Question about Avanti WC400YGB Wine Cooler
Ice forming inside of wine cooler
Ice was forming around drain hole.
  • 29 Answers
I would check running temp 1st/possible gas fault
Posted on Nov 10, 2009
Why is our EuroCave DUO wine cooler model D264 freezing 1/4 inch of ice on back wall inside cooler?
Most cases of ice build up can be traced to seals that leak humid air into the cooler. Check the door seal carefully using a fresh $1 bill. The bill should not pull out easily when the door is closed. If the unit has a self defrost feature it it is not coming on. Ice buildup inside a wine cooler is very rare. The cooler box should not reach 32deg in normal operation. Does the unit seem to run continuously?
Sep 10, 2014 | Furniture
What causes Ice build up on inside back panel of kitchenAide KUWA244PBS?
normally that means yhe defrost thermstat is bad or the heating element that causes the defrost is bad.
Aug 31, 2014 | KitchenAid KUWA244PBS Wine Cooler
Ice build up
Normal to have a bit of ice. Set the temp to 0 for a few hours every week. Check Seal is good all round the door.
Apr 20, 2014 | Haier HVFM20ABB Wine Cooler
Plugged drain
Need to completely defrost freezer. hot rags, hot water, paper towels, etc. Until you get all the ice out you don't have a chance of unclogging the drain. Could be just ice clogging it too which in that case hot water will solve that as well. If it's something else clogging the drain, I've used a mini bottle brush to unclog them or even a stiff piece of solid wire.
Mar 18, 2013 | KitchenAid KFCS22EVMS Stainless Steel ...
MagicChef Beverage/Wine Cooler keeps getting ice build-up on inside back panel
Ice build up wil accor if the evaporater blower goes out and does not crculate the air. If you have the model number off the tag I can be of more assistance, with the mobel number I can break the unit componants down in a diagram
Oct 07, 2012 | Refrigerators
My wine cooler is not reaching the set temperature. It stops at around 73 and the display flashed AL. Any ideas?
check to see if compressor cycles, if so you may have a thermistor problem which is intergrated with control, replace if you can find part. make sure to check evaporator, see if ice is forming if so you have a leak,or dry evap. you have a leak. repar.
hope this helps.
Aug 14, 2010 | Vintage Keeper Koolspace Wine Cellar
Leak to under ice cube tray causing drawer to freeze shut.
May be your freezer evaporator drain hole is frozen. If this is the case, you can try to install a low heat drain hole heater into the drain hole and connect the wires with the defrost heater.
Jul 04, 2009 | Traulsen Refrigeration 48'' Wide x 24''...
How do you use a breville wc15xl wine chiller
HOW TO USE
First you place the Wine Cooler on a flat, dry surface, making sure that the timer is in the "off" position.
Remove the chill cells from the freezer and place around the inside of the cooler.
Thirdly, place the bottle inside the cooler and then pour cold tap water inside, until it just covers the top of the chill cells.
You can then plug the unit in, or if it has batteries you don't need to.
Finally, you set the control dial to the desired time. The following are recommendations for different types of beverages:
Sparkling Wine, Champagne and Dessert Wine.....9 minutes
Dry Wines, Sauvignon Blanc, Riesling.....6 minutes
Chardonnay, Rose'....5 minutes
Light Red Wines, Pinot Noir....3.8 minutes
Full Bodied Reds, Shiraz, Grenache, Cab Sauvignon, Merlot....3 minutes
If you choose to chill a beverage without the timer, you just turn the control to the left and when you are done you turn it to the off position.
In addition to wine, the cooler can also chill beer and soft drinks. The only limitation is that the bottle diameter can be no more than 3.75 inches.
Should you wish to chill two or more consecutive bottles, the cells will remain cold enough for you to to do so.
While not in use, the cooler can also be used on the table with ice to keep your beverages cold (much like a regular ice bucket).
The power cord is removable, which makes for an easy clean-up.
The unit comes with a manufacturer's One-Year Limited Warranty.
Apr 10, 2009 | Breville WC15XL Compact Wine Cooler
Ice is forming on the outlet holes on the face of my 4200 xlt
you should check to see if the fan at the back of the unit is operating, and you also need to check for dust build up, if the fan is working then clean and defrost the unit, try it again, make sure there is nothing blocking the airflow, if the motor is not running, replace the motor, hope that helps
Jan 18, 2009 | Vinotheque Whisperkool 4200 Wine Cooling...
The fan to disperse air inside the STC55800 wine cooler is inoperable.
9721, Boul Métropolitain Est
Anjou, QC, Canada
H1J 3C1
Telephone : 514-374-5343
Fax : 514-374-5344
Oct 04, 2008 | The Cellar STC55800 / STC55810 / STC55820...
Avanti WC400YGB Wine Cooler Logo
268 people viewed this question
Top Avanti Refrigerators Experts
Vernon Taylor
Are you an Avanti Refrigerator Expert? Answer questions, earn points and help others
