Question about Dell OptiPlex GX520 PC Desktop
Dell Optiplex GX520 message: "Alert! System battery voltage is low." PC clock is 5 minutes behind.
  • Amelia Whitehead Feb 17, 2009
    Well, I'm not experienced in computer maintenance, so I hesitated to rate it as FixYa! just yet, since I will need to learn how to safely open the PC, and how to adjust the clock setup.
    Thank you for your prompt answers and extreme thoroughness!!
  • Dell Master
  • 13,433 Answers
Hey,
there is a 3 volt flat battery inside the computer, it in most cases clearly visible.
Dell Optiplex GX520 message: - 4047395.gif
Replace it with the same type of battery, then adjust the clock in the system setup.
All done, all fine.
Let me know if you need anything else.
Thanks,
Ekse
Posted on Feb 17, 2009
  • 1 more comment
  • Ekse Feb 17, 2009
    Hi
    If the problem is solved I would appriciate a Fixya rating instead of helpful.
    Thanks,
    Ekse
  • Ekse Feb 17, 2009
    Oh I see.
    1. unplug all the cables from the computer
    2. there are a few screws on the cover of the case it should slide open after that
    Heres a picture
    http://depot.omegacorp.net/share/bbs/pc_...
    the side should open like this, debends on the spesific computer.
    the computer is a low voltage device, there is 12volts inside the computer when its turned on. So you can't kill yourself while working on a computer. Unless it hits you on the head, which is very unlikely.
    • find the memory battery, should look as the picture before.
    • snap out the battery.
    • insert the new battery
    Next is the clock adjustment.
    When you turn the computer on, it will say somewhere on the screen to press button to enter setup or cmos. Press the button, its either f1, f2, del, etc.. it reads on the monitor.
    when your on the setup you will need to find the clock adjustment, feel free to play around. If you think you did something wrong, just exit the setup and discard the changes, or reset. When you have done the correct adjustments just save and exit. the settings wont be saved automatically you need to save it on exit, so you can play around freely.
    well
    Thanks,
    Ekse
  • Ekse Feb 17, 2009
    Also as I said its low voltage but always unplug before working inside. Thanks
How to reset the board of dell optiplex gx520
Remove the CMOS button battery on the system board for 30 minutes, then replace.
Apr 25, 2014 | Dell OptiPlex 170L PC Desktop
Alert System battery voltage is low
If it's installers correctly , reseat it and verify. Try unplugging the machine for a few minutes. Did you try to reset the Time in BIOS?
May 04, 2013 | Dell OptiPlex 380 PC Desktop
My dell demension E521 is giving me a "alert system battery low" message. Any suggestions?
Check the batteries voltage and check to see if the battery is being supplied charge voltage when the computer is off. If both these are good then your low battery message is in error. No charge voltage would mean faulty charger and low battery voltage would mean faulty battery.
Dec 15, 2012 | Dell Dimension E521 PC Desktop
Where is blinking amber light located on dell
Replace CMOS Battery.
1. Locate your CMOS battery
2. Obtain battery information
3. Removing the battery
4. Removing the battery
5. Enter CMOS values
This link will guide you. CMOS
Thank you for posting..
Jun 30, 2011 | Dell OptiPlex GX520 PC Desktop
Alert! system battery voltage is low. Strike the F1 ke to contunue, F2 to run the setup utility
Dell claims the problem is caused by some surge suppressors - and that you can eliminate it by removing the surge suppressor and plugging the PC directly into the wall outlet. Call Tech Support and have them send you a battery, or look in the system docuemtation and go to Radio Shack and get a new one if you are in a hurry.
Jun 21, 2011 | Dell OptiPlex GX520 PC Desktop
When I powered on my GX620 desktop computer, I got a "low battery" message. How do I resolve this problem?
There is a very small watch battery on the mother board. You will need to replace that. This battery keeps the time and various bios settings alive when the computer does not have power.
Feb 28, 2011 | Dell OptiPlex GX520 PC Desktop
Battery voltage low on Optiplex GX520
Just take the battery out and go to Radio Shack or a drug store. The number is written on the battery.
Gary
Jun 25, 2009 | Dell OptiPlex GX520 PC Desktop
The service tag is 19sfy91. At first I could not get past BIOS error "Alert! System Halted. Incompatable processor" I flashed BIOS and the PC boots up but I still get the error message with option F1 to...
The new series of Intel G1 stepping Pentium 4 processors (Prescott) is not backwards compatible with all the latest BIOS versions for OptiPlex systems.
Jun 05, 2009 | Dell OptiPlex GX520 PC Desktop
I have a dell GX 270 that has orange light on mother board, shuts down randomly, seems hot, and says Alert! System battery voltage is low. The fan is running but doesn't kick out much air..
The battery message means you need to change the battery on the motherboard, it looks like a coin about the size of a nickel. Which fan is malfunctioning, the power supply fan, the case fan, or the processor fan?
May 19, 2009 | Dell OptiPlex GX270 PC Desktop
Dell OptiPlex GX520 PC Desktop Logo
4,583 people viewed this question
Alun Cox
