Question about Kenmore 16602 / 16604 / 16609 Built-in Dishwasher
Dishwasher cyle will not rinse after washing it will just stay washing cyle
  • 15,935 Answers
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&%$
Posted on Oct 01, 2010
The dishwasher is staying in the washing cycle
LG14AW2 DISH WASHWER STARTED AND RAN YESTERDAY , STARTED IT TODAY , WENT TO WASH CYLE AND STAYED ON THAT . TURNED IT AND TRIED TO RETART IT ,ALL THE LIGHTS LIGHT UP BUT NO GO . HAVE CHECKED THE DRAIN HOUSE ,ALL OK ,FITTED NEW PUMP . AND STILL DOES THE Same thing , whaat do i do next to fix this dam thing
Aug 11, 2011 | Frigidaire FDB1100RHM Builtin Dishwasher
Light is on for heat dry but won't allow me to run a cyle or turn on
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad.
Hope this helps... Please post back if you need more information.
Daniel
Apr 17, 2011 | Frigidaire Professional Series 24 in....
I have a Kenmore Dishwasher model # 587.1523. For some reason, after washing or rinsing cycles are complete, water is still in the bottom tub. My question is, besides the troubleshotting tips in my use and...
Good Evening,
Have a Kenmore\Quiet Standard Model#587.1523 900
Dishes are not getting washed, cyles through , Believe the inside Top Nozzle is not getting any water up the tub to the top of the washer ?? Not sure hoo to fix this ?
Thank YOU for Your Time.
Mrs. Garza
Jan 13, 2010 | Kenmore Dishwashers
The dish washer fills and wash cycle begins, however stuck at wash does not progress to rinse cyle
you should check the heating element. if the water is not hot enough, the timer will not advance. crack open the door mid-cycle. let the water stop flying around. then open it all the way up. if you don't get a big ball of steam, you have an indication that your heating element may not be working properly. this is not too hard to check the resistance with a multimeter and then replace, if necessary. good luck
Nov 03, 2009 | Indesit 18 in. D41 Slim-Line Free-standing...
My dishwasher will fill with water, but when the wash cyle starts it does not sound like the blades are turning it makes noise, but does not wash
remove the occilating blades and rinse with water
water needs to go through the blades for them to spin, so if no water is flowing through them you need to clear them.
Sep 11, 2009 | Dishwashers
NOT DRAINING AFTER RINSE CYCLE
Dishwasher is not filling in first cycle. only in rinse cyle then it won't drain it
Jul 31, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwasher doesnt drain on wash cycle,ok on rinse cycle
Change the circuit board, timer/progrsmer.
Take it out and clean contacts,
Look for burnt circuit line and solder a fine bead carefully on the circuit board, difficult. Use the pot and pan program.
Vitally
May 03, 2009 | Maytag MDB7100AWB Dishwasher
Wash cycle not working
If it drains on start up, the pump is not dead
Dec 10, 2017 | Frigidaire 24 in. FDB750RC Slim-Line...
Water will not drain after wash or rinse cyles
sjjordan96,hey just had the repair guy come today. The problem is the one way valve on the washer was clogged. Its easy to get to just remove the bottom panel of the washer and disconnect the drain hose and clear the clog.
Jan 23, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
THE DISHWASHER STAYS IN THE WASH CYCLE
Check to see if the water is getting hot during this time, if not then the heater is probably not working, could be bad heater, bad door switch or bad heater relay on the control board.
Dec 14, 2008 | Whirlpool 24 in. GU3200XTP Built-in...
Kenmore 16602 / 16604 / 16609 Built-in Dishwasher Logo
87 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
