answers
When TV does not start, and sometimes you hear a clicking noise, that means that the TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on Apr 21, 2009
Green light flashing on TV. Cannot get it turned off. No pictur
Did you get yours resolved? I had the same thing. The repair guys called it the "flashing light of death". It indicated the TV is dead.
Jul 13, 2010 | Mitsubishi WD-52525 52" Rear Projection...
I have a Mitsubishi WD 52628. I replaced the tv
try turning it on hold the menu button for eight seconds menu pops up try reseting the settings again as before you had the problem
Jan 23, 2010 | Mitsubishi WD-52628 52" Projection HDTV
Picture & sound go off for 1-2 minutes, then return.
The most likely the TV has a power supply related problem.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Jun 27, 2009 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Green light covering all picture with no sound on occasion.
In LCD TV such problems occur due to problems in the circuit board. So no option for you to go for repair to your branded company authorized personnal.
Apr 23, 2009 | Televison & Video
Sony LCD 52 inch
This sound like you are having problems with the power supply board. Since you are getting a momentary picture and sound the fuses are good but TVs today have "shorts" and "overvoltage" circuitry build in that will shut it down on errors. Someone knowledgeable in electronics will have to isolate the exact cause.
Dec 05, 2008 | Samsung LN-S2641D 26 in. LCD HDTV
Picture jumps after a few hours turned on
I have a 3 yr old 55 inch mitsubishi TV and when I turn it on the green light starts flashing and I must reset the TV about four times before it finally comes on has anyone had this problem if so what solution did you have?
Jul 25, 2008 | Mitsubishi WD-52525 52" Rear Projection...
52 inch RCA - green light turns on & off, BUT no picture
CP150 is a capacitor in the power supply circuit....feel top to
see if flat....change if "pooched" or swollen..................T.
Apr 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
1,188 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
